Question about Minolta XG-A 35mm SLR Camera
Rewind knob stuck - Minolta XG-A 35mm SLR Camera
Rewind crank is loose on my Minolta XG 1 Film SLR
There is a spring in the bottom of the rewind knob that holds the crank, and it sounds like it has dislodged or the plastic rewind knob is cracked (try small amount of super glue for this). You can rewind the knob off the shaft (open the film door and put something in the rewind fork to keep the shaft from moving) and then turn the rewind knob opposite the direction of the arrow (if the arrow says turn clockwise, then turn counter clockwise). This will allow you to remove the rewind knob assembly and check it for damage, etc. Also, there is a small shaft at the end of the crank. Make sure it is not bent.
May 16, 2014 | Minolta Photography
I can't open the camera back on my Nikon FM3A 35mm SLR Camera. Is it because of the poor battery level?
The battery does not affect the back cover opening.
The back can be opened by lifting up on the film rewind knob but on this model, there is a lock. Lift the rewind knob and at the base of the rewind knob is lifted from, there is a safety lock. You have to move this safety lock and lift the film rewind knob at the same time to open back.
http://tinyurl.com/2u7wtt
has the instructions.
Jun 28, 2010 | Nikon FM3A 35mm SLR Camera
How do you change the film in a minolta x-370n?
push in the rewind button on the bottom of the camera. turn the rewind knob to the right until all the film is rewound into the film canister.
pull up on the rewind knob to open the back ( film ) door, remove canister. put new film into camera push rewind knob down and pull enough film to attach to the take up spool.
Dec 10, 2009 | Minolta X-370S 35mm SLR Camera
The nob that rewinds the film fell off my camera, and i unfortunately could not find it. Is there anyway to get the film out of the camera before I get a replacement piece?
yes, after dark find the darkest room or closet you can find, make sure no light is coming in around the door. pull up on the rewind shaft to open the back door. remove the film and rewind it into the canister by hand. turning to the right.
Oct 21, 2009 | Pentax K1000 35mm SLR Camera
How to load new film
push the rewind button on the bottom of the camera, then turn the rewind knob to the right to rewind any film that may be in the camera. Lift the rewind knob up to open the back door. remove the film canister if there.
on the new film canister pull enough film to reach the take up spool. attach the leader to the spool and close the back door, advance the film to counter number 1. enjoy.
Oct 07, 2009 | Minolta XG-A 35mm SLR Camera
How do I change film in my Minolta xg-a camera ?
first push in the rewind button on bottom of camera, then turn the rewind knob to the right to rewind any film that's in the camera. then pull up on the rewind knob to open the back cover.
Sep 30, 2009 | Minolta XG-A 35mm SLR Camera
Rewind button is stuck
It can definitely be fixed but let's try one thing before forking over few bucks to technician. Assuming it is a SLR camera, When you rewind, hold the rewind knob pushed in and try it. If you have a point and shoot, let me know which model. I'll be ready to assist when you respond either way.-James
Apr 04, 2009 | Olympus Photography
How do I rewind and take the film out of a pentax k1000?
mhamabrown,
push the rewind button on bottom of camera and turn rewind knob to the right, ( clock wise ) then pull the rewind knob up to open the film door.
Feb 24, 2009 | Pentax K1000 35mm SLR Camera
Rewind on my camera wont turn
Has the rewind knob become unscrewed or just won't turn? It does have to be turned clock-wise to rewind the film. If you would happen to turn it counter-clockwise, it would either jam or the knob itself would become undone from the rewind shaft.
Dec 25, 2007 | Photography
Minolta XG-A 35mm SLR Camera Logo
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
