Question about Mustek MCS 500 A3 Pro colour scanner
Failed to capture image - Mustek MCS 500 A3 Pro colour scanner
Cannon t3 comes on but will not capture picture
Hi. I would need some more info re your problem but for a start, you say the camera turns on but is there enough charge in the battery to operate the auto focus and the shutter/aperture?
If this is ok, is the memory card full? if so move or delete images from it and re-install it ensuring to insert it properly so you don't damage the camera or the card.If this is now ok and the camera does not capture an image check if the auto/manual switch on the lens barrell is set to "manual" if it is, switch it to "auto" and try to capture an image.
Try what I have suggested and be sure to reply whether the outcome is a success of has failed to solve the problem.
Apr 24, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
Software that allows the user to "capture" or copy a section of what appears on the screen
If you just want to capture a still image of what is on your computer screen, you can use a free image editing program like IRFANVIEW.
You can download this free program at the following link:
http://download.cnet.com/IrfanView/?tag=mncol;1
Just click on the underlined text above to get to the download page and then click on the green DOWNLOAD NOW button in the upper left hand corner.
Then follow the onscreen instructions to install this program on your computer.
Once the IRFANVIEW program is installed, start it up and click on the OPTIONS menu at the top of the screen.
Scroll down and select the CAPTURE/SCREENSHOT option.
For CAPTURE AREA, select the #5 option - CUSTOM RECTANGLE / REGION CAPTURE.
Now just click on the START button at the bottom of that screen.
This will start your screen capture. First place the mouse arrow in one corner of the screen image you wish to capture. Now just hold down your left mouse button and move the pointer to create a rectangular capture area around that image.
When you have enclosed the area of the screen image you wish to capture just click the left mouse button once. This will capture that area as an image which is now ready to save as a separate file.
Now click on the FILE option at the top of the screen and scroll down to the SAVE AS option in that list.
Choose a file name for the captured image and a location on your computer to save that file.
That's it. You have just captured and saved a screenshot image which you can open with any image viewing software. Just repeat the process to capture additional screen images.
Thank you for using FIXYA.
Good luck and take care.
Joe.
Jul 23, 2013 | Computers & Internet
N73 nokia, i have problem in take of the image capturing , in the image capturing mode doesn't key accept for image capture but it has work for video capturing. so plz help me what i do?
Generally the image capturing button should press 1-3 secs to get a picture.If it doesn't works there might be some hardware problem.But first try to Restore the phone by typing *#7780# and capture.If the problem still persist contact mobile repairing shop. The camera switch may damage .Or at least clean the pcb if you can remove the cover ..Thanks for visiting fixya
Mar 18, 2012 | Nokia N73 Cellular Phone
Hi, the view finder and lcd display on my Samsung SDC-103 gives a fuzzy black and white partial image only. This is all that comes out when I record - though I can playback fine. It's been like it for...
The CCD image sensor of the camera has failed. It is the component responsible for capturing the image the camera is focussed on, display it on the screen and capture it. If its malfunctioning you are bound to see problems like these. Getting the imagesensor replaced should resolve the problem
Jun 16, 2011 | Cameras
My lenovo easy capture camera is not work when i start it the error shown creation of the video preview failed please check the device connection and make sure that the device is not being another...
my lenovo esaycapture your problem is capture image in video the image is down, example yesterday my nephews use program image down, what is the problem and resolve it. Thanks for your help.
Jan 09, 2011 | Lenovo 3000V200 Laptop
Blank display on my camera
6280 me operation failed aaraha he
Apr 12, 2010 | Cameras
Unable to capture images
This is a failing component in the camera Contact HP customer support for a replacement or trade in
Sep 03, 2006 | HP Photosmart E317 Digital Camera
NEF Image will not open - Macintosh
RAW NEF images from Nikon cameras are proprietary formatted raw data directly from the cameras's sensor. If the images are improperly transferred to the computer they will not be able to be opened and will give an "Unsupported File Format" warning. Macintosh OS X has an "Image Capture" application (found in: Hard Drive/Applications/)that can be used to transfer images. If "Image Capture" is used NEF files will be corrupted and will not be able to be read. Only Nikon View, or manually dragging images from the mounted card, should be used to transfer NEF's. To disable "Image Capture": Double-click to open the hard drive and then the "Applications" folder Double-click "Image Capture" From the "Image Capture" menu choose "Preferences..." In the "When a camera is connected" pop-up choose "No Application" Close the Preferences window and Quit Image Capture After disabling Image Capture, it will not launch when the camera is connected and you can use Nikon View to properly transfer NEF images.
Aug 30, 2005 | Nikon Coolpix 5000 Digital Camera
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Mustek MCS 500 A3 Pro colour scanner Logo
32 people viewed this question
Top Mustek Office Equipment & Supplies Experts
Tony
Mike
Are you a Mustek Office Equipment and Supply Expert? Answer questions, earn points and help others
