Question about Panasonic TCL47E50
Panasonic TCL47E50 lcd tv will not come on
Wont do anything and the fuse is good
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
My Panasonic TC-32LX85 LCD TV powers on but then clicks of and on repeatedly?
The main power regulator board to your TV should be checked. In most cases, it need replacement.
Feb 05, 2013 | Panasonic TC-32LX85 LCD TV
I have an LG 42LD520-UA and it doesnt do anything no lights nothing just wont turn on
AC out is good? Otherwise check the main AC fuse on the power supply module, see picture here:
http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sjeay60990201.jpg
The fuse is located on the top right (white cylinder with red band), the fuse is soldered in.
Parts for your TV;
http://www.shopjimmy.com/catalogsearch/result/?q=LG+42LD520-UA
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Sep 14, 2011 | LG 42LD520 42 in. HD-Ready LCD TV
My Panasonic Model: THL32U20A will not respond. You can turn it on manually (not by remote) and once turned on, nothing works, IE: remote doesnt do anything and you cant even change channels or volume etc...
I too have exactly the same fault. The Tv even turns itself on in the middle of the night, i have to unpug it from the wall. It has been in for repair 3 times now, one guy said there is nothing wrong with it. I am keen to hear if anyone has had this fault resolved.
Thanks
Darren
Mar 13, 2011 | Panasonic TH32LRU20 32 in LCD TV
Disassembled tv. found inline fuse to have no continuity.no power to tv. power source good.
If the fuse show no continuity as you indicate, that means the fuse is open. Does it have sugn of blakened inside the fuse? You need to check the bridge rectifier, the MOSFETs' and anything else for shorted circuits. Did you try new fuse yet?
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Please post back what you find.
Jan 04, 2011 | Philips Magnavox 42MF521D/37 Television
Can't get my Panasonic LCD out of Standby.
I only have two solutions. Either, turn the tv on from the tv. or try checking the tv connection. If that doesnt work maybe the remote is out of battery.
Sep 14, 2009 | Televison & Video
TV WONT TURN ON
Got it fixed. Removed back off tv and found the fuse right where the cord enters. Removed fuse[didn't look like it was blown] and got new one from radio shack, installed and now the tv works. That was all it was. Thanks again
Apr 05, 2009 | Panasonic CT-32SL14 32" TV
Lightning affected Lcd tv
Panasonic 32"LCD Mod,TX32LXD70A
Jan 02, 2009 | Panasonic Televison & Video
Panasonic TCL47E50 Logo
62 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
