Question about Lands Phones
Setting the time on DCS Falcon phone
Cant reset the time now that it is spring and we are an hour off on our clock
  • 240 Answers
The clock signal coming from real time clock crystal to the universal energy management system would have failed. so only you are facing this prob
Posted on Mar 11, 2009
How to reset the clock?
Hello Ruth Anderson,
All mechanical... clocks (even quartz) should only ever be ADVANCED... In the springtime simply advance the clock and HOUR. In the FALL pull the plug, stop the pendulum...
QUARTZ WATCHES... Pull the winder stem out FULLY
(this removes battery...
Wait an HOUR... Plug the clocks back in... restart the pendulum
or push in the STEM on your QUARTZ WATCH...
(this restores power (and keeps the CROWN from coming unscrewed from the "winder-stem")).
Never turn the clocks backwards...
Modern clocks probably don't ACTUALLT MATTER
but antique clocks and timers can be UTTERLY RUINED
(It's just a good rule... & water RESISTANT seals happy).
Relative to the clock-face...
"FALL BACK - SPRING FORWARD"
SPRING = FORWARD ... advance the hands an hour.
Technically "time change" only ever occurs between
1am and 2am during each time zones respective hours...!!
Even on QUART
Hope this helps!
Nov 10, 2016 | Audio Players & Recorders
To reset the time on our UP2 central heating programmer to winter time I've bach one hour
Spring ahead fall behind. Fall set clock back one hour.
Hope this helps?
Oct 31, 2016 | Heating & Cooling
I cant change the time on my adamant verizon cell phone
Go to Settings and Tools. Select Phone Settings. Select Network Mode. Select Global.
Then go back to phone settings and the option to set the time and date will appear.
I reset my clock this way and it worked. I hope it works for you.
Nov 09, 2012 | ZTE Adamant - Black verizon Cell Phone...
How do I reset clock?
Press the Transfer key
Prompt: ENTER PGM ID: Enter 200
Prompt: PASSCODE: Enter 1234
Display shows: DISABLE
Press 1 to change to ENABLE
Press the Speaker key
Enter 505
Current Date/Time shows in the format: WMMDDYY:HHMM
W=Week day where 1 = Monday, 2 = Tuesday etc.
HH = Hour in military format
Enter a new Date/Time in the same format. noce the last digit is pressed it will automatically save.
For example: 3102908:1645 is what you would enter for Wednesday, October 29th, 2008 @4:45pm.
Press the Transfer key to exit.
Nov 02, 2009 | Samsung DCS 12 Corded Phone
I cant get the clock to hold the correct time . Every time i set the clock it goes back in time 2 hours after awhile
Have you tried using the reset hole under (use pin) and setting again? Also after setting you have to press the mode button again to go back into normal mode.If that fails it's probably broken.
Jun 29, 2009 | Oregon Scientific OR-RM313PA ExactSet...
I need to reset the time on my phone. Not quite sure how I do this. I can set the day, but not able to change the time.
Press "clock" and hold for a few seconds.It will say the day. If the day is wrong, use the arrow keys to move either forward or backword through the week. When the day is set press "clock" again and you will hear the hour. Press the arrow keys to move the hours. Press again for the minutes and use the arrow keys to set the minutes. Last press "clock" again and set AM or PM. By the way, the manual does not tell you how to set the clock.
Fame !
Jun 26, 2009 | Uniden Cordless Phone
Clock setting on alpine iva-w200
Copied from Alpine-usa.com support page:
Setting item: CLOCK ADJUST
Further setting items : HOUR / MINUTE / TIME ADJUST
Setting content: 1-12 / 0-59 / RESET
The clock-adjusting mode is canceled when the power is turned off,
when [RETURN] or [CONTROL] is touched.
Setting item: DAYLIGHT SAVING TIME
Setting content: OFF / ON
Setting the Time
HOUR: Adjust the hour.
MINUTE: Adjust the minute.
RESET: If the clock shows less than 30 minutes past, the
minute will be “: 0”; more than 30, the hour
advances.
Setting Daylight Saving Time
ON: Place the Summer Time mode ON. The time advances by
one hour.
OFF: Return to the ordinary time.
Aug 19, 2008 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
Cant set date/time on model#exi4560vuniden phone
Nov 26, 2007 | Uniden EXAI 7980 Cordless Phone
DCS reset
Push the reset button on the back of the camera
Oct 05, 2007 | D-Link Express DCS-900 Network Camera
Settings
http://www.sanyoservice.com/pdf/images/DCS-C60%20(OM).pdf Its not the same model, but should be the same adjustments.
Oct 29, 2006 | Fisher DCS-S450 CD Shelf System
Lands Phones Logo
76 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
