I have a gateway laptop mode nv57h13u need diagram keyboard and their functionsl
3 Suggested Answers
  • 114 Answers
SOURCE: keyboard start up mode wrong
When you mean numeric mode, you press letters and numbers comes out?
If yes just look for the "FN" button it should be near the window, ctrl, alt and space button. if not it will be a combination button.
just press it when inside windows and it should go back to normal.
Thank You for using Fixya!
Posted on May 06, 2009
  • 39 Answers
SOURCE: gateway mx8711 keyboard
yes
Posted on Jan 12, 2010
How do I replace a keyboard on a Gateway NE522?
Laptop keyboard replacement procedures are all similar,
Search on the internet for how to replace ne552 keyboard (or similar). You my find quite a number of nearly relevant instructional videos and step-by-step instructions, referring to slightly different models..Look at a few and see how similar they are, pick one and follow it eg
Replace Keyboard Gateway Laptop or
Replace Keyboard on Gateway Laptop NE56R
What you really need is the maintenance & service manual, but there doesn't seem to be one. You might try contacting Gateway support and asking.
Keyboards for your model are readily available, on ebay or from commercial parts suppliers, even Gateway
5.November.2015
Nov 05, 2015 | Gateway Computers & Internet
Why won't my Gateway, NV57H13 not turn on?
Make sure the coin cell battery is in working condition. If it is exhausted, the laptop won't boot.
Oct 29, 2014 | Gateway NV57H13u 15.6 Laptop i3 2.1GHz 4GB...
How do I replace the keyboard on a Gateway LT3119U?
Visit the Gateway support document website and locate the "User's Guide" section of the listings for your laptop model.
You should be able to locate either a "component replacement manual," or a document focusing specifically on replacement of the keyboard for that model (as different models of keyboards have slightly different methods of removing the keyboard.)
You may also wish to check the FAQ's in the support documents of your model, as they may also contain information on replacing the keyboard.
Power down your Gateway laptop and remove the battery.
This will not only ensure that you don't accidentally damage your laptop by powering it up while working on its components, but may also be necessary to reach the mounting screws for your laptop's keyboard.
Press the power button once after the battery has been removed to discharge any remaining electricity that the laptop may have stored.
Consult the support documents for your Gateway laptop model and find out where the keyboard mounting screws are located.
There will most likely be between two and five screws, depending on the specific model of laptop that you own.
You may be required to remove the keyboard bezel (the strip of plastic that runs along the top of the keyboard) in order to reach some or all of the screws; this can be done either by sliding the bezel off to the right of the laptop or by simply lifting it off once loosened (though you may need to use a coin or flat-head screwdriver to detach clips or pry the bezel out of its resting location.)
Remove the screws holding the keyboard in place.
The screws will either be located on the bottom of the laptop (under the space that the battery occupies) or beneath the keyboard bezel.
Put the screws in a safe place where they will not be lost, since you will need to use them to secure the new keyboard.
Lift the keyboard up from the bottom, detaching the keyboard connector and pulling the keyboard itself free from the Gateway laptop, then setting it aside.
You may need to once again use a coin or flat-head screwdriver in order to depress clips which might be holding the keyboard in place.)
Plug your new keyboard into the keyboard connector, then carefully place it back into the space previously occupied by your old keyboard.
If the keyboard is designed to be held in place by clips, press down with sufficient pressure to clip the keyboard into place.
Replace the screws that you had previously removed from the Gateway laptop.
Make sure that the screws are firmly in place both to ensure that the keyboard is secure and also to eliminate any potential problems with replacing the bezel or battery.
Reattach the bezel (if you removed it) and the laptop battery, making sure that all components have been reattached and are firmly secured.
Once the battery is back in place, press the power button to power up the Gateway laptop and give your operating system a chance to recognize the newly-installed keyboard.
hope this helps
http://www.youtube.com/watch?v=z7fs3nce2g4
watch the video
Oct 06, 2012 | Gateway LT3119u (LUWEW02001) Netbook
Broken function keys on gateway NV57H13u
If you are sure they were working yesterday then roll your system back to a day before yesterday by using System Restore. System Restore will allow you to select a Restore Point (date and time) before you started having the problem. System Restore does not delete your data, documents, music, pictures, videos or programs (unless the program was installed after the restore point you selected). Click Start/Program or All Programs. Click Accessories/System Tools/System Restore. In windows 7 just click Start and in the search box type: System Restore then look up at the returned search results and click on System Restore.
System Recovery on the other hand will delete everything and set your system back to when you first purchased it.
May 30, 2012 | Gateway NV57H13u PC Notebook
Where can you buy the keyboard? my son has ripped some keys off and I do not know where to find either the little plastic replacement springs or a full keyboard.
Here a couple of links where you can find a replacement keyboard: http://www.sunvalleyus.com/GatewayKeyboard/ http://www.nextag.com/gateway-keyboard/shop-html http://www.papatek.com/Gateway-Keyboard/ http://www.amazon.com/DekCell-Laptop-Keyboard-Gateway-MX6000/dp/B000NJYHRA
It depends also on the model of your laptop.
You can also buy just the keys and put them yourself: http://www.laptop-keys.com/Select%20Model.php?model=Gateway Also here is a guide, if you want to do it yourself: (do not delete) utube.png
If you need further assistance, or have further questions, just leave a comment. Thank you for using FixYa. Cheers
Jan 20, 2011 | Gateway Computers & Internet
Gateway laptop model M1634u continuous beeping on startup , able to boot to safemode and normal mode, but on windows log in , it has a long string of characters entered for the password, can clear it out...
Yes the keyboard is likely the issue. As silly as it sounds I would recommend strongly pressing all the keys on your keyboard repeatedly. Perhaps a few have become stuck. Otherwise contact your manufacturer or local technician. -Ravi Shanghavi
Aug 18, 2010 | Gateway M350 Notebook
How to replace gateway 3040 keyboard, need to know method to open the laptop to install a replacement keyboard
Visit this site and follow the instructions carefully.
http://www.ehow.com/how_4885524_remove-keyboard-gateway-laptop.html
Please rate me thank you
Apr 10, 2010 | Gateway 3040GZ PC Notebook
Keyboard stuck in Fn mode, how do I get it out?
Sounds like the "Num Lock" is on, the key should be at the top right hand side of the keyboard, just strike that key and the keyboard should return to normal.
Good luck
Jun 11, 2009 | Gateway Computers & Internet
I received the replacement keyboard for my Gateway laptop computer without the "easy to read instructions". I was hoping that these instructions for removal of the defective keyboard and...
Hi
The best I could find was the product page for the keyboard. Otherwise you'll need to either contact the people who you bought it off or use a general guide for replacing keyboard such as this one. It does have laptop - specific instructions for some Gateway laptops - hopefully you'll hit lucky!
You could try searching specifically for "(your laptop make & model number) keyboard replacement guide" if the above link does not work. Google usually has the answers! Alternatively if you provide me with the model number I could have a look around for you.
Hope this helps and good luck!
Philip
Jul 13, 2008 | Gateway Computers & Internet
Keyboard is locked into Fn mode and doesn't type letters on the right side
you need to press FN and NumLk together (NumLk on some laptop keyboards is either F11 or F12)
Does this help?
Regards
Please remember to rate
Nov 19, 2007 | Gateway Computers & Internet
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
