Question about Ryobi RCS3535CA 14-inch 35cc Petrol Chainsaw
How do I fit a 14 inch ryobi chainsaw blade correctly
4 Suggested Answers
Mike258
  • 1498 Answers
SOURCE: Ryobi 14 inch electric chainsaw won't cut with new chain
Hi Rossmac,
Both the smoke and it's lack of cutting ability are symptoms of the same problem. The Chain is dulled. Instead of cutting, it's just rubbing on the wood and heating up. It's also not a big deal to fix..
Your options are:
  • Replace the Chain
  • Have the Chain sharpened
  • Sharpen it yourself
To sharpen it yourself, you will need a narrow round file that will fit inside the Chain teeth. Each tooth has a two cutting edges, get the file a position that matches the tooths angle of attack. Don't over do, three to five swipes of the file should do it on each surface.
You will see they alternate directions. You may find it easier to do all the teeth in one direction (skipping every other tooth) then do the other direction. Up to you.
When you are done, check the level of your chain oil. Since it did get hot, you might manually oil the chain before trying out your handi-work.
Go cut some wood.
Mike
Posted on Dec 21, 2008
dontbother10
  • 2220 Answers
SOURCE: ryobi chainsaw brake not releasing model pcn3335
Answered in clarfication.
Posted on Apr 03, 2010
  • 4088 Answers
SOURCE: I bought a ryobi 14 inch electric chainsaw. Is
Use regular bar/chain oil available from home centers, hardware stores, and saw shops. Always keep the chain properly sharpened and tensioned so that you don't have to force the chain into the cut which causes motor overheating. If you need to make an 'under' cut, do so with the top of the bar--don't run the saw upside down. Good luck!
Posted on Aug 02, 2010
How do I remove the clutch cover from a Ryobi chainsaw?
There are two nuts that hold the clutch cover and chain bar in place. The same nuts you would loosen to adjust the chain tension. Once those are taken off the cover, bar and chain can be removed.
Sep 03, 2016 | Ryobi RCS3535CA 14-inch 35cc Petrol...
How do I fit a bush cutter blade
usually brush cutting devices go on weed wipers not chain saws,
hope this helps
Jan 15, 2015 | Ryobi RCS3535CA 14-inch 35cc Petrol...
No local Ryobi dealer; what other brand chains will fit my 18" Ryobi ?
Any saw service dealer can fit a chain to your saw. 'Oregon' saw makes bars/chains for about any saw made in the last 50 years or so. Just take the chain itself in to get a replacement. Good luck!
Nov 18, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Jul 30, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
What size file do i use for a Ryobi chainsaw model PCN4545 to sharpen the chain
The standard chain file should fit it. It is about 3/16 dia. I found the dremel to work 10 times better, they have a little stone bit just for chains. Eventually, you have to take it in for sharpening, it will set all the teeth the same.
Feb 24, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
How do i change the blade on a 10 inch ryobi table saw
There should be a removable plate next to the blade in the table top. two wrenches of the correct size, one for balde nut and one for the shaft,Hold the shaft and turn the nut to remove. reverse procedure to put back on.Chibasset
Oct 31, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
Remington 14 inch electric chainsaw replacement blades
You can 14SC available online at www.masterparts.net you also can contact them toll free at 800-446-1446. They ship parts out very fast.
May 25, 2009 | Desa International Remington 14" Electric...
Ryobi battery chainsaw 10" - How do I tighten the chain?
loosen the two nuts that hold the chain cover on. Once they are just loose, then use a flat blade screw driver to turn the slot that you see right next to the base of the chain. Once the chain is tight, retighten the two nuts.
May 23, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
Ryobi RCS3535CA 14-inch 35cc Petrol Chainsaw Logo
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
