Question about Gigabyte Computers & Internet
I need a manual to download for a Gigabyte 81PE1000 motherboard. Also would like to know settings to boost speed and performance on the mobo. Thanks, Mack E.
  • 1 more comment
  • macke1959 Mar 11, 2009
    Hello Nic, the motherboard is a Gigabyte GA-81PE 1000 (Rev 1.0)Socketr 478 865 Pe
    That is the info on the receipt I got when I bought it on ebay in August 2008. The mobo is a good, solid, stable board. I m on the tag end of the phone line in the county, and on dial up. This board just runs too slow. I need to know how to change the settings on the board to make it run faster.
    Thanks very much, Mack.
  • macke1959 Mar 12, 2009
    HI Nic, thanks very much. The info is a big help. The manual is great.
  • Nicolas
    Nicolas May 11, 2010
    Hi Mac!
    There is 15 diferent mobos of that 81PE1000, you need to be more specifik on the modenumber.
    Or you can look for the manual yourself on Gigabytes site here:
  • 1,073 Answers
Hi again Mac!
Good, now i will give you the manual:)
And here is the support site for the mobo, you may need some drivers or so
To run it faster you may look in to some forums how to overclock the cpu and the gpu. There arent many settings you can do in the bios to get it faster, the speed is almost all about the hardware
Good luck M8!
Please dont forget to rate me
Posted on Mar 11, 2009
  • Nicolas
    Nicolas Mar 12, 2009
    Hi Macke!
    Anytime my friend:) glad that i could help you out M8!:)
My Dedicated Video Memory Is 64MB. How to i increase dedicated video memory.I Use gigabyte Motherboard
Hello here is the gigabyte homepage:
The manual can be found by, selecting the mainboard number.
The video memory can be changed in the bios settings, but can probably only be decreased to a lower setting.
I guess the 64 mb, is the max memory setting.
The solution is to add a better graphic card, on the mainboard for better performance.
A graphic card can be bought in a computer shop, or online.
You just have to know, what socket the mainboard has.
There is 2 different ones: AGP or PCI-E slot
Good luck
Mar 23, 2013 | Gigabyte Computers & Internet
Where is the sys_fan to put 2 coolers ?
Visit this page and download the manual there will be a picture of the mobo and all of the connections will be identified.
Jun 03, 2012 | Gigabyte Z68MAD2HB3 Intel Z68 LGA1155 MB...
A7V400-MX Motherboard: I have changed the processor on my mobo, and I wan...
Based on the user manual starting v.2 dated April 2004, this mobo uses a dip switch array to set your processor and bus speed.
You will need to set the correct processor speed based on manufacturer [AMD] description.
Visit this link and see page 23 to set the switches as needed for your new processor.
May 18, 2010 | ASUS A7V400-MX Motherboard
How much memory can I install using windows vista 32 on a gigabyte ga-8vm800m. I know on Xp is only 2 Gig
Usually the limit is 3.12GB in any 32-bit Windows OS. In-order to achieve full 4GB recognition you should install a 64-bit version. Here you can read some more information.
Feb 19, 2010 | Gigabyte Giga-Byte: GA-8VM800M-775...
Hi ive got a GA-8TRC410MNF-RH Gigabyte mobo from a packard bell IMEDIA MC 2559 PC The mobo's P/N : PB34316801 I got a new case for my son to build a PC for the first time and we got this mobo from ebay...
as far as the SATA prob is concerned your mobo supports sata 2 as per the weblink
Feb 14, 2010 | Gigabyte GA-6WMM7 Motherboard
Gigabyte sound driver for win vista
Windows Vista has default drivers for most builtin sound systems on the motherboard.
Have you tried going directly to and downloading the exact driver for your mobo?
Let me know, how you get on.
Mar 07, 2009 | Intel D915GAG Socket 775 Motherboard -...
That mobo uses DDR400 PC3200 memory and a 800MHz. Front Side Bus (FSB) P4 processor. You can download System Information for Windows (free) here:, or use a similar program to get the details of your machine. The Gigabyte website also has the manual for your mobo.
Make sure Hyper-Threading is enabled in the BIOS to take full advantage of the P4 proceessor
Jan 29, 2009 | Intel D845GVSR Motherboard
Yes you can. Any DDRII RAM can function at 1.8v.
Every memory module has profiles written into it, this allows it to function at various speeds and voltages, and 1.8v is the default voltage for DDRII.
Voltages above 1.8v are used for overclocking, to take full advantage of high speed DDRII memory you should manually set the voltage and frequency in your motherboards BIOS (accessed by pressing DEL or F1 during boot), if your motherboard does not have options to set these parameters manualy then your memory will function at the default speed and voltage
Hope this helps!
Oct 02, 2008 | Intel Motherboard
My computer restart
Goto -->My computer---->Properties---->Advanced tab ---> Click Startup and recovery button ----> uncheck the Automatically restart.
If any problem in ur computer this settings restart the computer.
Hope this will help you......
Aug 07, 2008 | Gigabyte Computers & Internet
Computers & Internet Logo
435 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
