Question about Vehicle Parts & Accessories
91 ford ranger 4 cylinder. One coil don't have fire
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 34 Answers
I am a dodge man not ford but as a test have you inverted the wires to the coil noing one side works if the same coil dosnt fire it probably be the coil if the oppaset dosnt fire i would guess it was in the wireing or a pick up just a thought good luck. also if it has a resestore? dodge hasballest kind of the same.
Posted on Apr 19, 2013
  • Cw toms Apr 19, 2013
    Thanks for the help but all that didn't work. But did find that the crank sensor was bad. It has dual pickups one for each coil pack. Will know later when part comes in if that fixed it.
  • Cw toms Apr 20, 2013
    Well new crank sensor didn't help. Checked the wires and found no breaks. So still only one coil firing. Help
Ford ranger 2.3 dual coil firing order
the cylinder # 1 is at front exhaust side
firing order 1342 front coil to left side(intake)
rear coil to right side (exhaust) check the numbers at the coils.
Mar 12, 2017 | Ford Cars & Trucks
Both coils do not fire on 1 and 4. Will start but only running on 2 cylinders. Could both coils be bad or should I look elsewhere?
Part 3 -How to Test the Ignition Module and Crank Sensor ...
easyautodiagnostics.com > Ford > 2.3L
Mar 1, 2012 - Spark plugs for cylinders #2 and #3 get spark at the exact same time. ...voltage -12 Volts) to both individual ignition coils within the coil pack. ... Ford Mustang or Ranger (or 2.3L Mazda B2300), this is what you'll need ... for this 'Switching Signal' at the coil pack... but you can also test this ... 1991, 1992, 1993.
How to Diagnose a Misfiring Cylinder (2.3L Ford Ranger ...
troubleshootmyvehicle.com > Ford > 2.3L
Apr 3, 2012 - Bad Fuel Injectors can cause a Misfire Condition. ... the ignition system on the 2.3L Ford Mustang or Ranger consists of 2 ignition coil packs, ...
2002 ranger misfire rough idle - Discussion on Topix
www.topix.com > Ford Ranger
Jul 27, 2007 - My truck is giving the code misfire in number 4 cyl. I replaced my spark plugs, Wires, Coil packs (both of them) and all my fuil ... three (3.0L v6) go bad, the fuel/air mixture gets messed up. Judged: 2. 2 ... My truck runs rough only at idle. ...code for ford ranger 2002, 2.3 5speed. truck runs like a champ but that ...
Extremely stumped! I need the best and brightest 1994 Ford ...
answers.edmunds.com > Edmunds Answers
Jan 31, 2016 | Cars & Trucks
Firing order for 2.3 91Ford Moter
See the picture for the wiring layout.
Nov 25, 2015 | Ford Cars & Trucks
I'm getting an orange spark on my 1983 ford ranger, 2.3 4 cylinder. Replaced the coil, the distributor cap looks brand new. This truck is excessively flooding and when it does crank, it won't...
yes it could,, if you don't have the correct spark,, the firing would be weaker also, check the wires themselves to the plugs, and also the rotor , just because the cap looks brand new doesn't mean that its not arching inside the cap,, allowing the contact to get a reduced spark, if you replaced the coil, then its after that in the electrical circuit,, which brings you back to the cap, rotor, and wires. normally 3 wires won't go bad all at once unless there is a heat problem where the wires are routed, so I would just replace the cap and rotor, and see how it runs after that .
Oct 04, 2011 | 1983 Ford Ranger
Im working on a ford ranger 2002 with the v6. i just need to see a pic of the piston order and the coil pack order. im getting codes for 4..5..6 missfire but im not sure witch ones they are
Cylinders 1,2 and 3 are the cylinders on the passenger side and cylinders 4,5 and 6 are the cylinders on the driver's side. They are numbered front to rear. The coil pack will have the cylinder numbers marked on the top of it. The actual firing order is 1-4-2-5-3-6
The top of your coil should look like this:
1 2 3
5 6 4
Your engine looks like this:
1 2 3
FRONT OF ENGINE
4 5 6
Apr 15, 2011 | 2002 Ford Ranger Regular Cab
NEED FIRING ORDER FOR 2004 FORD RAnger 3.0l
For the 3.0L
Firing Order:
1-4-2-5-3-6
Cylinders:
(back of vehicle)
3-------6
2-------5
1-------4
(front of vehicle)
Ignition Coil:
(back of vehicle)
3-----4
2-----6
1-----5
(front of vehicle)
Nov 29, 2009 | 2004 Ford Ranger
Where is the ignition module control located on 1996 ranger 2.3 e
It does not have an ignition control module. The PCM (powertrain control module) fires the coil pack based on signal it recieves from the crankshaft position sensor and the camshaft position sensor.
Apr 08, 2009 | 1996 Ford Ranger SuperCab
Vehicle Parts & Accessories Logo
99 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
