Question about Canon imageRUNNER 1310 Printer
Canon iR 2318 paper jam problems - Canon imageRUNNER 1310 Printer
ctf1800
  • 4402 Answers
SOURCE: ir 3300 paper jam
the heater section is the fuser you should be able to pull the tray out and then lift the door of the fuser
Posted on Sep 03, 2008
SOURCE: paper load and jammed problem
I have a problem of canon Mp180 printer. The problem is paper jam. When we start the print process and clear the process. It shows a message cancel printing.
Posted on Mar 20, 2009
digitalhubz
  • 109 Answers
SOURCE: My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Posted on Oct 21, 2009
FixinFax
  • 3085 Answers
SOURCE: Canon IR C3220 paper jam problem showing in the
Check to see if the EJECT SWITCH is hung up or out of it's holder.
Posted on Oct 30, 2009
  • 52 Answers
SOURCE: paper jam problem in pixma mp145. E3 error.
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
Posted on Nov 04, 2009
IR 2318. What is e261 error?
http://www.copytechnet.com/forums/canon/76193-canon-ir-2318-error-e261-dont-found-manual.html
Apr 05, 2016 | Canon Office Equipment & Supplies
Firmware for canon ir 2318
This is only available to Canon support dealers.
I can supply you with this firmware & the SST for £20
May 22, 2015 | Canon Office Equipment & Supplies
Service manual Canon ir 2318
Hello friend, I have downloaded a Good canon iR2318 service manual from below link:
Canon iR 2318 2320 2420 2422 service manual:
http://goo.gl/dBXTt0
Good luck on repairs.
Aug 03, 2012 | Canon imageRUNNER 6000 Copier
Canon IR 2318 Copying Problem
My Canon copier IR 2318 has a problem. When it prints, comes out a dirty paper with texts just easy to be rubbed by a finger and disappear! No any error code shown, so what can I do to fix this.
Jun 26, 2012 | Office Equipment & Supplies
Canon photocopier 2318 service manual
Hello friend, you can find the Canon iR 2318 2422 2420 232 service manual in below link:
Canon iR 2318 series service manual:
http://goo.gl/Ee4H4l
Thanks
Mar 12, 2012 | Office Equipment & Supplies
Error e000007-0000 for canon ir 2318
Feb 04, 2012 | Office Equipment & Supplies
My Canon Image runner 2318 keep jamming paper even no paper is not jammed
is this problem only when u copy from the tray or even from bypass.if it is from tray only then ur rubber feedrolls needs to be cleaned with simple wet cloth.if it is from both then u have to check the paper path sensor
Jul 13, 2011 | Canon imageRUNNER C3200 Copier
Canon ir 2318 shwos "out of toner.I unpacked the
this is the common problem with 2318. u have to take out the developer assembly out and if u are a rep then check the toner shutter in the dev assembly.it some times does not move in accordance with the toner cartridge. u have to align it with cartridge in home position. and be sure to check the toner cartridge sometimes the churner in the cartridge is broken but 90% is the above said
Jun 03, 2011 | Canon Office Equipment & Supplies
CAnon xerox Machine IR 2318 L Error code : E 000007-0000
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
Canon imageRUNNER 1310 Printer Logo
224 people viewed this question
old marine
old marine
