Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
It wont start.. what is sata?
I have just got this new desktop computer and i just wonder.
is it normal for it not to start. and what is this red cable i got left called sata?. shall i use that for any purposes.. i know i have IDE cdrom but there is no IDE entrance on my HDD. any ideas what i shall do and if i shall use this red sata cable?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
You have to make sure first, what is your HDD type? is it IDE or SATA (Serial ATA).
Check it out: http://www.wisegeek.com/what-is-sata-or-serial-ata.htm
You should plug the data cable, to your hard disk. Remember, there's no way to plug your SATA cable to IDE HardDisk because the connector are not the same (I don't know if there's a converter between it).
So, make sure it first. If it IDE, find IDE data Cable, and make sure it plugged to your MainBoard and Hard Disk. Do the same procedure if it is SATA Hard Disk, only this time you should connect the SATA cable from your mainboard to your SATA Hard Disk.
Posted on Mar 11, 2009
Getting data off HDD from Caddy ?
I have had similiar issues using caddies there seems to be many connecting parts that can fail or become old and dirty failing to make contact with the hard drive you could remove the hard drive and check these contacts make sure they are clean and making contact
or
You could just remove the hard drive from the caddy and connect it directly inside your computer as a normal hard drive
or
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
http://www.bing.com/images/search?q=SATA+Power+Splitter&qpvt=SATA+Power+Splitter&FORM=IGRE
Once connected to another computer to a usb port and power supply you should get a message found new hardware and it should install the drivers it should show on your computer or you might have to install it manually
click start click on computer to open you should see this drive
If you dont.
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a Yellow Question / Exclamation Mark? ! or a Red X
you will need to update/reinstall drivers
right click to reinstall drivers.
If you can see your usb drive but its not working
ports (com&lpt) right click update driver
Once you see this drive just click on it to open and copy all or any data you want and save it to another usb drive
or get one of these
http://www.ebay.com.au/itm/NEW-2-5-SATA-USB-2-0-external-HDD-enclosure-case-AU-/221010079433?pt=LH_DefaultDomain_15&hash=item33753a2ec9
NEW!2.5" SATA TO USB 2.0 external HDD enclosure case AU
Hope this helps.
Nov 23, 2012 | Computers & Internet
My computer wont boot up
check your cables,your hard drive is not detecting
May 09, 2012 | Dell Inspiron 530 Desktop Computer...
My computer turns on but appears to say one thing for computer repair and also appears advisable to start normally. already loaded on both, not by anything. I wonder how to turn it
Go to start if you can boot up. And then select run...type in chkdsk in the run window and hit enter. You computer will scan your hard drives for missing files and/or damaged files and fix it for you. Let me know if this helps.
Jan 04, 2011 | Acer Aspire M1100-B1300A Refurbished AMD...
HP a6412p added 2nd hard drive but wont work get blue screen
you should try switching the sata port you plug your new drive into. also, you should go into your BIOS setup f2 and save setting then exit.
Jan 25, 2010 | HP Computers & Internet
I was wondering what DVDroms work with a hp micro towe. Mine didn't come with one and I was looking to buy one. It has a different cord then my other computers and I think its called a SATA? I don't know...
You need a standard Sata DVD RW drive, there is 2 blue , one red and one white connection for sata drives in the lower right hand side of the mainboard. Good luck!
Dec 28, 2009 | HP Compaq dx2300 Microtower - RT950UTABA...
My disc drive wont open, i tryed hitting it, prying, and even tearing off the front off my tower! any ideas?
in front of your cd rom disc drive you will see a very small hole, try to insert a small sharp object or pin that will fit in the hole, that is the bypass key to open the disk tray
Nov 14, 2009 | Gateway GT4016 Desktop PC
Computer wont start up!
try to replace the IDE/SATA cable connection..good luck
Jun 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
IS HD161HJ COMPATABLE WITH MS-6741
Be sure that SATA is enabled in your BIOS settings. Sometimes if the computer ships with an IDE drive, the company that builds them will disable SATA in the BIOS. Also, while you are in your BIOS, if you decide to use just the SATA drive, you need to disable your IDE and set the bios up to boot the computer from your new drive on the SATA connector.
Mar 27, 2009 | E-Machines eMachines Refurbished EMA...
Added new drive, cloned old want new drive to be pimary
Sata's don't really have a primary and secondary, they go by the port on the motherboard their connected to.
It starts from 0 and counts up, depending on how many sata ports u have.
0 is normally the main one that the computer boots from, and its normally a different colour than the others.
So basically u need to swap the ports that the 2 drives are plugged into on the mother board
Mar 20, 2009 | Sony VAIO Digital Studio PCV-RX755 PC...
Can a MSI MS-6330 Ver 2.1 Motherboard support a 250 Gb HDD?
Yes, It will although if you buy a new drive, make sure that it has support for IDE as this mobo does not have support for sata. If your wondering IDE cables are the flat ribbon like cables. Sata is smaller, about the size of an ethernet cable, usually red or black.
Dec 13, 2008 | MSI Computers & Internet
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
183 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
