Question about HP LaserJet 3600n Printer
Was printing fine but now when I send something to print, the printer doesn't respond at all and just shows the "ready" screen
Is it connected directly to your PC, or is it networked?
In your printer dialog box, does the printer say "ready"? it may be "Paused" or "offline". Right click and select "resume Printing", and/or "use printer online"
Are you sure the cable is still connected and working?
try removing and reinstalling driver.
Posted on Mar 11, 2009
My canon mx452 keeps sending a message on screen saying printer not responding.I have run a diagnosis and it says no problem.
Make sure you are getting blank printouts when printing from the printers control panel, not just your computer. If it's printing blanks from both of these procedures, the focus would be on the "Printhead". Some Printheads are easy to remove, sits under the inks. Should be a grey latch you release to get access to the printhead. (remove inks first). Soak this printhead in a solution of windex, about a quarter inch deep, for about 20 minutes, wipe clean with isopropol alcohol and reinstall in your printer and do another alignment / cleaning procedure. If this does'nt fix the issue, you might try replacing the Printhead or retiring this printer.
Mar 02, 2015 | Canon Pixma MX452
Will not print
try to restart your computer. before u print something, make sure u select the right printer (maybe there's copy 1, copy 2, and so on), check the usb cable, and don't turn on your printer before the laptop/pc ready because your computer will not able to detect the printer if you turn the printer first.
Jun 13, 2012 | HP Photosmart 4180 All-in-One Printer
Hi, i have some problems with my ML-2010R, it doesn't respond to anything from the computer. when i press ON it makes the usual noises,eating and preparing for printing , but when i try to send a file...
try to use a new USB cable maybe the problem is on the cable this transfers the data from your PC to the Printer this is a common issue for printers. Or update your printer driver.
Sep 02, 2011 | Samsung ML 2010 Laser Printer
I can't print anything on printer, and when I try, it says the printer is not responding. In Printers and Faxes, it says it is ready.
Sure sounds like you have another printer as the default. Click on start. Then click on control panel. Click on printers and other stuff. See which printer is set as the default. If the Canon Pixma mx340 isn't change it. This should solve your problem.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
Jan 13, 2011 | Canon PIXMA MX340 Wireless Office...
Screen shows ready but can't print
ese follow these procedures carefully and i hope it will solve your problem.
● Check that all trays are correctly
loaded, adjusted, and installed in
the device.
● Using the computer, check the print
queue or print spooler to see if the
device has been paused. If there
are problems with the current print
job, or if the device is paused, a
configuration page will not print.
Also check the IP address associated with it if it is not connected directly. Make sure it corresponds with the one on the printer.
May 19, 2009 | HP LaserJet P3005n Printer
Canon ip 3000 saying printer not responding
when you disconnect the printer from your pc does it make a sound? also check File - Print - ( is the printer you are using highlighted? If no, right click and set as default. If yes, right click and see if it says "ready" when disconnected it should say "offline"
Which means the USB and the connection is OK
Look at the bottom right ot the screen is there a printer Icon there? if yes right click and see if there are any jobs pending, delete all jobs.
Otherwise it may be the driver which you may have to re-install.
Jul 23, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Printer not receiving jobs from computers in office..HELP!
what type of connector do you use? if its network printing then check ip address, cable, and the network card of the machine if it shows light, if its usb cable check the driver or cable.
note: make sure when you press the print buttom on the machine it doesnot show offline! if it shows offline you cannot print hit go or start to make it online.
if none of this work, reset the machine by hitting 1087 twice this will take you to maintenance mode then hit 906 then start, highlight the words that come on screen by your finger then hit start, the machine will ask you to put the main power on and off, do that and you will be fine.
Best Regards
Feb 15, 2008 | Kyocera Mita KM-2050 Printer
Printer is ready but nothing prints
Yes, there is a number for Epson printer technical support. Assuming you are in the US or Canada the number is on this web page: If you?re interested in troubleshooting this further let us know and please don?t forget to rate this posting.
Jan 24, 2007 | Epson Stylus Photo R200 InkJet Printer
HP LaserJet 3600n Printer Logo
383 people viewed this question
Ben Johnson
