Cant hear tv with soundlogic wh-6/4685 wireless headphones
Did scan and have gone thru all channels and tv sound of channel never comes up.
SOURCE: acoustic research aw722
poop in a bucket
Posted on May 10, 2008
  • 155 Answers
SOURCE: RS120 Can still hear TV when headphones are on
Ok.. first.. the simple thing is to go into your television menu and turn the television speaker OFF.
Then exit the menu and turn the volume up.. try your headphones now.
Next.. check the back of the TV for a FIXED AUDIO OUT.. plut your headphones into these outputs.. if you have these.. you can simply turn the set down.. and use the volume control on the headphones.
Posted on Apr 24, 2009
SOURCE: How do i set up the Technika TA-709 Wireless
You should have all the necessary cables to do this with the package you bought, the wire which has a headphone style plug on each end should be plugged into the headphone jack on your tv.
If they dont work then there are two further things that could be at fault:
A: The headphone audio volume controls and the actual speaker volume controls on tvs are totally different and if the actual headphone volume is turned down then you will get an interference type noise thru your headphones as no sound is being detected by the reciever and therefore they go into kind of a standby mode. !!!!!!!!!!Try looking in your TV settings menu to make sure your headphone volume is turned up!!!!
B: being an owner of a pair of these headphones I know how audio the cable can easily turn faulty from prolonged use us. The wires can easily break inside but look fine from the outside so get a new one. Headphone jack to Headphone jack cable.
I use these along with my xbox 360 wireless earpiece (fits nicely under the headphones) and I think they're far superior to the Turtle beach headphones +++ My setup is 100% wireless which also makes it better than any turtle beach setup on the market.
Posted on Jan 16, 2010
  • 11800 Answers
SOURCE: New Sony MDR-DS6500 wireless headphones.
Simple test to see if the unit is functional: get a cable like
http://www.amazon.com/3-5mm-Stereo-Male-Cable-ft/dp/B002T4OMG8
plug it in the headphones output from your pc or whatever device which you know it works since you are using it with other regular headphones (even a phone will do) and see if you hear something. If you don't then it's defective, if you hear then the problem is with your HT.
The biggest one is the fact that the only way in which this HT is capable of delivering sound to another unit is thru the wireless S-Air connection which the wireless module from the headphones doesn't support - it can connect strictly only to the module from its base which accepts only cabled connections, which your HT doesn't have..
To put it simply there is no way to connect this headphones to this HT. If you want to use those headphones you will need to get a real receiver and use this HT strictly as an BR player.
Posted on Sep 11, 2011
SOURCE: just bought the brookstone wireless tv headphones.
I had the same problem with Brookstone wireless headset the only solution I found was plug in the red and white connectors to your cable box it works perfectly that way. Just make sure the red cable connector from the transmitter is connected to right red input connector on the box. I have a Comcast cable box. Now I need a solution for them on my PS3?
Posted on Dec 28, 2011
NTD-1356 Auto Channel Scan not finding channels
Cable TV comes from the receiver to the monitor (ntd 1356) thru a cable the ntd 1356 tuner needs the external antenna to be installed to work
Check the inputs for external signals
Oct 29, 2016 | Televison & Video
Static noise coming from headset. The headset has been making this noise for 3 or more days.
Most headphones (wireless) have a tuning wheel that allows you to find your headphone channel pair to base set. It sounds that while checking your foam ear piece you may have moved this dial / wheel. After locating (probably near volume) the control for tune, place headphones on and slowly move control for tuning. You should hear something move control to strongest signal.
your base also has settings switch for channel helpful if you have more then one pair in house, on different TV. Play with both to find best volume.
Sep 04, 2016 | Jabra GN9330 Wireless Headset
Right speaker terminal not working - tested out both speakers and they work fine when independently tested on the left speaker terminal. Sony MHC GX45 Shelf System, 2 speakers and 1 sub.
If the sound is also dead on that channel on a pair of headphones. Then you have probably lost the main power amp for that channel. To be certain. With you headphones on, slide or turn the balance control so you can only hear the faulty channel. With some music playing turn up the volume. If you can hear "faintly" music playing then the pre-amp is OK and the power amp has gone.
The power amp will be located on a heat sink. It will consist of 4 transistors (2 for each channel) or one big device (or two) (an IC). If it is transistors you only need to replace the two for the right channel.
Aug 31, 2013 | Sony COMPLETE PWB, MP-45 Shelf System
Can I watch a DVD and use the WH-930 headphones to hear it better?
Most DVD's have line-level outputs which will NOT drive headphones. You need to run the audio line outputs, which are usually RCA jacks to jacks on an amplifier and then plug the headphomes into that. An inexpensive source for an amplifier is OFTEN at thrift shops. Run the pair of cables into jacks that would likely be labeled TAPE INPUT for example. FInd one that does have a headphone output jack on the front.
Oct 23, 2011 | Sylvania SYL-WH930GB Wireless Headphones
Retuned my BUSH freeview TV and have lost all my BBC channels can anybody help ?
did you get another tv in its place and cant receive the same channels? if so have you did a channel scan for both over the air and thru the cable? usually located under the settings menu
May 14, 2011 | Televison & Video
How do i set up the Technika TA-709 Wireless Headphones to my tv. Have lost the manual and am not getting any sound only static on all 3 channel selections.
Jan 07, 2010 | Audio Players & Recorders
Can't figure out what channel to put radio on to get sound for dvd in car
The only way to hear it through the car radio is if it has a built in fm modulator installed.
Usually the car manufacturers use the lowest (or close to it) number on the dial. 88.7...88.9 etc.
On some factory installed units - you must press SOURCE for the DVD sound.
If it is aftermarket - an FM transmitter is almos alwyays part of the unit - and you'll have to find the proper channel.
Stick in a music CD, and then scan the stations manually.
Some FM Modulators use only 4 selectable channels... and some can use any channel.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 02, 2009 | Televison & Video
TV sound only thru front and sub woofer speakers only
this might be happening because the audio format for surround is not supported by the channel or affiliate of the channel that you are viewing does this happen on all tv channels or is it on just a few? if all sound while playing a dvd is proper and in working order than there must be an issue with the sound and or format of sound from the tv source. maybe more information would help me decipher this
anyways hope it helps
Ryan
Feb 14, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Tuning in to TV with wireless headphones
I need more info on this. What type of tuner and receiver? Is the tuner plugged into the headphone jack on the tv? If you have a tuner for tv that tunes in channels 2,3,5,12,25,60 etc that would be an older tuner that used the older NTSC standard. Tv stations now broadcast using ATSC, channel 4,1, 4.2 etc.
Dec 25, 2017 | Jensen Radio Communications
321 people viewed this question
 Grubhead
Grubhead
