Question about Genie Company G912 Genie 912 One Button
Genie garage door opener made before 1995 no remote need to program to 2013 Chrysler mini van
4 Suggested Answers
  • 170 Answers
SOURCE: I have new Genie 9-12 remote for garage door
The code for the opener is on a dip switch set under the light bulb lens on the opener unit. Remove the lens and the switch set is usually located on the left as you look at it. It's either a 9 or 12 switch set. Match the numbered switches on both the remote and the receiver, and it should work! Oh, and make sure the battery is fresh.
Posted on Feb 12, 2011
SOURCE: FOR GENIE GARAGE DOOR OPENER ICA SERIES WITH
First you want to clear both Garage Door Openers. To clear the openers you need to locate the learn code button. This button is (usually) under the white lens cover just push it and hold it in until the red light stops flashing then do the same thing to your other opener. This clears out all remote controls that are programmed to these openers. Try the remote to make sure the units were properly cleared. Neither opener should activate if this was done correctly. After units are properly cleared push the learn code button on the opener that you want this remote to open. The learn code led will flash, then press the button on the remote once (learn code goes solid), press the remote a second time ( learn code goes out). Press the remote a 3rd time and opener should activate.
Posted on Jul 14, 2011
dcramer531
  • 1654 Answers
SOURCE: I have problem in my garage door. I have manual
Does this opener have intellicode opn it? if so it can teach itself the code. What excactly are you wanting, are you needing to find out what the code is on the opener to program the remote? Is your opener a Genie model also? I also need the model of the remote to find the coding info on this.
This is from Genie themselfs. ( Remotes manufactured after 1996 should work with your Intellicode® opener. Pre-1996 remotes use fixed-code sequencing and are not supported by Genie® Intellicode® technology. If you are unsure about when your controller was manufactured, contact us, your local Genie® retailer or your local Genie® ProTM dealer.)
Posted on Jul 25, 2011
How to program a remote for a genie garage opener model 209
When programming a genie remote press the learn button
Then you will have to press the genie remote at least three times before it stores the code older genie models 5 times genie i
Apr 05, 2015 | Building Materials
I have a Master Mechanic Garage Door opener that I am trying to use a Genie Master Remote to operate. What steps do I need to take to operate the door with the Genie Remote?
You have to pair the remote with the opener, which will require the opener manual because you have to put the opener in programming mode.
Dec 06, 2014 | Building Materials
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
We want to erase all of the programed instructions for the garage door in our Chrysler 2002 mini van the book says to push the 2 outside buttons until the green light begins to flash we don't know...
I just installed a garage door opener and the programming is done on it, not in the car. There is a button you push on the opener that learns your code and then remembers it. If you have an owner's manual for your opener, check in there. On mine, which is a Genie, you open the lower part of the cowl and there is a button you push and hold in until it starts blinking. Then within 30 seconds you have to push your opener remote or your in-car transmitter and it will learn the code.
Dec 19, 2010 | 2002 Chrysler Town & Country
Have a 3 Genie remote and the center button works in programming one garage door, but the side buttons will not work to program the other garage door. Can you help?
The other opener has to be a genie, compatible genie to be exact. An older one will not work with new devices. If it will not program it will be the openers fault not the remote. Thanks BB
Feb 16, 2010 | Genie Company IntelliCode GICT390-1BL...
Programming the garage door opener
Homelink Garage Door Opener Programming Procedure:
The procedure described below was successfully applied to a 2005 Jaguar S-Type.
To begin with, several attempts were made using the programming instructions contained in my Jaguars owners manual. Though the procedure described in the owners manual was straight-forward and understandable, I was unsuccessful in getting the vehicles remote to make my garage door opener function. The particular garage door openers I have are both made by Genie. Both openers utilize the Rolling Code feature.
To begin with, be sure to clear previous codes on your Jaguars garage door opener by first turning (rotating) the ignition key to the I position (first notch). Next, simultaneously hold button 1 (left most button) and button 3 (right most button) down until the middle buttons red light changes from continuous on to a rapid flash. This process takes approximately 20-25 seconds. What follows is a two part process. In the first part, get your Genie portable remote and hold it near (approximately 3 inches away from) your Jaguars garage door opener console buttons. Choose which button on your Jaguars remote you wish to dedicate to your Genie door opener and simultaneously press and hold your Genie opener button and your Jaguars opener button. The red light on your Jaguars center button (button #2) will light up and within 1-2 seconds will begin to flash rapidly. You have just completed part 1 of the two part process.
Part two: Now it is time to utilize the Learn function on your Genie garage door opener. Press the Learn button on your Genie garage door opener. The red LED adjacent to the Learn button will begin to flash. You now have 30 seconds in which to program your Jaguars opener button. Using the same button you just used in the part 1 procedure, press and hold the same button for several seconds. As before, your Jaguars red light in the middle button will light up and within 1-2 seconds, it will flash rapidly. Release the button you are programming. Now, here is the key piece of information! Once again, press and hold that same button. Once again, the center buttons red light will flash rapidly. Release your newly programmed button. This procedure proved successful in my application. Here is what has just happened. The first time you pressed your Jaguars remote button tells the Genie opener that it exists and that it is a viable candidate for making your life easier (opening the damn door). The second time you press your Jaguars remote button confirms to the Genies rolling code that your Jaguars signal is legitimate and is to be trusted from then on.
Jun 06, 2008 | 2003 Jaguar XJ-Series
Genie Company G912 Genie 912 One Button Logo
70 people viewed this question
Top Genie Company Home Security Experts
Lawrence Oravetz
Are you a Genie Company Home Security Expert? Answer questions, earn points and help others
