Question about Garden
Test the charging system on a 95 Polaris magnum 425 2x4
SOURCE: 2001 Polaris sportsman 500 magnum 4x4, speedo dont work
I'm not sure but it might be the sensor on the right front wheel disk
Posted on Sep 05, 2009
SOURCE: 1999 polaris magnum fuel comming out carb
i have no spark
Posted on Oct 26, 2009
  • 18 Answers
SOURCE: 2007 polaris trailblazer not charging how to test
I would start by making sure your battery is fully charged then with the battery connected, use a multi meter to measure the amps going to the battery while you have someone hold the throttle steady at different rpms. then you can check the capacitor charge coil resistance I think its the black/red to brown/white 120 ohms black/red to ground infinity and white to ground zero ohms. Hope this helps.
Posted on Mar 27, 2010
rockitman187
  • 2559 Answers
SOURCE: Ihave a 95 polaris magnum
It will work and it's really not one continuous magnet, it just has a cover over the magnets on the 96 one.
Posted on Jul 20, 2011
  • 123 Answers
SOURCE: Where are the cam timing marks on a polaris magnum 1998
There will be a couple sets of timing marks for your cam. The first and probably most important is the mark on the flywheel. On the top of the recoil cover, there is a bolt that can be removed to see the timing mark on the flywheel. The mark on the flywheel will be a "T". You will notice that the threads where the bolt was removed will have a point, kind of like an arrow that the "T" needs to be lined up with. Next there should be 2 dots on the camshaft gear. If the "T" is in the window, the dots should be at the top of the gear, and the piston should be at top dead center. The camshaft lobes will also be facing away from the valves. Hope this helps, Daniel.
Posted on Nov 04, 2011
Why will 2005 Polaris Magnum 330 fan not stop running when the ignition is turned off? The running fan drains the battery.
replace the faulty fan relay or check for a problem wire from the ignition to the sensor to the relay
Mar 03, 2016 | Polaris 2005 Magnum 330 4X2
Where are the fuses on a 2001 Polaris 325 Magnum 4X4
Polaris 325 MAGNUM 4X4 HDS A00CD32FA Parts Manual
www.manualslib.com > ... > 325 MAGNUM 4X4 HDS A00CD32FA
View and Download Polaris 325 MAGNUM 4X4 HDS A00CD32FA parts manual online.Polaris Automobile Accessories Parts Manual. 325 MAGNUM 4X4 HDS ...
Aug 07, 2015 | Polaris ATV
Polaris atv has no power to ignition
Check the run/stop switch and it's wiring. Also with these units make sure that the wires on the circuit board have not become disconnected. Also check the main switch and wires.
Dec 10, 2011 | Polaris ATV
Polaris 425 magnum lights don't work. how do I troubleshoot
GET A 12 VOLT TEST LIGHT, AND LOCATE YOUR FUSE BOX AND CHECK THE WIRES UNDER THE HEADLIGHT. TEST LIGHT IS YOUR BEST FRIEND.
Oct 25, 2011 | Polaris ATV
I have a 98 polaris 425 magnum, how do i tighten chain
how do i tighten front chain on 1998 polaris magnum 4x4
Feb 28, 2010 | Polaris ATV
4 WHEEL DRIVE DOESNT WORK ON A 1996 POLARIS MAGNUM 425 4X4 DOESNT EVEN TRY TO ENGAGE HAS A NEW BATTERY AND VOLTAGE REGULATOR
an ohm test on the hub coil wires will identify whether or not it is a bad magnet. test between the brown and grey wires and thisd should be aruond 27 ohms. then test brown to ground this should be open. you can also test 12volt power to the coil between thos two wires
Feb 18, 2010 | Polaris ATV
1995 polaris magnum 4 x 4
overheat check that the fan work properly if not check your temputure sensor if good check coolant level last change radiator cap
-high gear shifter probably needs to be adjusted
Sep 16, 2009 | Polaris ATV
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
