Question about Kyocera FS1320D Laser Printer
Kyocera FS-1320D assign IP address - Kyocera FS1320D Laser Printer
leroyal
  • 2120 Answers
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Posted on Jan 23, 2009
biz_kid1
  • 107 Answers
SOURCE: Factory Defaults for Kyocera FS-1300D
Turn off the Dell printer (assuming you want to keep that IP address as is). From the computer/server the printers are networked to, go to Printers and Faxes and locate the printer. Right-click on the printer > Properties > and there should be a tab where you can change the IP address within...sorry I can't recall the exact steps from here as I don't have access to do so from my machine. Once you change the IP, reboot printer and your conflict should be resolved.
If all else failes, you'll need to consult the NIC card manual for further diorection.
Posted on Jan 28, 2009
SOURCE: CLEANING A KYOCERA FS-2000D
Follow the page http://www.fixya.com/support/t1336338-kyocera_fs2000_thin_black_vertical_line
Basically, you remove the cartridge and developer all at once, then remove the waste toner bottle, then push the grey tab in to release the drum cartridge (be very, very careful in removing and putting back in. Any scratches on the drum and you will enjoy black spots permanently on printouts).
On the right side of the grey charger section is a tab you can use to release it. Do this, then put the drum away in a light tight back to prevent damage to it.
The reason why this Kyocera printer doesn't have the primary charger wire cleaner is because it did away with it. It now charges via a black fuzzy looking roller on top which is like the secondary corona charger wire, which then applies it to a roller, which then applies it to the drum. I think this is nice since it should prevent printer quality problems better since there is nowhere for oxidation to really collect. But, OTOH, it does happen anyhow.
I cleaned mine off and the streaks disappeared. I used a non amonia based cleaner to help, since I didn't find any dust on it to begin with. Whatever you choose, do not get your fingers on it, or it will put oil onto the rollers and that will make it worse.
Worked for me.
Posted on May 25, 2009
  • 46 Answers
SOURCE: Printer KYOCERA FS-1030D not geting connected to my local Netwok.
I cannot remember the name of the utility but I know on the new drivers for the newer machine it is built into it it discovers the machine baised on its mac address and you can change / set the ip from there.Try some of the utilities from the kyocera support sitehttp://www.kyocerasupport.co.uk/index/download_center.html
Posted on Jun 11, 2009
xptareq2000
  • 1447 Answers
SOURCE: change drum kyocera fs-3900
open printer front cover and remove drum unite ,two side screw open two side spring **** two side open drum
if you are not possible it then buy a new one unite in your service authorized delar
Posted on Aug 27, 2009
Can this be set-up wireless, and if so how ?
no it can't however it should have a 10/100Base-TX ethernet port. You should be able to plug it into a Wireless Router and be able to access it via an ethernet ip network. However you would have to set the laser fs-1118mfp printer to an appropiate IP address and subnet mask and set the router to issue DCHP to Ip addresses outside the printer range of IP addresses. So for example 192.168.0.1 router 192.168.0.2 could be assigned to printer and DHCP leases assigned to 192.168.0.10 - 192.168.0.254 using a subnet mask of 255.255.255.0 for all the ip addresses. The router could communicate with laptops via wireless but each laptop would need the laptop operating system driver for the printer added and the ip address would be 192.168.0.2 for the printer. it could also be done on 10.0.0.whatever 10.0.0.1 router 10.0.0.2 printer 10.0.0.10 -10.0.0.254 DHCP server leases. If you have a ethernet network already you could just add a wireless access point to the network .
Oct 09, 2015 | Kyocera FS-1118MFP Laser Printer
Ip address for kyocera fs-1320d
Contact your IP Provider for the information you require
Mar 30, 2015 | Kyocera Mita Ecosys FS-1320D - 37 PPM...
I need to add an IP address to a Kocera 1320d that has been hooked up as a USB printer, how do i do this?
You can print a status page by pressing for 5 seconds the green button and see what IP address has the printer. Then you can modify it through your PC. The most important is that you have a NIC (network interfade card), because this printer (FS-1320D) comes from Kyocera without a NIC. Unless your printer is already intergrated with a NIC.
Aug 21, 2014 | Kyocera FS-1320D
How to set ip address for kyocera 1320d
Print a Status Page by pressing the green button for about 5 secs. Check the IP Address on the Status Page. If the IP Address is similar to your local network, you type that IP Address in an internet browser to open the Command Center (web interface).
If it is not similar, then you can change PC's IP to be similar to printer and via the command center, you change the printer's IP to a desired IP (similar to your local network) and restore then the IP of the PC to the one before.
How do I install a new genuine kyocera developer unit (dv-172) in a Kyocera Y FS-1320D?
1-5-4 Developing section
(1) Detaching and refitting the developing unit
Procedure
1. Open the top cover.
2. Open the front cover.
3. Remove the developing unit (with toner container).
4. Check or replace the developing unit and
refit all the removed parts.
5. When the developing unit is replaced with a
new one, carry out the following procedure.
6. Perform toner install mode in the service
mode (see page 1-3-12).
May 26, 2014 | Kyocera Office Equipment & Supplies
Change ip address
You cannot change the ip address, if you are using static ip address.If it is dynamic ip address, you can change it easily by resetting the modem or switching it off and on.you can also use Proxy server or Hide ip address software to change the ip address.
To check the ip address before and after changing, Visit the Ip-details.com . Here you can search IP,domain host and it also includes city, country, global latitude & longitude coordinates etc.
Nov 04, 2013 | Kyocera Mita Ecosys FS-C5100DN -23 PPM...
How to check printer ip address
go to menu interface- option-netware-tcp/ip on - dhcp -ip address
Mar 08, 2012 | Kyocera Mita FS-1920 Laser Printer
May 16, 2009 | Kyocera FS-1030DN Printers
KM 3060 Scan Error 2101
Hi Guys,
I was getting the 2101 error as well. I resolved this by placing the IP address of the computer into the "host name" field. Only thing to remember is that your IP address will change from time to time. You will need to assign a static IP to that particular machine or give it a reserved IP address through your switch. Good luck!
Oct 14, 2008 | Kyocera Mita FS 3800 Laser Printer
Kyocera FS1320D Laser Printer Logo
140 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
