Cowon J3 32gb Black - 3.3" Amoled, Micro Sd Card Slot Logo
A
Anonymous Posted on Apr 18, 2013
I cannot access the files in my cowon mp3 player with external micro sd card
Cowon z2 plYER
I Have 2 problems, I put songs on my player and it says that the file doesnt exist on some songs. The player does support the format of the song but its not recognizing it. The other problem is that I...
File Doesnt exist, means the music is not MP3 that your putting on, make sure its MP3 format. In regards to SD card support, the unit doesnt combine the internal and external memory. You would have to access the SD memory from the Explorer icon on the main menu.
4helpful
3answers
How do I use the mico sd card on this player?
I would recommend here:
http://www.newegg.com/product/ProductList.aspx?N=2070070068+1053118914&Submit=ENE&SubCategory=68&Tpk=micro%20sd
It honestly doesn't matter what brand of micro SD you stick in your MP3 player, so I wouldn't worry too much. Micro SD's are much smaller, so no, you can't use a normal SD in a Micro slot. Most however do have an SD "shell" that you can stick your Micro into, and use just like a normal SD card. Also I know that MOST mp3 players allow you to add pictures, videos, etc, and having a Micro SD inside should allow you to add things directly onto it, so i dont see why you wouldnt be able to access the contents of the Micro from your MP3.
Hope this helps! :)
I cannot access my external memory!!!!
it cant hold a 2gb micro sd
it can hold only 1 gb micros sd
sorry
2answers
Doesn't show mp3 files on micro sd card
You have to drag and drop only the MP3 files into the music folder. If you have them organized and in folder by artist, drag only the MP3s into the card's Music folder.
How to sink micro sd card with player
You should probably just copy the mp3 files directly from their source folder over to the micro sd. To do this, put the micro sd into some type of adapter that will allow the computer to read/write to it. There are usb sticks that do this and there are SD adapters you put the micro into so you can use a media reader/writer with it. Once you have the card seen by the computer, just drag and drop your MP3's into the drive letter corresponding to the memory card. After that is done, put it back into the player and turn it on. I should find all your songs and make them available to you.
My sansa player does not recognize a micro sd when its inserted
Sorry, it doesn't work that way. You can use a separate card reader to put files onto the microSD card. When the card is installed into the Sansa, the Sansa will see the additional music.
How to access SD micro card on sansa e250
I expected to find the new playlists on the SD card as a separate file to access and play. Instead the SD card songs show on up the Sansa menu simply added among the existing songs / artists stored in the Sansa. Its not a solution but they are there. Since using the SD card, my Sansa does databse refresh everytime it starts, whether SD card is in it or not.
External memory - sd card recognition on pc??
if it doesn't even appear on windows explorer either the sd card, usb link or iriver is defective. if all else fails try getting a memory card reader. this allows you to store files on the card through the computer and still be able to insert the card as external storage on the iriver x20. the only trouble with that is that its hard to get the card in and out of the iriver
Top Cowon Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Cowon Audio Player and Recorder Expert? Answer questions, earn points and help others
