Question about Welding Tools
Farmhand 115 volt flux core wire feed welder # DK688519AV 1/05
3 Suggested Answers
luis_david
  • 407 Answers
SOURCE: SMALL PUDDLES NO PENATRATION
Hi:
If you are using flux core wire you need to switch the polarity of the machine. With flux core wire, your ground clamp becomes positive (lead) and your gun the ground. All you need to do is switch the cables above the feed rolls.
That will take care of the problem
If this was useful to you, please vote. Thanks.
Posted on Mar 21, 2011
luis_david
  • 407 Answers
SOURCE: How do you switch the polarity switch on the 115
Hi:
Disconnect you ground clamp form the negative side pole and switch it to the positive pole, same for the gun disconnect the from the positive side and switch it to the negative pole.
Good luck.
Posted on Sep 07, 2011
Wire wont feed on my welder
I would call miller and get a number for the closest repair station. They have a three year parts and labor warranty. 1-920-735-4505
Jan 10, 2015 | Miller Multimatic 200 MIG TIG & Stick...
Very little power at wire
try to use bare .032 wire and co2 shielded gas, If the equipment does not have a gas solenoid you may have to wire a solenoid to the trigger mechanism to get the gas to flow while the wire is feeding. The bare wire usually copper coated burns much hotter than the flux core when there is a gas shield. Also a .032 bare wire with a gas shield burns a a lower amp range and will get better penetration.
You may have to experiment with the feed rate and gas flow to get the correct setting, but the bare wire has a lot less resistance to current flow than the flux core and will burn a lot hotter when you use a gas shield.
At 115 vac there is not a lot of amperage left to create an arc and run the feeder and the rest of the unit , and the flux core wire takes a lot of amperage to burn both the wire and the flux . .
Apr 03, 2014 | Campbell Hausfeld ® 115V MIG Flux Core...
How do you switch the polarity switch on the 115 farmhand versa-arc mig welder. trying to switch from mig to flux core wire.
Hi:
Good luck.
Sep 07, 2011 | Campbell Hausfeld MIG / Flux Core Wire...
SMALL PUDDLES NO PENATRATION WELDER IS FARM HAND 115 VOLT MIG//FLUX CORE WIRE FEED PUT ON ANY SETTING NO DIF CANT FIND MODLE IT HAS CHPOWER.COM WEB ADDRESS
Hi:
Mar 20, 2011 | Campbell Hausfeld Welding Tools
When i weld with my wire feed it pulses what am i doing wrong
you need to ether turn up the wire speed or turn down the heat, also with a flux core you have to be very close to your work. don,t forget your mask!!
Jan 16, 2011 | Firepower Flux Core Wire Feed Welder 88...
Just purchased and tried to use my flux welder. It jams before flux even comes out the handle.
have you tried adjusting the tension on the flux wire? before you start feeding the wire into it make sure there isnt any kinks in the wire. seems like it doesnt take much for it to bind up once you get start welding with it im sure you will run into this problem quite allot. usually its from welding the wire to the tip. i have to be honest it can ve a pain in the ***
Dec 30, 2010 | Firepower Flux Core Wire Feed Welder 88...
Wire won't feed, motor runs and it grips the wire. I can pull it through by hand but it is hard to do .Is something in the line restricting the wire?
I wll check the gun liner and see if it is kinked. Check also your contact tip, must be same diameter as the wire, if you are running flux core wire, oversize your tip, example if wire is 030, then use a 035 tip. Check also drive rolls, for flux core must require knurled drive rolls instead of grooved ones.
Dec 18, 2010 | Campbell Hausfeld 115 volt MIGFlux Core...
Hobart 140 voltage drop when welding in all setting using 30 wire and uni mix gas will start out welding good then will not ?????
Check your input line voltage. 115 volt Mig welders / plasma cutters need stable voltage / current. Test to see if the voltage drops to below 100 volts when welding. If so, find a more stable power supply.
Mar 05, 2010 | Hobart Welders 500505 Handler 140 MIG &...
What is required to switch from steel to gas on light duty mig welders
if you mean from flux core wire to gas shielded wire you will need a tank and regulators,and feed hose from the welder to the tank
Sep 06, 2009 | Lincoln Electric LE 83180 Century...
Flux core welders are burning up tips, insulators, and leads
Try to turn up the wire feed and the volts and pull the cup 1/8 inch past the tip
Nov 30, 2008 | Campbell Hausfeld MIG / Flux Core Wire...
Welding Tools Logo
161 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
