Question about Acer Aspire 5241 5251 5332 5334 5338 5516 5517 5532 5541 5542 5551 5551G 5553 5553G ... (30034027032) AC Adapter
Laptop not charging power & battery light flashes
    Top Expert:
  • Acer Master
  • 35,598 Answers
Depending upon the age of your Acer laptop, it may be time for a battery replacement
Posted on Apr 19, 2013
  • 2 more comments
  • bobmireau
    bobmireau Apr 19, 2013
    Replaced battery & AC adapter
  • Tom Chichester Apr 19, 2013
    Could the replacement battery be ng?
  • bobmireau
    Battery will charge to 100% but is very sporadic It will charge for a while then the lights start blinkingand will quit charging tried running with battery removed Again sporadic sometime will sometimes not
  • bobmireau
    I have another acer Model number Aspire 7741Z-5731 Mine is Aspire 5251-1805 Can I swap chargers & batteries to check for problems?
My acer laptop computer will not turn on, charge or anything. the charging cord has a flashing green light but no charge light on the computer.
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Oct 11, 2010 | Acer Computers & Internet
I have a dell inspirion 1545 the power light is flashing white and orange and the battery wont charge
Oct 07, 2010 | Dell Computers & Internet
I have a constant blinking power light, as long as the laptop is plugged in the the AC power lead, but when I try to start it up, the laptop battery light starts flashing, then stops and goes back to the...
Sep 19, 2010 | Acer Aspire 1640Z Notebook
My laptop gives a warning at startup "the charger will not be recognized". There is a little light flashing 3 red flashes alternating with one wgite flashes where the charger gets plugged in. The battery...
Sep 19, 2010 | Dell Studio 1535 Notebook
Dell b130 - battery indicator - flashing orange light - bios says "unable to identify this battery" and AC adapter = {none} is it the battery or do I need to flash the bios?
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
Sep 17, 2010 | Dell Inspiron B130 Notebook
Battery light flashes red. Battery will discharge but not charge. I have a cf-50 which is having the same problem. I replaced the battery twice but the batteries will not charge. I tried refresh. I...
Sep 14, 2010 | Panasonic Toughbook 50 Notebook
My HP Compaq 6730s will not turn on. There is a blue light with a amber flashing light around the ac cord input. I"ve disconnected the battery and the ac plug and it still happens when I reconnect them. Is...
Sep 05, 2010 | HP Compaq 6735s Notebook
I have a dell inspiron 1545 just over a year old. I have the laptop plugged in and working but the amber light is flashing on the front and the battery is not charging....heeeellllppppppp please
Aug 29, 2010 | Computers & Internet
HI I HAVE A PROBLEM WITH MY C500 FIRT OF ALL THE DC JACK ON THE CORD MUST HAVE WORN BECAUSE IT STOPPED WORKING I TESTED THE CABLE IT HAD A BREAK IN IT SO I BOUGHT ANOTHER ADAPTOR POWER SUPPLY AND I GOT...
Aug 25, 2010 | Computers & Internet
This a probelm with recharging the battery
Possibility is that your laptop's adapter's output is no longer capable of supplying enough power to charge the battery & operate the laptop simultaneously. Please try a replacement adapter & check if it resolves your problem.
Another possibility:
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Dec 28, 2009 | Acer Computers & Internet
Acer Aspire 5241 5251 5332 5334 5338 5516 5517 5532 5541 5542 5551 5551G 5553 5553G ... (30034027032) AC Adapter Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
