Question about HP Color LaserJet 4550hdn Printer
50.1 fuser error hp 4700 - HP Color LaserJet 4550hdn Printer
  • 10 Answers
SOURCE: 50.1 fuser error on HP 8150 LaserJet Printer
wow if you were an hp certified tech you would know instantly that 50.1 is LVPS also if you were or were not certified you could look at serv man and figure it out right quick
Posted on Oct 22, 2008
no_pc-gst
  • 58 Answers
SOURCE: 50 .2 Fuser Error in
you need an maintenance kit 4100
ACC C8057A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8057-67901 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8058A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 220V, LJ 4100 LJ 4100 Series
Selected Item RG5-5069-000 See RG5-5069-090 Not Available 0
Alternate Item(s) RG5-5069-090 Fuser Film ***'y, 220V, LJ 4100 180.50 2 http://www2.printerworks.com/cgi-win/tpwall.exe/find?RG5-5069-000
HP LJ 4100 Fuserkit RG5-5069 HP
Posted on Dec 31, 2008
leroyal
  • 2120 Answers
SOURCE: HP Laserjet Printer 4700 Fuser Error
Try unplugging the printer for 30 mins. You may still have a defective fuser.
Posted on Mar 12, 2009
POCBM
  • 121 Answers
SOURCE: need to change out a fuser kit
1. Turn the printer off.
2. Open the top cover.
3. Grasp the purple handles on the fuser.
4. Remove the old fuser from the printer.
5. Install the new fuser.
6. Close the top cover.
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00366229/c00366229.pdf
Posted on Mar 20, 2009
SOURCE: HP 3505n message: 50.9 Fuser Error Fuser is
Please replace the fuser assembly.
Posted on Sep 27, 2010
Hello how to reset fuser in hp 4700 whitout
fusers include a tiny "fusable link" that "burns itself out" during the 1st power-on. Basically you must install a replacement fuser then turn on your printer, and the power-on process will automatically reset the page count for you.
Sep 18, 2013 | HP LaserJet 4700 Printer
I keep getting a "replace fuser kit" message on my
If you replaced with new fuser even getting same error, then check,
>Check the fuser connector (J5001). If
it is broken or damaged, replace it.
>. Check the connector (J1025) on the
DC controller PCB.
>. Replace the DC controller PCB.
Oct 07, 2011 | HP LaserJet 4700 Printer
In your best soulution for fixing the 59.30 error code on a hp 4700 printer it states to remove the duplex devise from the printer. what is the duplex device and where is it located
Duplex is here:
But 59.30 error (Fuser motor startup error/Black or N/A)
Follow next instructions:
Fuser motor error
1. Reconnect the connectors J4605 for the fuser motor and J1024 on the DC controller PCB.
2. Run the component test to verify that the fuser motor is working correctly.
3. Replace the fuser motor.
Aug 01, 2011 | HP LaserJet 4700 Printer
I have a 50.2 fuser erro on our Color Printer HP 4700
The 50.2 code on nearly all HP laser based machines including your 4700 means you have a fuser error. The fuser unit is the assembly that heats up and "fuses" the toner onto the paper. There are a few things you can try including, power cycle the printer and see whether the code resets or try reseating the Fuser Unit. Neither of these will resolve the issue in most cases. Most of the time fuser unit replacement is necessary.
Here is a link for you to see pricing and a picture for your fuser unit. You may want to just buy your own fuser and replace it if your are mechanically inclined. If not you can have a local printer repair shop replace it for you. At least they won't rip you off on the price of the fuser unit. Note that there may be some cheaper prices out there on this unit.
http://www.precisionroller.com/search.php?q=hp+4700+fuser
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 23, 2010 | HP Color LaserJet 4550hdn Printer
Fuser error 50.9 came up when we turned the printer on what does that mean??
normally this error means you have a bad fuser assembly. These items are normally a customer replaceable part. If replacing the fuser assembly does not correct the error code you may have a bad power supply board.
Sep 30, 2010 | HP LaserJet 4700 Printer
How to replace image fuser kit for hp laserjet 4700n
turn off the machine. open upper front cover. remove the old fuser and insert the new one. turn on the machine and enjoy your printer with new fuser kit.
Jan 20, 2010 | HP LaserJet 4700 Printer
Hp clj 4700n 59.30 error
The error stands for:
59.XY PRINTER ERROR
X is in your case 3 : FUSER MOTOR STARTUP ERROR.
Y is in your case 0 : NO COLOR
The service manual says:
1. Reconnect the connectors for the fuser motor and on the DC controller PCB. Replace any damged parts.
2. Replace the fuser drive assembly.
3. Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
Best regards,
mannu_rakesh
Aug 22, 2009 | HP LaserJet 4700 Printer
Need to change out a fuser kit
Mar 20, 2009 | HP LaserJet 4700 Printer
Mar 12, 2009 | HP LaserJet 4700 Printer
Hp color laserjet 4700dn error code 59.30
turn off the printer. remove the duplex device from the printer. turn on the printer. enter the diagnostic menu. enter the menu for sensor and motors. select the fuser motor and let it run. if you can hear it its ok (its not such a noicy one ... you have to listen very good) - follow up the next steps:
turn off the printer. turn on the printer. enter the service menu - pin code is: 09470005. set to 0 all counters for mono print, color print and the counter after service. leave the menu.
turn off the printer, reinstall the duplax device. turn on the printer.
result: the error msg is gone. its just HP wants to sell theyr service contracts.
Feb 25, 2009 | HP LaserJet 4700 Printer
HP Color LaserJet 4550hdn Printer Logo
49 people viewed this question
Seeker5211
Seeker5211
