Question about Dishwashers
Manual for ds603mfd fisher & paykel dish draw
  • 3230 Answers
SOURCE: Fisher & Paykel dishwasher model dd602 error code F4
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Posted on Jun 26, 2009
  • 784 Answers
SOURCE: F1 Error on Fisher & Paykel Nautilus
It leaked before leading to this.
1- Unplug the power.
2- Dry out the leak.
3- Before taking off the lid seal, check if Lid actuator working by going to diagnostic mode. 4- Select LD.
5-Pull the drawer half way out so you can see the lid going down or not when you turn on by pressing lock button.
6- Press the lock button again to release the Lid.
7- Most the time it is a Lid actuator problem and your seal look good, then you replace the Lid actuator only.
8- If it is a problem with the Lid actuator and your seal look bad then replace all .
Posted on Jul 03, 2009
taran_2005
  • 10515 Answers
SOURCE: we have F1 light appearing and cannot remove
I am Sorry to hear regarding this Error. But, i am afraid that you need to call a technician as this Error refers to Faulty Control Board. It has to be replaced.
You could try to Press Cancel / Clear buttons, if any to check if that could improve the situation or keep the Dishwasher unplugged for few minutes, and then turning it ON, say after 30 minutes to check if that could fix the problem. ( You would be lucky if you could get it fixed by this ).
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 09, 2010
woodchuck789
  • 4070 Answers
SOURCE: haveing a u3 code on my top draw of my fisher
First have the unit turned off. Then open up the drawer that,s giving you trouble.
The badge ought to be lit.
Now simultaneously press the static touch pads on each end of the led status lites (the ones on the drawer top?) (Cycle Select, and Eco-sensor pads)
Hold them for about 5 seconds.Now If you have a metal front machine, the badge display will either show HP or LP. Assuming you have normal water pressure about 50 - 70 psi you want to select the HP setting.
Do that by pressing the start button till you get what you want, then press power off to lock the setting in.
Posted on Mar 06, 2010
Testimonial: "problem solved thank you very much for the info"
My drawer on my fisher & paykel drawer sticks
I found a ball bearing stuck in one of the draw runners ?
http://www.scribd.com/doc/6462163/DD601V2-Manual see if this link still works
Sep 29, 2014 | Fisher and Paykel 24 in. DS-603 Built-in...
F& P bottom dishwasher draw won't drain. Top dish draw draining fine?
Excess water in
the DishDrawer
Drain hose(s) bent or
kinked.
Straighten the drain hose(s).
Blocked filters and/or drain
hose(s).
Clean the filter plate/drain filter. Unblock
the drain hose(s). Refer to the user manual
Aug 28, 2014 | Fisher and Paykel Dishwashers
Fisher and paykel dish draw not draining
If the problem is with both drawers, then most likely kitchen side drain is blocked. But if only one drawer, then need to clean filter and drain sump at base or if pump motor is not running then replace the pump rotor.
Mar 21, 2013 | Fisher and Paykel Dishwashers
Fisher and paykel dd603
Flood switch is at the very bottom underneath the bottom draw in the base floor.Unplug cord.Open bottom draw all the way & squeeze a towel or sponge under the draw & soak up the water..The washer should work now..Why did it flood in first place?
Check that dishes are not stacked higher than top edge of the draw otherwise it can't seal.this can happen when children are asked to stack the dishwasher.Another cause is some models the seal is an inflatable tube that seals the top edge of the draws,it gets cut or sliced buy a plate that was stacked to high when you closed the draw.there should be no clunk of dished hitting when the draw is closed.
May 30, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher Paykel control panel to far left side has a film on it that chipped off - showing a shinner stainless steal under it. I guess this is a coating of some sort. Dish draws are 4 1/2 yrs old. Mild det...
You can buys the parts that look chipped/ broken and replace them. Panel parts are very easy to replace.
Check out which parts you need from the parts manual and order from the local fisher and paykel distributor.
http://www.stokes-aus.com.au/StokesAP/Manufacturer_Info/FP/DISHWASHERS/599084%20Dishdrawer-Version%203%20%20eg%20%20DD603%20etc.pdf
The parts that you need are listed from page 6.
Jan 02, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Th dish washer that we have is the 2draw dd-603m
A lot depends on how it happened. Is this a new installation or everything was working well until now? F1 error implies the float switch in the drawers is activated as the inlet water soneloid could not turn off. This prevents the units from being flooded.
Are you using the correct pressure setting for the water supply. Check the user manual for details. IF you don't have one, download from the fisher & paykel website.
Nov 08, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & paykel double dish drawer top draw just beeps...
The controllers get very brittle & can break away from their housing, the reason it's rapidly beaping is because it thinks the door is open. PLEASE TURN IT OFF FIRST AT THE POWER POINT. Take the front draw panel off by pulling the plugs situated on the front behind the draws, the controller is at the top right hand side if it is loose then thats the problem, double sided tape will work but lots of it or try a wedge type arrangement. I know this is an old post but people refer to these for solutions much later.
Mar 09, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel dish draw F2 code.
Buy a Miele they last 20 years or more and don't go brain dead in 4 years like the Fisher and Paykel
Nov 26, 2008 | Dishwashers
Dishwashers Logo
55 people viewed this question
Top Dishwashers Experts
