Question about Panasonic TH-L32C20X 32 inch Multi-System LCD TV
Mainboard pricePanasonic TH-L32C20X 32 Inch Multi-System LCD TV
How to buy mainboard Panasonic TH-L32C20X 32 inch Multi-System LCD TV
  • 29 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
Possible DRY Joints on the power board. Needs either an engineer or someone who knows how to check it.
Posted on Dec 12, 2008
eagle338
  • 4889 Answers
SOURCE: my panasonic 32 lcd tv tc-32lx60 will not turn off
Really sorry abou that. Here's the transcript.
http://www.fixya.com/support/c36637
I have been posting responses all the way through. But you were not able to see them, possibly due to some kind of bug
Posted on Mar 18, 2009
SOURCE: Panasonic 32 inch LCD TV reset
Here's a possible solution. I have a TC32LX7 and forgot my password. I tried the service mode access method for my 27" Toshiba SDTV. It worked. Remember, the entire set is put
back to the factory settings. All you do is:
1> Turn on the set.
2> Turn the volume level to zero.
3> Press and hold the "Down Volume" button on the TV.
(Do not release the button)
4> Wait 1 sec
5> Press and hold the Menu button on the Remote Control
(Make sure the remote is pointing at the TV's sensor)
6> Keep holding both buttons until the TV goes into System
Check mode. (When it does, Release the buttons)
7> If it works:
a) A message should popup telling you the system is
being checked, do not power off ...
b) Then that message will go away and the screen will
simple have some result codes showing.
8> If something like step 7 happened, Press and hold the
"Power" button on the TV until it shuts off. When you
turn it on again it will think it is the first power up.
(bang no passcode) - The End - Stop Reading.
9> If step 7 did not happen, try steps 1-6 again.
10> If step 9 did not work...Oh well then I guess the
software reset method was changed.
Posted on May 02, 2009
  • 1274 Answers
SOURCE: vertical line
replace the vertical ic chip
Posted on Feb 14, 2010
  • 8 Answers
SOURCE: we have a panasonic 32"inch lcd tv.we want to
hdmi Ports Qty 3 port(s) PC Interface VGA (HD-15) HDCP Compatible Yes
I read your tv has 3 hdmi ports and a PC input.
if your pc has hdmi out - the you use a hdmi cable from the pc to the tv on one of the hdmi inputs.
if your pc has a 15pin vga cable you can unplug from your PC monitor (or go buy a VGA cable if you want to keep one on the tv and one on your pc monitor - or if you are using a laptop).
when you unplug the computer from the monitor .. check the pins - should look to be about 15 pins in the connector. it that will plug into the tv- then you are using a vga cable. if it will not plug into the tv pc input .. don't force it. It could be a dvi connector . .take the cable off the PC and to radio shack and they can fix you up (you need a dvi to vga cable - not likely, but possible)
I always turn off a pc before disconnecting monitors - and plug into the other display before turning the pc back on.
Good luck.
Bill.
Posted on Nov 29, 2010
I need a firmware for Panasonic TH-L32C20X LCD TV, Software Version: 1140 Can you help me, Thanks.
sounds like you need a technician but try the panason website and support you will need a pc and sd card
http://av.jpn.support.panasonic.com/support/global/cs/tv/download/fw/europe/step3_eu.html
Dec 17, 2015 | Panasonic TH-L32C20X 32 inch Multi-System...
Panasonic 32-inch LCD TV Blinking 3 Times. Not Turning On. Please Help.
http://www.tv-forums.com/forum/TV_Equipment_C4/LCD_TV_Forum_F41/Panasonic_lcd_Tc-32lx60l_with_blinking_stby_light._P151410/
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the APh
board, A board, or the LCD panel.
Jul 19, 2015 | Panasonic Televison & Video
Sound on but no pitcher
Sound on means audio section is ok. No picture is video board problem. Pl check input cables. Or give Hdmi cable input. Disconnect all inputs switch on u should get plain raster that is only dots on screen, or blue back screen, if nothing contact authorised dealer,
Feb 08, 2015 | Panasonic TH-L32C20X 32 inch Multi-System...
Suport format mpeg4,flv,..
Please never do any more experiments with software [firmware] with this set. Contact the authorized service centre for Panasonic. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 24, 2014 | Panasonic TH-L42U20S Full HD 42 inch...
TH-L32C20X does not read hdmi cable
is the driver installed on the computer you are using at the minute?
Feb 12, 2013 | Panasonic TH-L32C20X 32 inch Multi-System...
Power on after five secand power off
Switch off TV and power outlet, remove plug, retry after 48 hours. Then if the problem persists, this might need attention by a qualified service technician.
Jul 24, 2012 | Panasonic TH-L32C20X 32 inch Multi-System...
Troubleshooting 32 inch Philips LCD TV
Sounds like a power supply problem that typically is caused by a power surge of some sort. Check with tvrepairkit. com for their power supply kit to do the repair yourself.
Jun 19, 2012 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Iwant to buy of main board panasonic viera
Contact the nearest authorised service center for Panasonic to buy an original one.
Jun 09, 2012 | Panasonic TH-L32C20X 32 inch Multi-System...
Panasonic TH-L32C20X 32 inch Multi-System LCD TV Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
