Question about Konica Minolta Bizhub C360 Copier/Printer/Scanner
L4 error on konica minolta c360 - Konica Minolta Bizhub C360 Copier/Printer/Scanner
osiriscompu
  • 16 Answers
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Posted on Jul 19, 2008
taminol
  • 62 Answers
SOURCE: Hi In our office Konica Minolta C250 ,it show message mulfunction. error:- c0206
C-0206 relates to tray 3.
With the copier turned on do the following
Open paper tray 3, remove paper, close tray, open then shut front door, load paper into tray 3 - hey presto!!
If the fault comes back you could have paper stuck behind the tray or have a defective lift up motor.
Regards
Taminol
Posted on May 27, 2009
  • 15 Answers
SOURCE: konica minolta bizhup 6501 error c-2452
Something with your developer causing not enough toner. Maybe an auger issue in the developer or in the toner feed itself?
Posted on Jun 17, 2009
  • 7 Answers
SOURCE: PRINTER TROUBLE CODE C-0210 KONICA MINOLTA
on previous models with this code check that there is no paper caught behind the tray open and close door to clear code
Posted on Mar 04, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
What is error code c5370
appears to be fan error from the rear of the printer. perhaps over heating or not spinning or very dirty
May 11, 2014 | Konica Minolta Bizhub C360...
Konica minolta bizhub c360 cannot stabilize color
what code is showing what do images look like????
Apr 17, 2014 | Konica Minolta Bizhub C360
Bizhub c360 error code 12
l-12 or p-12 code????????????????????????????
Feb 07, 2014 | Konica Minolta Bizhub C360
THE KONICA MINOLTA C360 COPIER SHOWS ERROR CODE C6103
• Scanner home sensor (PS201)
• Scanner motor (M201)
• Scanner relay board (REYB/SCAN)
• MFP board (MFPB)
Scanner is located under the big glass. reset open close right door
Jan 21, 2014 | Konica Minolta Office Equipment & Supplies
Can i repair a developer unit of the konica minolta C360, the parts are so expensive
yup , u can repair it if you have enough knowledge and resources of the parts...
Oct 12, 2013 | Konica Minolta Bizhub C360
I have changed the setting of the dev unit of the Konica minolta C360 to No life But it still says replace unit. The printer is still giving excellent prints
it continue to showing this error and u have to press ok
just make prints till print are coming ok
after that u have to change unit
Aug 06, 2013 | Konica Minolta Bizhub C360
An error on my c360 konica minolta c-3721
fuser temp too high to reset turn off machine then turn on while holding down the utility/counter button when the trouble reset button comes up on the touch screen touch it and make sure it says ok then turn the machine off wait 10 seconds and turn back on if error code comes back fuser unit will have to be replaced
Dec 11, 2012 | Konica Minolta Bizhub c203 Copier
Feb 11, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub C360 Copier/Printer/Scanner Logo
612 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
