Question about Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum
Can't figure out how to open the canaster to take the dirt out
How do I open the canaster to get the dirt out
  • Anonymous Mar 27, 2009
    My DC07 has a bad surge, suction builds up then falls as it surges, is this the norm
  • 389 Answers
Above the clear bin (canister) is the cyclone, and on top of that there's a handle. The whole bin-plus-cyclone assembly is released from the rest of the machine by grasping the handle and releasing the button that is on top of the handle where your thumb naturally falls. The trigger on the underside of the same handle releases the base of the bin (on a hinge) so the waste falls out.
You need to be careful not to squeeze that trigger until the bin is wherever you want to get rid of the waste, or else you'll end up with it all back on the floor!
You can empty the waste directly into a trash can, or enclose the bin in a plastic waste bag before releasing the waste.  After, make sure the base is properly re-secured before re-fitting the bin to the machine.  You can wipe the outside of the bin with a damp cloth.  If you wipe the inside (not necessary, but sometimes nice) make sure it is completely dry before closing the base.
I hope this helps.  I value your feedback, so please remember to rate this response.
Posted on Mar 11, 2009
  • TreborEcurb Aug 31, 2010
    What does one do when the trigger on the underside that releases the base of the bin doesn't release? Is there a way to manually force the base open?
Where do you put the prefilter on a miele canaster vaccuum
Hi If the power head isn't working it may be clogged. Try taking it apart to see if threads and general dirt has got in at the sides. Also without the power head if the Miele still isn't working then its a possibility that the on switch wiring is either loose or check the plug at the end of the power cord.
Sep 11, 2012 | Miele S514 Solaris Electro Plus Vacuum
Latch on my dirt devil total pet canister to empty is stuck. how do I make it open
I bet I have the same problem as you. My vacuums canister was put back together backwards and now will not move far enough to click unlocked. I am not sure how to fix this and I cant find anyone on any forums who do :( If you figure it out post it! So far ime just trying to muscle it open.
Mar 26, 2012 | Dirt Devil Breeze Bagless VacuumVacuum
I have an Elextrolux Discovery Advantage(upright) . I need to replace the lower hose. Unfortunately the hose comes out of the roller/feeder area fine but I believe it is held in with a screw in the...
It's simply screwed into the tank. Simply unscrew in a clock-wise direction to remove. To install the new hose, screw in in a counter-clockwise direction. This is opposite the direction normally used for regular screws.
You don't need to dismantle the tank at all.
Nov 03, 2010 | Electrolux Vacuums
I can not get the dirt cup out to empty it.
Just slide the dark gray release tab, located just below the cup, all the way to open position, and then pull the Easy Empty Cup toward you.
Jul 10, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Got a sock stuck in vacuum, can't figure out how to open bottom and get out
I believe it is held in with 6 "torx" head screws. I think they are #6
Dec 12, 2009 | Dirt Devil CE6100 Featherlite Upright...
ok . i may have read you post wrong but i think you want the vacuum to empty itself ? i never heard of any vacuum emptying itself ......... the water or dirt goes into the canaster . when full remove the top and dump the bin . some than a drain plug you take out when your over a floor drain or outside ........ if this answer helped please rate 3 or 4 this high rateing will keep me in the paid answer department thanks you ..........if i misunderstood your post i am sorry , just leave a comment i will get it and try to help
Apr 03, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
I have acquired an old Regina Electrik Broom
Hi jmathe, Looking at the back (business side) of the vacumn: Underneath the white plastic dirt cup, please find a cast aluminum latch, that secures the part you will empty. To remove the white plastic part, turn the aluminum latch handle downward, and to your right, while you are holding on to the dirt cup with your left hand. I usually wear a dust mask, and empty the dirt into a small grocery bag, to tie shut, before placing it in the trash. To replace the dirt cup, turn the cast aluminum handle back to where it was before, handle pointing left. The more often you empty the cup, the longer your Regina Electrik Broom will last. Mine is forty-five years old. Allow the motor to cool, often, as well.
Jan 07, 2009 | Regina ElectrikBroom RG100 Vacuum
Dirt devil easy steamer need directions to use
Thank you for responding to my question. I should have spent some time really looking at my little machine. It wasn't hard to figure out -once I found and read the back of the cleaning solution bottle and tried my luck following the water to cleaner ratio.. Opening, adding the cleaning solution and water and re-closing the reservoir was pretty easy. Everything worked out fine...and my carpet is...spotless. Thank you, Cmarie
Mar 27, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Oct 15, 2006 | Hoover U6630-900 WindTunnel Bagless...
Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum Logo
90 people viewed this question
Top Dyson Vacuums Experts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
