Question about Gateway FPD1975W 19" LCD Monitor
Screen truns blank after starting up
I have a gateway FPD2275W 22 in. LCD monitor....when I first turn on my PC I have the windows logo come on & then my screen turns white.
I can hear the music that comes on while starting up....I can turn my screen off & back on & sometimes that works... I can unplug my screen & plug it back in & it will work just fine....but if I leave my PC on & leave it...my screen will blank again. I have replaced my power cord because I first thought that was the problem. Other than that my PC runs fine as long as I am using it & not letting it go to sleep. Can you give my any advise on what might be going on with my monitor?
Do I need to replace it? or is there something I can do on my end of it to fix it? Thanks for any help on this matter.....
  • BoneDealer Mar 18, 2009
    Ok, I am having the same problems as this person here. But I do not know what you mean by caps. Can you please explain? That would be really helpful to me. Thank you.
  • 56 Answers
Check the caps all eight and the 5v transistor it's seem like it braking down under a load (heat up and shut down)
Posted on Mar 18, 2009
I have a gateway FDP2275W desktop monitor. the monitor will power up and display the Gateway logo in the middle of the screen, then goes black. The monitor is still getting a signal from the computer as...
This is a common problem with many LCD monitors. The
printed circuit board that provides a stable voltage for the monitor to operate
from starts to fail. The PCB can be replaced, when/if they are available, or repaired
in most cases at a much lower cost. for more information on this email me at
Sprint6@zoominternet.net
Dec 26, 2010 | Gateway FPD2275W LCD Monitor
GATEWAY FPD2275W 22" will show everything when unhooked from pc then reconnected but within seconds goes to a black screen. I have 2 and the other one works fine so it is definitely the monitor giving the...
Chances are that some capacitors in the power supply have failed. some monitors are known for this. The parts are readily available, but they do solder in.
Nov 13, 2009 | Gateway FPD2275W LCD Monitor
My Gateway FPD2275W LCD monitor has just failed.
Trying to find replacement parts for your model could be a task. LCDs are so inexpensive these days it would be cheaper to just replace it. Not sure if you have a Frys computer store nearby but I saw a 22" LCD for 129.00. Check your local electronics stores also. If you did find the part for your Gateway consider the cost and installation fees.
Eric
Oct 23, 2009 | Gateway FPD2275W LCD Monitor
FPD2275W No PC or On Screen Menu Display
Bad caps, be REAL CAREFUL when take the bezel out, you can easily damage the small ribbon cable attached to the front bezel.
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Jul 28, 2009 | Gateway FPD2275W LCD Monitor
Fpd2275w monitor problem
Have you unplugged the power cord for 2 min. Try that, there are problems with these "locking" and unplugging sort of "reboots" them.
Jun 01, 2009 | Gateway FPD2275W LCD Monitor
Monitor goes blank after it comes on for two seconds
bad capacitors on the power board internal to the monitor they need to be replaced, let me know what you would like to do
Mar 22, 2009 | Gateway FPD2275W LCD Monitor
Gateway 22" flatscreen monitor won't display after startup
Monitor has blown capacitors internally on the power board I can fix these let me know what you would like to do.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
Monitor screen ia blank
open it and see if you can find a blow capacitor on the logical lcd board...it´s very common to happen in this kind of model...
Good Luck!
Dec 04, 2008 | Gateway FPD2275W LCD Monitor
22-inch Wide screen X2Gen LCD Monitor
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
242 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
