Question about Black & Decker 22" Electric Hedge Trimmer
My electric B&D hedge trimmer quit working. It is not the power cord. What could it be and can it be fixed?
  • 463 Answers
Obviously, disconnect power from the mains...
Something has come loose inside the unit. You can disassemble the unit. Follow the power wires from the pigtail to the switch/trigger (<-- Most likely point of failure), then to the motor. Also, triple-check there is not reset button (a pop-out fuse of sorts) on that unit.
Posted on Mar 11, 2009
I accidently cut the electrical cord while using the black and Decker hedge trimmer TR116, now its not starting.
Did it cut it all the way through.? Have you repaired it? Has it been repaired adequately? Check it hasn't blown the fuse in the plug when it was cut, protecting the circuit.
May 14, 2016 | Garden
My hedge trimmer has a faulty switch
Hi Bob:
First, make sure the power supply cord is connected with power at the tool.
Since it's already broke, you really can't hurt it so you get to play if you're into it.
Disconnect from power supply!
Try to determine if something is stopping the switch from moving far enough to function.
Dismantle until you can get the switch out. Try to clean the switch terminals and check the function with a continuity meter.
If you can't get it to work, see your local dealer about getting a replacement part.
Sep 18, 2015 | Bosch AHS 45-16 Electric Hedge Trimmer
Where can I get a new cable fitted for this hedge trimmer?
any accredited electrician or appliance repair shop will be able to fit a new lead(cord)
look in your local telephone guide.
Jun 16, 2015 | Bosch AHS 45-16 Electric Hedge Trimmer
Cut the electrical cord on craftsman electric hedge trimmer. Does not run. Is there a reset ?
NO, no reset. The only thing causing it to NOT RUN is an OPEN circuit condition caused by the cut wire, OR an IMPROPERLY made splice, OR improper replacement of the cord!!!!!
Get somebody that KNOWS what s/he is doing to replace the damaged cord.
Jul 12, 2014 | Craftsman Garden
Electric bushwacker trimmer wil not start
other than making sure u have a good power cord feeding it that's plugged into a known good outlet (not the one u always use) , any other troubleshooting would require u to open up the case to further investigate any faults , this maybe is a thing thats better left to an expert due to it being an outdoor electrical appliance and can adversely affect ones health and well being if something was mis done inside , any sears repair centers would sure be capable of fixing this tool and safely
Apr 08, 2014 | Craftsman Bushwacker Bush/hedge Trimmer...
16" B&D Hedge Trimmer, No.
motor smoking is an electrical fault internally
brushes , armature of field windings problem
take it in for a proper diagnosis
Nov 13, 2017 | Black & Decker 16Inch Hedge Trimmer
Black and Decker 22" electric
I do not know of a reset. Most likely you damaged the wire and have to repair that section, or replace the wire.
If really helpful, please rate.
Jul 12, 2011 | Black & Decker Electric Hedge Trimmer
I have a 14 in. electric chain saw I bought last year and need to download a manual
A hedge trimmer is a type of agricultural or garden tool. And as the name suggests, it is used to trim hedges. There are mainly two types of hedge trimmers - manual and electrical. Amongst these there are some below mentioned variations.
Stand Alone: A stand alone hedge trimmer could be either power driven or manual. The power driven stand alone hedge trimmer uses gasoline or electricity to operate. However, the manual or hedge trimmer driven by human force is best when you consider environmental factors. They are cheaper and easy to operate. Generally gas powered hedge trimmers or electrically powered hedge trimmers are equipped with safety devices. The mechanism is such that they operate only when the operator has both his hands on the handles.
Tractor Mounted: This type of a hedge trimmer is more suitable for pruning of plants and crops. Tractor mounted hedge trimmers either have a movable arm or they do not have a movable arm. The ones without movable arms depend only on rotating blades on a couple of central pivots placed on the tractor's side. Now, these hedge trimmers are best for growing grapes, more specifically for making wine. Small tractors driving between the grape vines are mounted with these type of hedge trimmers, without a movable arm.
Well, this was about hedge trimmers in general. Now lets get down to business. Here's a low down on a few best hedge trimmers. The following is an overview of electrical hedge trimmers comparison.
Hedge Trimmer Reviews
Stihl Hedge Trimmer HS81T: Well, this one is surely up for grabs. Stihl HS81T is a great option for keeping your hedges in a perfect shape. Stihl HS81T is lightweight with balanced design and low vibration levels. It has 24 inch or 30 inch double sided blade length. It's also equipped with rear swivel handle for enhanced comfort at different speeds. The engine power is 0.7 kW and this hedge trimmer weighs between 5.2 kg and 5.4 kg, depending on the blade size. It is good especially for shaping and sculpting your hedge. It does not start on the first pull sometimes, still Stihl is a good option for hedge trimming.
Black & Decker NHT518: Now you would perhaps love this, if you do not want the whole baggage of fuel and electric wires and so on. It is cordless and runs on a battery and 22 inch blades that give a smooth and level cut. It does a neat job of branches less than 1/2 inch thick and you get optional extra battery packs. However, it gets a thumbs down from users with regards to poor battery life. On the other hand the users like the cordless design. Again, they say that it is not as powerful as corded trimmers. Nevertheless, it is lightweight and makes minimum noise. So you can go for it.
Echo HC-150 Petrol Commercial Grade Hedge Trimmer: Well, hopefully most of the users would echo my statement that, Echo is a very efficient hedge trimmer. This is a high performing, commercial grade hedge trimmer powered by petrol. It is a smooth and **** free hedge trimmer and is great for pruning and trimming. Durability is apparently the forte of this Echo hedge trimmer. Superb double reciprocating blades cut on their return and forward strokes, which give a smooth, uniform finish to your hedges. Not a bad choice either!
Makita UH6350 Electric Hedge Trimmer: This is a well designed tool with a great cutting action, according to a magazine on mechanical products. It is light weight and can deal very well with branches upto ½ inch of diameter. Although one of the disadvantage is that you have to bear with a cord and has a single blade operation. A fairly good option if you are thinking of buying a hedge trimmer.
Well, there you go, this was a small list of best hedge trimmers. I hope the hedge trimmers comparison was useful for you.
Take your pick according to your requirements and any hedge trimmer is good so far as it helps you keep your plants in good shape! What say!
for mannual download go to
http://www.stihl.de/safety_manuals/en/heckenschere_englisch.pdf
Jun 15, 2011 | Homelite Garden
Trimmer Question
mains, battery or petrol A hedge trimmer can be powered in 3 ways: mains electricity, rechargeable battery or petrol. They all have their advantages and disadvantages, so decide which is best for you. Electrical hedge trimmers provide a clean lighter weight option with the convenience of immediate and continual use. However you may be restricted by cord length - not ideal if the hedge is a long way from your power source and having a cord can be obtrusive and dangerous. Rechargeable hedge trimmers give you the best of both worlds. They're clean to use and have no cord so they can be used anywhere, without the danger of accidentally cutting the cord. They are less powerful than petrol models and you do need to plan ahead though and make sure your batteries have been charged. 5-7 hours of charging will give you just 30 minutes use. A second battery will give you back up but if you're cutting for long periods of time, you may find this timescale too restrictive. Petrol hedge trimmers can again be used anywhere, there's no cord so they're safer. Just top them up with petrol and away you go, no charging necessary. These models do tend to be harder to use - they're heavier, noisier and smoky.
Aug 27, 2008 | Electrolux Gas Hedge Trimmer
Black & Decker 22" Electric Hedge Trimmer Logo
962 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
