Question about Cell Phones
How can I fix my I pod - Cell Phones
    New Friend:
    Problem Solver:
  • 5 Answers
You know your litte white charger cord. ok so unhook just the white cord from the big box that hooks into the outlet. Then plug the cord into the computer. put your ipod on the charger. next go no the enternet and serch itunes. then get on to YOUR itunes and it should tell you whats wrong.
-anna
Posted on Apr 19, 2013
I am tting grounds in my cup using caffitaly pods how can I fix this
Usually low quality pods or pods that have faulty manufacture. Try changing make.
Nov 27, 2016 | Coffee Makers & Espresso Machines
My machine is smashing my pods? How do I fix this?
check inside where you place your pod for debri or a piece of the last pod or plastic piece. once you open your machine where you insert pod. feel around in there or look with a torch
Sep 01, 2016 | Coffee Makers & Espresso Machines
I have an I-Pod touch and all off a sudden CCS stopped sync with my facebook acc ,i have checked both fb + i-pod settings which both enable access for each other but it doesnt help , how can i fix this ?
try updating your I-pod on the iTunes software on your computer if that doesn't work back up your I-pod on the iTunes and then reset your I-pod to factory settings. now if you backed your I-pod up properly then log back into your I-pod with your iTunes account and plug it into your computer, it should automatically restore all your apps and music ect. then you should be able to sync what ever u want again the problembeing is u probanlypicked up a virus or something on your I-pod
Jul 31, 2013 | Audio Players & Recorders
How Do I fix My I Pod Which Is Disabled
First make sure the battery has some charge by using a wall plugin. Then try resetting it by holding down the power button and home/middle button at the same time until it turns off. It should automatically start back up again.
Aug 06, 2012 | Audio Players & Recorders
I have an Ascaso Dream - pod only version. I would like to know if the portafilter is replaceable. I want to exchange it with the model that does both ground and pod coffee. Thx, Rasmus from Denmark
Hi Rasmus,
If your model is pod only - fixed version - then it is not possible to replace the group.
If you have a pod portafilter then it is possible.
You will need: . a new portafilter and ground converter kit Ground coffee converter Kit ASCASO porta filter complete
Sep 04, 2010 | Ascaso Dream Espresso Machine
Philips senseo coffee is watery
It may be the pod holder,there is a seal under the black disc at the bottom of the holder,the water will bypass the coffee under pressure,travel to the outside of the pod holder and exit the centre where the filter mesh is,if there is no foam also this is a sure sign,fill the empty pod holder with water and see how quick the water drips,I had this same issue and bought a new pod holder and compared,should be no more than 1 drop a second,you can knock the plastic out and re seat the O ring or buy a new holder,hope this is of use to you
Dec 27, 2009 | Philips Senseo HD-7810 Coffee Maker
Anyway to use Bose companion 3 system without the control pod?
had the same issue. Trial and error - I tried shorting every pair in the control pod dock with a paper clip. Turns out it is totally possible to bypass. You need two: top row, right side to third row, one from the right (below it by two spaces), and second row (there are only two in the second row, connect them). One tells it to turn on, the other passes audio through. I'm only getting sound from the right channel, so probably need to connect one more pair...
Read more: Can i operate my bose companion 3 without the control pod? - I lost my control pod. can i go around it. :: Ask Me Fast at http://www.askmefast.com/Can_i_operate_my_bose_companion_3_without_the_control_pod-qna6342714.html#q3658086
Jun 29, 2009 | Bose Companion 3 Computer Speakers
Purchased i-pod from walmart- not working
Take it back to wallmart, along with the receit.
Dec 02, 2008 | Microsoft Xbox 360 Console
Bose Control Pod won't work
Try changing the plug on the control pod, those plugs are fairly weak and prone to breakage. Does there appear to be any strain at all on the plug itself? if so then that is where I would start. If you have a series 2 then I can help you, or if you can find out if the 2 control pods are the same, that would be fine too, but I have a series 2 system companion 3 and if needed I will cut my cable to trace the wiring and then replace your plug for you. my cost for this would be $40, that includes return shipping with priority mail.
Oct 03, 2008 | Bose Companion 3 Computer Speakers
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
