Question about PANDIGITAL PhotoLink Office Equipment & Supplies
Lost my cd for my pandigital scanner Model Number: PANSCN05
Lost my cd drivers
Pandigital scanner for photo negatives. the setup is for Windows xp. I have windows 10. I have 64 bit and not 32 bit which what it requires. The model number is PANSCN05, serial # 0105000510800606.
Older scanners are not compatible with newer operating systems and if the manufacturer does not provide you with a driver you are SOL and have to buy a new scanner that will work with your OS. End of story.
Aug 22, 2017 | PANDIGITAL Computers & Internet
Want to purchase some photo sheets
This is a scanner not a printer. You put photographs or negatives into it and it saves then to SD card or USB.
Pandigital Photolink One Touch PANSCN05 4 Inch x6 Inches Photo and Slide...
Jan 18, 2016 | PANDIGITAL PANSCN05 Photo Scanner with...
Why will scanner only scan 1 photo?
possible lack of memory where ever it's scanning to?
Jan 04, 2015 | PANDIGITAL Computers & Internet
Slide scanner doesn't work properly
Put this scanner in the Trash.Your problem has no solution.
Pandigital - is not a serious company and rabble imbeciles.
They do not provide support for their "products"
Nov 30, 2013 | PANDIGITAL PANSCN05 Film Scanner
How do I scan negatives?
You can try scanning negatives the same way you scan prints, but the results may not be great. Scanners that are designed to scan negatives usually have some way to put light behind the negative to make sure it scans with enough contrast. They often also come with special holders for negatives. I don't know if your model was specifically meant to do negatives, but you can't hurt anything by trying.
After you scan a negative you need to convert it to a positive. The scanner may have come with software that can do this. If not, IrfanView is a free program that can do that as well as much more. It's a great general-purpose image viewer, so it's worth downloading in any case.
May 13, 2011 | PANDIGITAL PANSCN05 Film Scanner
Does this work with a mac?
go to pandigital.com, and look for your scanner and click it. then look on the scanner page.
Dec 28, 2010 | PANDIGITAL PANSCN05 Film Scanner
I found a cd it says pandigital cd driver on it what is it for
Pandigitals products are Panditigal Novel, Digital Photoframe, Photo Scanners Converters, etc.. so that CD should be the Driver CD for one of the devices, perhaps it's written on the Cd or you may check the contents of the CD on your computer.
Pandigital Official Website
Good luck.
Thanks for using FixYa.
Nov 02, 2010 | Computers & Internet
679 people viewed this question
Top PANDIGITAL Office Equipment & Supplies Experts
Mike
David Payne
David Payne
Are you a PANDIGITAL Office Equipment and Supply Expert? Answer questions, earn points and help others
