Question about Duo Fast Duofast Cn325 Cn350 Nailer Oring Repair Parts Kit
Duo fast 350 leaks - Duo Fast Duofast Cn325 Cn350 Nailer Oring Repair Parts Kit
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: duo fast n 350 sets
On the very front of the tool just up from the contact part of the tool there should be a thumb wheel that will spin and adjust the depth of the nail.
You can also reduce the depth by turning down the air pressure to the gun...back the prssure down using the regulator on the compressor tank...
heatman101
Posted on Feb 21, 2011
H2_Brad
  • 425 Answers
SOURCE: what degree nails should be used for a duo fast Cn
The CN350 uses a 20 degree, full round head, plastic collated nails.
Posted on Jul 21, 2011
86 GMC sierra 5.7L 350..has a fast idle in neutral, and diesels when you turn it off..any suggestions?
Have the intake system checked for unmetered air entering the engine, causes of this are intake manifold vacuum leaks due to a faulty gasket and leaking engine vacuum hoses or a defective brake Vacuum booster
Aug 25, 2012 | Cars & Trucks
Duo fast leaking oil
putting to much oil into tool ( it just takes a few drops a day) or cap/ nose has loose screws
May 05, 2012 | Duo Fast Duofast Cn325 Cn350 Nailer Oring...
Repair duo fast nail gun
Duo-Fat is now owned by ITW which also owns Paslode. The DF350S is basically the same thing as the F-350S Paslode. Go to Duo-Fast's website to locate a servicing dealer nearest to you.
http://www.itwindfast.com/buy.cfm
Feb 16, 2012 | Duo Fast DuoFast DF350S 20? Round Head...
What degree nails should be used for a duo fast Cn 350 B nail gun?
Jul 21, 2011 | Duo Fast Duofast Cn350 Cn350b Sh Nailer O...
350 chev in ski boat idles to fast 850 rpm 22hg vac runs nice (could it be secondary throttle butterflys worn
Not very likely on the secondary plates being worn. I suggest that you look for any vacuum leaks, and primary throttle issues, like choke not coming fully off (fast idle).
Jan 25, 2011 | Holley 0 80552 650 Cfm Four Barrel...
I have a duo fast CN 350 nailer and it works ok but it don't seem to let the driver blade to come up high enough to get on nail head
You will need to pull the top off to get to it to check it out, If the drive pin is bolted on, make sure the bolt didn't loosen up, most are one piece, welded on, If you don't find anything in there preventing it from coming up, I would grind off the tip, nice and square and flat, then put it back together. I have a feeling you will find a piece of white plastic holding the piston down, part of the head there, It will need to be replaced. Check it out, hope this helps.
Dec 29, 2010 | Duo Fast Duofast Cn350 Cn350b Sh Nailer O...
High idle CHevy 350 TBI
check if went from a V6 TO V8 need power two more cylinders
Jun 20, 2009 | 1992 Chevrolet K1500
Duo Fast Duofast Cn325 Cn350 Nailer Oring Repair Parts Kit Logo
42 people viewed this question
Top Duo Fast Air Tools & Compressors Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
yoopertech
Are you a Duo Fast Air Tool and Compressor Expert? Answer questions, earn points and help others
