Question about Hitachi 51SWX20B 51" Rear Projection Television
I have a 51in Toshiba that nees a protective screen.
Its the plexy glass. its not the actual screen that has a crack.
  • 111 Answers
The plexi glass if a "special formulation" and costs around $350 if available!. I would go to some repair shops and see if they have old junker sets (city dump) that you can get the screen and if you have to cut it to size.. Cheap fix...
please rate!
Posted on Mar 11, 2009
I need to replace the dust cover on my Hitachi 53SDX01B
the problem here is Hitachi usually if it still has it sells all three screens as a unit---expensive.
You may want to search with GOOGLE the internet as some companies sell replacement "protective" screen replacements.
I have even seen one time someone found a piece of plexi-glass and had it cut to the exact size and thickness for a replacement.
Mar 21, 2012 | Hitachi 53SDX01B 53" Rear Projection...
Where can I get a replacement plactic screen cover
This set has 3 screens---the outer one is really only for glare--clear plexigalss--no longer available from Sony.
Sony 4-070-602-01
SCREEN, FRESNEL Sony 4-064-343-11
SCREEN, LENTICULAR Sony 4-058-894-11
SCREEN, PROTECTION (CONTRAST)Outer one is (Contrast) the other two inner ones are showing as available and about 180 each.
You would have to either have someone dismantle or do it yourself---most of these sets you have to remove all three screens from the rear of the set---then remove the outer contrast one if it is scratched or cracked--
If you get it out and measure it: It is possible you may be able to find a company who can cut you a plexi-glass piece to replace it with--lots of work to do this and you have to use extreme care when you remove the two inner screens--easy to damage them---Usually the inner two are taped along all the edges to keep dust etc from getting between them and the front one is a short distance forward of them.
The front protective screen is really only there for glare and to protect the inner screens from damage---I have seen people who had a cracked outer one just dismantle and remove that one---put the others back and use the set that way---have to be careful as the inner screens are easy to scratch or damage with the outer one removed.
Also---I have seen several where someone removed the outer one and got a piece of plexi glass big enough to put on the outside of the front of the set---secured all around the edges with velcro--does not look as good as the original but prevents glare and protects the inner screens.
If this told you something you did not know or helped you rate this solution as I do this here for free.
SD TECH
Jan 03, 2010 | Sony KP-53V80 53" Rear Projection...
Where can i get the plexie glass cover for a toshiba 51hc85 and can i just use any plexie glass
The screen is available using part number: 23311065 for $52.58 plus shipping. This cost was from tritronicsinc.com (a Toshiba parts distributor.)
Dan
Oct 26, 2009 | Toshiba 43A10 43" Rear Projection...
Screen broken or cracked
you will need to call rca and order one from them
here is a customer service number you can call for more details on how to get the screen
877-794-7977
Dec 10, 2008 | RCA HD52W59 HDTV Projection Television
Broken protective plexiglass ...
it is not tecomended that you remove this especally around children. i say this but i personally have one like that but i have no children. the other reson is the screens are easy damaged and they are 250 to replace. You can get another front plexi these are known as the supersheild. or if you can find the right size plexi glass it might find another option. It can be watched but like i said it will just lead to more problems without plexi
Nov 02, 2008 | RCA HD52W59 HDTV Projection Television
How do I remove the outer protective screen on my Mitsubishi WS-55315?
There are trim pieces around the edges that can be removed by sliding a knife underneath and lightly prying. They should remove fairly easily, don't force them as they may break. Use the knife on the cabinet side and pry toward the center of the screen.
The tear on the inner screen may be best left as is.
lexan would be better than plexi as it is tougher, but try to get anti-glare if possible. Anti-glare plexi would be better than regular lexan.
Feb 17, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Panasonic HDTV 1080i Screen
Usualy Panasonic have 3 layers on the screen. From inside to outside is: fresnel, lenticular and protective. If only the one from outside is broken don't wory. It;s just protective and the film it's just a filter to improve the black level. You can use it like that but be carrefull because the lenticular it's not protected anymore and if you scrach it ... And do not try to clean it with anything else just dry rag.
Dec 10, 2007 | Draper Replacement Surface ONLY for...
Panasonic PT53wx53g Rear Projection TV screen cracked
You can try it, but through my experience, it just does not look good. You may not have a problem with it. Give it a shot. Good Luck.
Oct 15, 2007 | Panasonic PT-53TW53 53" Rear Projection...
My tv
if your tv has black borderaround screen protector it has to be replaced with original part..if not it can be replaced with plexi-glass, avail at local home improvment stores john
May 24, 2007 | RCA P52926 52" Rear Projection Television
Hitachi 51SWX20B 51" Rear Projection Television Logo
44 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
