Question about Samsung Sam4s ER-5200M Cash Register WITH PROGRAMMING 1-800 SUPPORT FRRE SHIPPING
Over limit error - Samsung Sam4s ER-5200M Cash Register WITH PROGRAMMING 1-800 SUPPORT FRRE SHIPPING
Tajima embroidery machine
Hello, Error 225 Travel outside the set embroidery area
( When the software frame limit is set, or
on cap machines) Here is website for all the errors:
May 17, 2014 | Sewing Machines
E66 Error
Hello samanthaway - Error code E66 indicates that the thermal limiter circuit is open. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the inlet or outlet thermal limiter for continuity. If the thermal limiter is open, tech will need to check for evidence of high temperature event and any resulting damage. If no further damage is evident, the thermal limited and retest will need to be replaced.
Dec 06, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Super...
Error code e66
Hello wez1330 - Error code E66 indicates that the thermal limiter circuit is open. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the inlet or outlet thermal limiter for continuity. If the thermal limiter is open, tech will need to check for evidence of high temperature event and any resulting damage. If no futher damage is evident, the thermal limited and retest will need to be replaced.
Sep 29, 2012 | Electrolux Frigidaire Affinity 5.8 cu. ft....
Error: dependent limit
Dependent limit error may occur if a limit of integration is dependent on the integration variable.
For example, integral:
int(x^2,x,1,x) is not allowed
Sep 06, 2012 | Texas Instruments TI-89 Calculator
Error Code E65 on Frigidaire Front Loader Model #LTF2940ESO
Thermostat issue - need a professional to complete the following:
For electric model, check inlet thermal limiter for continuity. If thermal limiter is open, check for evidence of high temperature event and any resulting damage. If no further damage is evident, replace thermal limiter. If no problems are found with the thermal limiter, check exhaust vent system for air blockages. If no problems with vent restrictions, check/replace high limit thermostat, and retest.
Aug 15, 2012 | Frigidaire Washing Machines
Have a gmp125-4 furance blower runs all the time checked themostat wires error code 1 blink then 2 then 3 then 5 furance works if you turn power off turn back on when heat kickes off blower comes on gives...
Sounds like limit switch issue. Furnace heats up, high temp limit switch opens, fan will stay on. GMP model is older and do not have the codes.
May be over fired, have airflow problem, to cause the limit to open.
Next time before shutting off power, try to find the limit, it has two wires that connect to a 1.5 x 2 inch card mount to the furnace fire wall. tap on it and see if the blower stops. If so replace the limit.
Sep 06, 2011 | Goodman Heating & Cooling
My sharp xea203 is showing over limit how do i clear this message and why does it happen
hello ,
error is about overflow limitation error.
make a registration within a limit of entry
Jan 31, 2011 | Sharp XE-A402 Electronic Cash Register
Open tray error
There is a limit switch inside your disc drive. It's either not making the limit, or you have a bad limit switch.
Sep 29, 2009 | Microsoft Xbox 360 Console
IError Code C13FO on konica minolta Di1610
C13F0 - Laser error
The laser output exceeds the upper limit value.
The laser output remains lower than the lower limit value.
Feb 25, 2009 | Konica Minolta Di1610 Copier
Samsung Sam4s ER-5200M Cash Register WITH PROGRAMMING 1-800 SUPPORT FRRE SHIPPING Logo
63 people viewed this question
Top Samsung Retail Supplies Experts
Patrick Tinashe...
ray gallant
Electroboy
Electroboy
Are you a Samsung Retail Supply Expert? Answer questions, earn points and help others
