Question about Microsoft Xbox 360 Console
Disk drive wont read
Tray opens and closes but wont read or play any games
  • 203 Answers
You may need a new disc drive or you may just need to clean the laser in it.
if you remove the disc drive and turn it over you will see the laser, just clean it with a non static cloth.
Posted on Mar 11, 2009
What do you do when your xbox won't read disks?
The main problem might be a big problem with the disk tray. There might be an faulty wire that has lost connection and if your disk wont event turn on, there might be a problem with the power supply that supplies the cd tray. If the disk opens and closes but doesnt read and wont say tray is in and keeps saying open tray, there might be a small fracture on some of the wires or there is something wrong with the motherboard of the xbox 360. The best way is to buy the warrenty now and send it to the xbox 360.
Jul 27, 2011 | Microsoft Xbox 360 Console
Wont play games just says reading, open tray.reading, open tray. reading, open tray.u get picture
Xbox 360's disk drive is starting to fail.Knocking on the top of the Xbox (when its on its side) while loading a game cansometimes get it to work, but at some point you will need to have your Xbox repaired by Microsoft or replace it.
Apr 23, 2011 | Microsoft Xbox 360 Console
My Xbox 360 isn't reading any discs. Games nor Movies. When i put either in the game console it tells me to open the tray because it didn't read.by the way it makes a funny noise when it tries to read the...
take out the cd. close the tray with no disk in it. let it read till it says open tray
open and close it like 3 times with tha method mentioned above with out the disk. then put the disk back in and it will probly work.
sometimes the system turns dumb and u haft to remind it to reconize when there is actally no disk.
Oct 25, 2010 | Microsoft Xbox 360 Console
Games wont play
Check if theres anything blocking the disc drive.If that doesn't work each game has a warranty.
Jun 26, 2009 | Microsoft Xbox 360 Console
Put cd in then it says open tray wont play cd
Hi. this open tray code is caused by a failed limit switch that is responsible for sending a signal to the optical assembly, confirming that the tray is totally closed and ready to read the disk. this switch is part of the drive and, it is recommended to replace the DVD-ROM drive in this case.
Jun 03, 2009 | Microsoft Xbox 360 Console
Games wont play. Problems with Disk player
If you don't have the tools to open your 360 go to best buy or an office supply store and get a can of compressed air and blow the dust out of the dvd drive. If that doesn't work then the lens needs to be cleaned with a q-tip and alcohol. This has worked for me on numerous occasions.
Jun 01, 2009 | Microsoft Xbox 360 Console
it might be the disk drive lens just inst reading. if you still have warrenty with microsoft call and tell them whats wrong. if not then it will be cheaper if you buy a new disk drive for your xbox 360 and have a game repair shop replace it or just take it to the game repair shop and they can tell you whats wrong for sure. but call microsoft first you have 3 year warrenty with microsoft depending around what time you purchesed your system.
May 31, 2009 | Microsoft Xbox 360 Console
One day i was playing halo 3 and my disk drive starting making wierd, grinding noises and stopped then after the noise stopped my disk would stop spinning and now eveytime i try to read my disk my motor...
This hard disk is a easy fix, You can buy a new one for the fraction of the cost, All you have to do is slip this off the unit and apply an new or even a used hard drive. Here is some links for some hard drives http://catalog.ebay.com/Microsoft-Hard-Drive-120-GB-9Z600001-for-Xbox-360_W0QQ_fifptsZ1QQ_pcatidZ413QQ_pidZ70884347QQ_trksidZp3286Q2ec0Q2em271
you can get some for under 30 bucks. if this information helps please rate accordenly Thanks
May 02, 2009 | Microsoft Xbox 360 Console
I turn on my xbox 360 and it says open tray and wont read disc
I have had this happen about 3 times. The first time was when i figured out how to fix it. The 2nd and 3rd were temporary.(Just needed to be turned off for a moment) You need to shut the console off for atleast 15 minutes 10 at the lowest with everthing unplugged. I mean the hard drive, memory unit, and all cables, and adapters. Then after 10-15 minutes plug everything in and DON'T PRESS the BUTTONS ON THE XBOX OR THE CONTROLLERS. Press the button to open the tray and take out the game or dvd and put in a different one. If this doesn't work do it all over again and then put in a different game or dvd not the previous ones and turn on the console the same but then a soon as you get the disc in and closed in shut it off then open the tray and wait till you are at the main menu go into any program so you can't see it is reading and close the tray. If that doesn't work contact the xbox support line. Really hope this works for you.
Mar 28, 2009 | Microsoft XBOX 360 ARCADE Console
My xbox says open tray when there is a disc in it
common xbox flaw mine does the same ,just keep opening and closeing the tray till it reads the disk,this can be very annoying .your dvd tray is probally on the way out
Feb 26, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
112 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
