Question about E-Machines eMachines Desktop PC
When connecting my weatinghouse flat screen to my emachine pc, tv screen says invalid format. Is there a way to change format?
  • E-Machines Master
  • 7,627 Answers
Is the format refering to a file you are trying to play? If so, convert the file. It may be a resolution issue on the Computer? How are you connecting? HDMI? Do you see any thing other than the error message?
Posted on Apr 19, 2013
I have a bunker hill item 62463 dvr security system and all i get on my T.V is invalid Format it will do nothing else
You need to use the TV remote, and change the input to video, or DVR ...or something. Run through the various input channels, and you will find it. Invalid format is like if my TV is set to RGB/PC input, but the screen has timed out and is in sleep mode (no display) ...it puts invalid format on the screen. Or if you go to straight TV instead the channel that's connected to the box, same thing. You have to have the right input selected. You usually need the remote for it.
Dec 02, 2017 | Computers & Internet
Vizio vt420m invalid format when trying to view netflix
The TV can't read the format that the data is in, it is a kind of code, your tv can decipher it.
Jul 02, 2012 | Vizio VT Televison & Video
Invalid format on tv when used as monitor
This problem occured using vista.
To solve this problem i had to change the colours from highest (32bit) to medium (16bit)
Oct 17, 2009 | LG 42LC2D 42 in. LCD HDTV
I have a LG 42PC5D Invalid Format on Screen HDMI VGA and PC
I have a LG plasma and I am trying to connect my PC via VGA and I am getting the "Invalid Format" - can you please tell me what is the problem? Thank you
Aug 25, 2009 | LG 42PX5D 42 in. Plasma HDTV
I have an eMachines and when i hook up my 42in LG HD LCDTV says
You resolution on the eMachine is higher than what the 42inch LCD can support .. reduce is to size by check the LCD manual and make change in window display settings
Jul 18, 2009 | Computers & Internet
Invalid format displays on screen
hello try changing the picture ratio...what i mean is try 16.9 widescreen or 4.3 ledder box the tv is tryn to produce a pic bigger or smaller than what you have keep tryn different picture ratio's
May 20, 2009 | LG 26LG30 26 in. LCD TV
Invalid format message when trying to use the RGB(PC) port
Honestly, that sounds like one of two things happened. Either the resolution of your computer video card changed or (I'm not sure with your specific TV) the TV's resolution changed.
If through the TV menus you can adjust PC resolution, I would try changing the resolutions. In the LG 47LB5DF TV, press Menu, then go to Picture, then go down to Screen. On the screen menu, you will see Resolution, Position, Size, Phase, and Reset. First try adjusting the Resolution to some of the options you see. If that doesn't work, try to reset the screen settings.
If adjusting those settings on your TV does not help, then you will have to change the resolution through the computer. Try connecting a monitor to the computer. If you get a picture through the monitor, on the desktop right click and select Properties. If using XP go to the setting tab, if using Vista/7, select Display Settings. Lower the resolution to something you think the TV will be able to handle, then connect the PC to the TV again. If you are using an HDMI connection to the TV, you may have to turn off the computer, connect the cable, then turn the computer back on with the TV on the correct input.
If the monitor doesn't show the picture or if you don't have another monitor, you can try adjusting the picture in safe mode, by pressing F8 after you press the power button, before you see the Windows loading screen. Press if multiple times if necessary. You should see a screen that gives you a few startup options. Select Safe Mode. After Windows boots up, you should still see the screen as the resolution would have been reduced. From there try changing your display settings.
Hopefully that info has helped. I noticed that you asked this question 2yrs ago, so I hope you have already figured out how to fix your problem. I simply wished to post this in case it would help you or anyone else had a similar problem. Good luck and take care.
Dec 15, 2008 | Philips Magnavox 42MF521D/37 Television
Invalid format
the comp is set to an unsupported screen res. set it to 640x480 and try again.
Dec 04, 2008 | Televison & Video
Invalid format
my xbox 360 when hooked up to my 42inch Lc7d get sound but displays invalid format error,  how can this be fixed?
Jul 07, 2008 | LG 42LC2D 42 in. LCD HDTV
E-Machines eMachines Desktop PC Logo
47 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
