Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
Mtd yardman wont start getting feul no spark detected
Ive cleaned the filter, spark plug is clean and has the proper gap, there is feul getting to the carburetta, also the feul filter is clean but doesnt want to start, maybe the magneto what do you think, thankyou for your help
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Briggs & Str... Master
  • 1,917 Answers
They go bad rarley make sure your blade brake switch is not ingage killing spark
Posted on Jun 07, 2014
5 Suggested Answers
  • 110 Answers
SOURCE: It wont start. Fuels good.
If you have no sign of life with starter fluid, there's no spark in the cylinder.
If the plug is oily, it may spark in free air, but not under compression. Try a new plug first.
Excess oil won't prevent the engine from starting, but it will spew oil everywhere if it's overfilled. Just check the level with the dipstick (on level ground), and pour any excess out of the filler tube.
Posted on Aug 08, 2010
  • 130 Answers
SOURCE: Engine turns over, installed new fuel filter,
Not a whole lot of information here so I'll give it my best shot. Since you mentioned "both spark plugs" I'm assuming this is a riding lawnmower. I'm also assuming since you said "engine still will not fire" that there is no spark jumping the plug gap. There are several problems that can cause the symptom you have but I will address a common one and hope it helps. We are seeing problems in regards to the seat safety switches on some riders. Not necessarily the switch itself, but the connector that plugs into the switch. Some engineer has designed a "mini switch" inside the connector. It's purpose is to keep people from unplugging it and "jumping it out". If the connector is not plugged in securely or if the "mini switch" malfunctions, the mower thinks nobody is on the seat and "kills" the ignition to the spark plugs. Again, I hope this helps to some degree.
Posted on Feb 25, 2011
#1 Taper
  • 1040 Answers
SOURCE: 875 Series Engine-cleaned flywheel and
You should put it at .020
Are you sure you had spark before you took it apart? If you are not sure, then the Ignition Coil may have went bad. How did it act before you decided to take it apart?
Jim
Posted on Aug 20, 2011
Testimonial: "After I adjusted and put everything back together again it still didn't work and like you indictated it turned out to be a bad ignition coil. "
  • 6468 Answers
SOURCE: This mower will start but not smooth could armature magneto bee the problem???
check the valve adjustment if overhead valves
Posted on May 29, 2012
Im getting a crank/ no start situation on my 93 chevy astro ext 4.3Ltr v6 and ive never let a vehicle beat me b4 but this one is giving me a sound whoopin - pls help
Easiest way to trouble shoot a crank no start is to spray starting fluid into the air cleaner intake before you crank it. If it fires then dies it is a fuel problem. If it doesn't fire it is a spark problem. If it fires then dies, check the fuel pressure at the engine end of the fuel line. Pressure below spec prevents the injectors from working properly. See shop manual for the proper procedure.
If it doesn't fire put a spark tester at one of the plug wires set to the proper gap to measure the spark voltage being developed by the coil etc. Good luck.
Sep 22, 2015 | Cars & Trucks
if you have no spark check the contact between the flywheel magnet and mag and make sure they are clean and the gap is set ( old school the thickness of a cig. pack) if that doesn't do it check the wire and end for contact. Still no you probably need a new mag
Apr 19, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
How do I clean the fuel line to my MTD self propelled high wheel 5.5 HP tradesman Yardmachine? What should the spark plug gap be? how do i clean the air filter?
the fuel line if it is dirty you should just replace it you can get it at homedepot or ace hardware . your spark plugg gap should be the thickness of a match book . and the air filter should be replaced every year if you use it in a dusty environment maby every couple of months .
Jun 11, 2011 | Mtd 22" White Outdoor Self Propelled High...
Start and immediately stops
spark plug gap would be .030 and magnito gap would be .010. I would clean carberaor. Sounds like the main jet is plugged. Hope this helps you.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
MTD yardman chipper wont start get spark need manual
I am successful too at using the starting fluid in the carb or directly into the clinder. That is how I start my MTD 5.5hp chipper. My problem is I have to hold down the primer bulb to keep it running. If not, the engine will stall.
May 12, 2009 | Troy Bilt Walk Behind...
Little spark
check the gap on your plug. .030 is what it should be. also make sure that your
kill cable is working properly and not grounding the engine out.
the gap for you magneto should be set to .010 to .012
loosen up the magneto insert a standard business card or 3x5 card
then turn the flywheel so that the magnet on the flywheel pulls the magneto into it. then tight the magneto mounting screws down. try spark now. always use fresh gas. -no-water- if in doubt throw it out.
gas is BAD after only 30 days.
Apr 26, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
MTD Yardman push mower runs fine for awhile then cuts off.
Try buying a new plug first but if it continues then I would say that there is debris in the carb.
Apr 04, 2009 | Mtd 22" Yard Machine Push Mower
Will not start
Spark plug not fouled? Spark plug wire properly seated on spark plug? Sounds like there is rust on the rotating part that creates the spark (magneto?). Clean (lightly sand/clean with steelwool) and check the gap. Make sure the whole thing is bright metal. Then verify your getting a spark.
Mar 27, 2009 | Mtd Bronco Rear Tine Tiller
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
118 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
