Question about Garden
Removing and replacing tecumseh carbuetor from tc 300 tiller
Need to replace carb cannot figure out correct placement of spacer
  • 42 Answers
SOURCE: Need diagram for this carburetor #632508 or 632508
below is a copy of the only diagram I could find for you. hope it helps! thanks.
Posted on Mar 25, 2009
Remag1234
  • 387 Answers
SOURCE: I have 1980's model troy built pony tiller that won't fire
Great machine, I had one. The points need replacement. Look for a gadget that replaces the points. I found mine in PepBoys. Search the Internet, the cost was about $5.00.
Posted on May 17, 2009
  • 376 Answers
SOURCE: replacement carburetor OHH55 tecumseh 5.5 hp rear
Need the 5 numbers and a letter following the model number to tell you that. :)
Posted on Jun 06, 2009
  • 6 Answers
SOURCE: troy bilt tc 300 tiller that will not start. Have
Pull several times with choke set full if spark plug is not wet you have carborator issue. If spark plug is wet you probably have a bad connection to spark plug in boot or issue with spark lead. Pull spark plug, replug into lead, lay on head and pull rope to see if you have spark. Do not hold onto plug or you may get shocked.
Posted on Aug 21, 2009
01fordeb
  • 1033 Answers
SOURCE: Engine part for Tecumseh 6hp 195cc
The float and pin can be bought as a repair kit., and replaced.
Posted on Mar 24, 2010
Idle surging on 179cc Tecumseh motor
Air to Gas mix is not correct. The carb will need to be cleaned very good and all new carb gaskets in place to work right. It only takes 1 stopped up port or a slight air leak due to dry gasket to cause your problem. Hope this will help.
Feb 24, 2015 | Tecumseh Garden
Troy Built tiller Tecumseh engine carburetor linkage
I've got one of these that I'm working on myself right now, and all the carb linkage from air vane to springs was gone. I had no info. on this TC-2 engine myself. I found a couple of free service manuals from Tecumseh by Googleing Tecumseh TC-2. And then partstree.com has a lot of good parts break downs, I take the parts numbers I need here and then order through my local dealer.
Hope this helps some what and GOOD LUCK.
Oct 13, 2014 | Troy Garden
I have a Tecumseh OHH55 on a wood chipper. I replaced plug, oil, new fuel and cleaned up. I cannot get it to start. Carb was also cleaned. Any suggestions before I take to a repair shop.
Is fuel getting to the carb? Check the fuel line it may be plugged. The rubber deteriorates after many years and plugs up the line and or jets. Its always best to replace the fuel hose when you rebuild the carb. Have you checked for a spark at the plug?
Aug 09, 2014 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Ifound a Tecumseh Yard Machine Front Tine Tiller. It has a 5.50 HP. The tiller seems to choke out every time i crank it up. Can Someone tell mewhere the fuel filter is located???? i have replaced the air...
It sounds as if you still have Carburetor problems.
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked.
(If there is a small screen in the Carb., this can get blocked too. Make sure that it is clean as well.)
Reassemble and start. (If there is a small screen in the Carb., this can get blocked too. Make sure that it is clean as well.)
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Sep 05, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Mar 24, 2010 | Mtd Products Yard Machines 158CC Tiller
Engine will not run/tecumseh enginelstall once it starts/hsk model
I assume this is on a snowblower?
Be sure you have fresh fuel.
You can also remove the bowl on the carb and spray carb cleaner in any orfice you see.
Always store a snowblower with fuel stabilizer in it. Otherwise it the fuel can "varnish" the inside of the carb and cause problem.
If it still doesn't start check compression.
Jan 09, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Oh318 (tecumseh) Runs for a few minutes then cuts off. Starting fluid makes it run for a few sec. then it cuts off again. replaced whole bowl assembly. Cleaned carb in carb cleaner. Blew it out. Checked...
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Nov 21, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Float was sticking ,now will only run if i feed it
Here is a website that will tell you where to look for your particular engine number and how to obtain original tecumseh parts. good luck with it. if you need any other assistance please get back. i really do want to help you get your tiller running again.
May 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Tecumseh HM80 on coleman generator. won"t stabilize, backfires. new plug, fresh gas 'carb cleaned. starts first time'new air filter. any suggestions?
check to see if it has a smeared or worn key way it is what times the fly wheel to the engine if not it is possible that it coul have problem with a valve or engine timming
Mar 01, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
