Question about Brandt WTC0815F Top Load Washer
The drum will not turn (brandt wm 700 eco) the moter and belt is ok
Eastest wat to put belt back on moter and drum
Hook the belt on the motor pully first and then on to the drum and then turn the drum at the same time to run the belt on. The belt will never go on if the motor adjustment is not correct. If this has not been touched it should be OK. If the the belt is at the right tightness it should "ping" if you flick it with your fingers.
Sep 30, 2014 | Washing Machines
Front load washer drum will not turn
Can you hear any noise? It could be the belt which you can check by tipping back and looking from underneath. The belt runs vertically from the motor to the drum pulley at the very back of the machine. Does anything work, the drain, the water fill? If they do and only the drum won't turn and the belt is ok then it could be quite a few things. The motor itself, check the motor windings with a multimeter. The control board, again check for voltages with a meter. Wiring to the motor, visually check the wiring harnesses throughout. Will need to know what your machine does and does not do to diagnose correctly.
Feb 05, 2014 | LG WM-2277HW Front Load Washer
How to operate top loader brandt malice AA washing machine
Hi guys! Please help me. I used the Brandt Malice top loader with a horizontal drum. I don't think the doors on the drum were clipped closed properly and now when I open the machine the drum is not facing up so I can't open it? It also won't spin. What do I do? There is clothes in there and the machine is off, but the drum seems stuck? Please help!
Sep 29, 2013 | Brandt WFH1176 Front Load Washer
There is a belt sitting in the washer at the base of the tub and what appears to be a small white plastic piece between the alternator and motor is this where the belt belongs
i no expert on that model but i seen a few inside of a washer there a moter small siver thing the belt goes on there and around the drum i say the plastic thing is part of the cog for the moter but cant be sure without seeing it does the drum spin or move when turn it on if not then that defo the drum belt
Apr 04, 2012 | Whirlpool LTE5243D Top Load Stacked...
My drum on my dryer is not yurning but all else seems to be working fine i have given the drum a push it then turns but when it stipos it will not move again
the belt could be bad or the moter if its the moter u will probably hear humming but the only way to really find out is to take the dryer apart to get to the moter and look at the belt
Jan 24, 2012 | Tricity Bendix TM220W Electric Dryer
DRUM NOT TURNING MOTER OK
if the motor is running and the drum isn't spinning you have a broken belt,next time send model number
Mar 20, 2010 | Dryers
Drum has stopped working. everything else seems to be ok
If the drum has stopped working it can be a few things.
  1. Moter
  2. Water level sensor (doesn't know if the water level is right, so it does not turn the moter).
  3. bad belt for the moter.
All good things to check.
Oct 14, 2009 | Washing Machines
I need to replace brushes on a hotpoint aquarius wm32
pull machine out and make sure u remover the plug completley it is still live with the plug in and switched off throught the netural feed
at the back take off the botom white pannel made of plastic look in side pull the belt off the moter
there should be 2 10mm bolts remove these and tap the moter and it should slide out
remove the earth wire and the moter harness plug and pull the moter out it will go you might have to turn it this way and that once out there is two screws holding each brush remove and put in the new breushes replace the moter
to put the belt on there is two screws on the lid one each side behind a oval blanking cover these are hex head screws
once off put the belt on the moter pully first then on the drum pully and gide it on by hand turn the drum and the belt will spring on open the door and spin the drum by hand to make sure the belt is on correctley replace lid and back turn on power an try if this does not work the moter has gone try ebay i did for my hotpoint cheaper than trade on there
Jun 28, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
LG WM 12230FB WASHING MACHINE
the belt which s at presently fixed is not of proper size change the belt and try it. the drum will run properly
Jul 06, 2008 | LG WM-2277HW Front Load Washer
Brandt WTC0815F Top Load Washer Logo
21 people viewed this question
Top Brandt Washing Machines Experts
Gerry Harvey
Gerry Harvey
john mabry
Are you a Brandt Washing Machine Expert? Answer questions, earn points and help others
