Question about Microsoft Windows 98 Second Edition for PC
Disabling users from changing system time & date?
I am trying to figure out how I can stop users from changing the date and time one one system in Win98 second edition.
I have read that you can go into command.com in hex editor but I dont know how to get into hex editor.
Need help on this as im at wits end.
Thanks in advance
  • Emma J
    Emma J Mar 11, 2009
    Thanks for the quick responce. I cant seem to be able to see Administrative tools in the control panel, I have even tried to search for them. Im guessing maybe this has been disabled maybe Im not sure. And yes I am a admin, its actually a works computer where people log in and out using a computer based program, but some of the users are changing the times if there late. And this is becoming a bit of hassle when it comes to wages. Anything else you can suggest??
    Sergeant:
  • 219 Answers
If you're the administrator you should be able to set user permissions through the control panel. I had a Windows 2000 which had some features comparable to a 98. Most likely you will have to enter the category known as, "Administrative Tools" located within the, "Control Panel."
In this region you can change security policies, overall computer settings, and user settings (At least that's how it was on my 2000). I don't know which option you need to change to disable non-administrative users from changing time, however playing around with some of the settings might help you figure out which one it is.
NOTE: Make sure you don't change any of the settings for administrative users! If you do you might not be able to access the control panel or change administrative settings in the future.
Since I'm uncertain about this working with a 98, contact me again later notifying me if the above worked or not. I'll see if I can help you resolve this.
Posted on Mar 11, 2009
  • Peter Steiert
    Peter Steiert Mar 11, 2009
    This certainly is strange. I wish our family had kept that old 98 of ours. We got rid of it when a hardware virus ate all the source files of the hard-drive.
    You can try to check the user accounts. This should be found in the Control Panel once again and should be named, "Users." I'm not certain if it will let you, however you might be able to change permissions for Administrators, users, moderators, Power Users, etc... If not then I'm out of ideas. Might be time to upgrade the systems. I know building them yourself can give you a half-decent machine, the only problem comes at installing the Operating System as right now Windows XP is expensive (in high demand) and Windows Vista is an immense pain.
    Let me know if you find anything in the user portion of the control panel. If you don't find anything and you are considering getting a new computer (or computers) I can e-mail you some estimates. They would definitely be cheaper than if you bought them from dell or at a store.
Avaya phone 5410 how can I manually change time
The IPO should get its time from the VM Pro server. The time server should be
set to the IP address if the VM Pro pc. If there isnt a vmpro pc, you can set
it manually.
http://mfurrer.dyndns.org/?p=224
For IP Office systems without access to a time server, a number of methods to
manually set the system time exist. These are available in the IP Office 4.1+.
The following method is only supported on these phones: 2410, 2420, 4412, 4424,
4612, 4624, 4610, 4620, 4621, 5410, 5420, 5610, 5620, 5621, 6412, 6424. It is
supported on any analog, T3, T3 IP or wireless (IP DECT, 3600, 3700 Series)
phones.
Note: If the IP Office system that is still configured for automatic time
updates (on by default), any manually set time and date will be overridden on
the next automatic update. The use of automatic updates can be disabled by
setting the System ' System ' Time Server IP Address to 0.0.0.1.
Enabling a User Button for Time and Date
Select the user who can adjust the system time and date.
If necessary create a new user who can be used to log in and set the
time and date before logging out.
On the User ' Telephony tab, ensure that the option System Phone is
selected.
On the User ' Button Programming tab select and double-click on an available
button.
Select Emulation > Self-Administer as the action.
In the Action Data field enter 2.
Enter an appropriate label for the button.
Adding another button set to the Emulation > Time of Day action is
recommended as this will allow the user to view and confirm the systems current
time.
In the User tab, Change System Phone Rights to "Level2"
Send the updated configuration to the IP Office.
Using the Programmable Button
Press the programmed button. If the user has a Login Code enter it as
requested, and press Done
The options Date and Time are displayed.
To set the date press Date.
The current system date is displayed.
Enter the new date, using two digits for day and month. Use the * or #
keys to insert the / separators. The format for date enter matches the locale of
the IP Office system.
During entry the key labeled <<< can be used to backspace.
When the full date has been entered as required, press Next.
Press Done.
The phone will return to idle.
To set the time press Time.
The current system time is displayed.
Enter the new time using 24-hour clock format. Use the * or # keys to
insert the : separator.
When the full time has been entered as required, press Done.
Nov 05, 2012 | Avaya IP Office 5410 Terminal - New
Date & Time Problem
First, you need to have administrative rights to change date and time.
Check whether you are part of admin group or not. To check click on start and click on run, type "control userpasswords2" and hit enter. It will display user information, make sure you are part of administrators group. If not, try logging from administrator and run the same command
"control userpasswords2" and click on your user name and click on properties, go to to group membership tab and select others and then select administrators. This will make you part of administrators group. If this doesnt solves you problem try the CMOS Settings.
Try changing the date & time from CMOS settings. To go to CMOS Setup, restart the system and there will be options highlited to go to setup.. ( eg press F10 Steup ) and play around only date and time setup. Rest if not known to you, do not change anything.
May 15, 2010 | Microsoft Windows XP Professional
Program date and time on the microlife bp monitor
http://www.microlifeusa.com/files/manual/files/MLU3MQ1-IB.pdf
4.3. Setting the date and time
With the unit OFF, press the Time/Date button on the side of the monitor and hold for
three seconds until you see the icon start flashing in the upper left corner of the
monitor screen. The Memory button becomes your scroll button and the
Time/Date button moves you to the next time, date or user.
When the User icon is flashing, you can toggle between User 1 and
User 2 by pressing the M (Memory button). If you press the M
(Memory button) one time and the User changes to User 2, you can
press the Time/Date button to set your unit on User 2 or you can press
the M (Memory button) again to go back to User 1. Either way you
must press the Time/Date button on the side of the monitor to confirm
the setting and move on. The unit will automatically move on to the
Time/Date settings. If you don’t want to change the Time and Date
then just keep pressing the Time/Date button six times until nothing is
flashing on the monitor screen.
If you want to change the Date and Time, then press the Time/Date button once the correct
User is flashing on the screen so you can move on to set the correct year.
The unit will automatically move to the Year setting after the User has been set. To
change the year, press the M (Memory button) to scroll forward. Please note: You cannot
Time/Date button
on left side of
monitor.
scroll back so scroll slowly so you don’t miss the correct year. If you do pass the correct year
the unit will scroll all the way to 2050, then start again at the year 2000. Once you select the
correct year, press the Time/Date button to set it and move on to set the correct month.
Then the Month will begin flashing. Again, use the M (Memory button) to select the correct
month and press the Time/Date button to set it and move on to the day setting.
After you set the month, the Day will begin flashing. Again, use the M (Memory button) to
select the correct day and press the Time/Date button to set it and move on to the hour setting.
After you set the day, the Time hour will begin flashing. Again, use the M (Memory button) to
select the correct hour according to AM or PM and press the Time/Date button to set it and
move on to the minutes.
The last setting is the Time Minutes. The minutes will be flashing. Again, use the M (Memory
button) to select the correct minutes and press the Time/Date button to set it and complete
your setting.
Please NOTE: You can cancel out of setting the User/Time/Date by pressing the Start/Stop
button. If no operation occurs during the User/Time/Date setting process, the unit will automatically
cancel out of it. To re-initiate the setting process, press and hold the Time/Date button
for three seconds until the User icon begins flashing. Start the procedure all over again or
press the Time/Date button again and again until you reach the desired location to reset.
Jun 08, 2009 | Microlife 3MQ1 Blood Pressure Monitor
Certificate problem
Please check your clock on your machine to see what the date and time if it is correctly configured.
You might also be using a third party software that is conflicting with SSL secured websites. Try uninstalling or disabling the latest software that you might have kept may be that could be the cause.
Please do vote for me if you liked my solution.
Thanks
May 25, 2009 | Computers & Internet
Disabling the adjustments of Date & time??
Hi there.
This is the best i can remember about Win98
In Win98, rename the timedate.cpl to _timedate.cpl from your system folder and open command.com in a hex editor and go to the location that is on or around 0x010b36. there you will see a table of DOS commands.
simply rename "time" (and/or "date") to something else (as long as it's exactly 4 characters long!). then bring up a new DOS window and you will see that it only accepts your new command for changing the time and date.
This method, in combination with (renaming timedate.cpl), and
making sure that your BIOS settings are password protected, should prevent virtually anyone who is a non-guru from changing the system time.
Good luck and thanks for using FixYa!!
Mar 04, 2009 | Microsoft Windows 98 Second Edition for PC
Remove secure mode in Windows Vista Ultimate
Note: Disabling UAC will lead to a less secure system, so do it at your own risk.
here is how you can do it.
Open up Control Panel, and type in "UAC" into the search box. You'll see a link for "Turn User Account Control (UAC) on or off":
On the next screen you should uncheck the box for "Use User Account Control (UAC)", and then click on the OK button
You'll need to reboot your computer before the changes take effect, but you should be all done with annoying prompts.
Feb 07, 2009 | Microsoft Windows Vista Ultimate Edition
Changing to correct date on camcorder
To change / reset date and time touch on lcd screen, HOME > SETTINGS > CLOCK / LANG > CLOCK SET and set the date and time.
Above said is mentioned in user manual of DCR-SR42 and you can download it from Sony Support.
Dec 03, 2008 | Sony Handycam DCR-SR42 Camcorder
Cannot change pc's date and time
plz scan your pc for viruses by disabling the system restore
Apr 30, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Date/time change
Press program
then 0
(this will then display current date and time - overtype as follows)
eg. for Friday 2nd November 2007 8:58 am you type the following
071102 (date backwards) [space] 5 (Friday is 5th day of week) [space] 0858 (time) [space] 0 (0 is am, 1 is pm)
Press the store button and then program button to exit the programming.
Oct 30, 2007 | Panasonic KX-T7730 Corded Phone
Microsoft Windows 98 Second Edition for PC Logo
80 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
