Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Wont empty water cant find filter
Machine wont spin as the water does not empty, cant seem to find the filter to see if it has blockage.
    President:
  • 1,294 Answers
Plug off the wall socket. Pull out the machine to get to the back. Remove the panel at the bottom where the discharge hose comes out. You should see a black concertina type tube coming from the drum attached by a jubillee clip. The filter is inside. Losen the clip and pull away the tube, take out the filter and clean it out. When you replace it don't forget to put the ball float back in and check it's well fixed by running a spin cycle before sealing up. Don't forget to fit the exit hose in the standpipe.
Posted on Mar 11, 2009
  • Hotpoint Master
  • 3,361 Answers
Remove 3 screws from the bottom front service panel. Pull the panel down...then off. The pump will be in front of you.
Bosch classix 14oo washing machine displaying fault code F18.Wont pump water out but will spin if clothes are taken out.PLEASE can you help?
it could be that its spinning after you take the clothes out because you have given it 2 opportunities to drain/pump out.. once with the clothes in and once when you have removed them. Machines wont spin if the water doesn't drop below a certain level within a designated length of time. The problem might be a simple blockage
Check filter
Check drain hose and pipe its emptying into
Put machine on its soap box side down (very important) and powered off (very important)
Looking up the base of the machine you will see the pump right in front of you
Check wiring
The pump on these machines if I remember well have 1 screw and then you have to twist it to remove it
This will give you a chance to see if something got behind or is wrapped around the emptying propellor
Oct 16, 2013 | Washing Machines
My machine wont spin or turn i took the back off the machine and in the tank there is water in it and wont come out
firstly,the machine will not spin if water is in it.the spin cycle starts when the tub is drained of all water.you seems to have one or a combination of these problems; drainage/blockage/pump motor/no signal/no voltage.does the machine complete the wash cycle?
Nov 20, 2012 | Avanti W789SA Top Load Washer
Zanussi z918 washing machine wont empty or spin although the pump seems to work
if the pump seems to work, check outlet hose for blockage/check pump filter as well
Dec 09, 2011 | Zanussi Washing Machines
Left machine on yesterday, while I was out. When I got home was still bleeping, should have finished about 3 hours earlier. So I switched it off and was still full of water. Emptied it manually this am,...
Hi there. The first thing to check, now that you have cleaned the filter is to check the disharge hose for kinks or blockages. Also, on some models there is a specific height range at which the hose must be placed (maximum height above washer) and a specific method of running to hose to a drain. Some machine models seem very picky about this so make sure the hose is checked for any blockage and that is is located in a correct manner according to your product manual. Ensure the hose is not be squashed between the back of the machine and a wall or other obstruction. The next possibility is a bad discharge motor.
Feb 13, 2011 | Zanussi WJS1265W Front Load Washer/Dryer
Wont spin
Probably down to the water not emptying from the machine in the empty cycle and the machine won't spin because there's still water in the drum. If this is the case, the root of the problem is almost certainly a blocked filter, restricting the draining of the water and not allowing it all to pump out in time during the empty cycle. You probably need to find and clean your filter.
Feb 02, 2010 | Washing Machines
LG washer wont drain or spin
The problem is this, The machine wont spin until it sense that it is empty. So your solution is easy either a faulty pump that wont drain the water from the machine or a blockage in the the filter. There should be a filter at the front behind the kick plate at the bottom of the machine just check to see if you have something stuck in it before you go changing the pump. The easest whether its the pump or a blcokage is to disconnectthe waste pipe and drop it to floor level if the water comes out the machine then its the pump if it does not then its a blockage .
please rate if it helps
Sep 08, 2009 | LG Washing Machines
PE235 would not spin or empty. Now it wont cycle either
Check the filter at the bottom of the machine ,right hand side behind the plastic cover along the bottom. You may find a blockage in there.
Adrian
Aug 06, 2009 | Hoover PE235 Front Load Washer
Washing machine wont empty
hi there this is a common fault empty the water into a bucket and remove the water pump to check for blockages, the pump is located at the rerar lefthand side of the w/m.
also check your drain hose where it connects under your sink.
hope this helps
Dec 11, 2007 | Washing Machines
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
158 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
