Question about HP OfficeJet 4620 All-in-One CZ152A
OfficeJet 4620 print head removal - HP OfficeJet 4620 All-in-One CZ152A
Hp officejet 4620 does not print with starter cartridge
If printer is in warranty, demand for replacement.
1. Check ink levels in printer..if levels are showing, take out all ink cartridges refill them.
If levels are zero, go for new cartridges.
2. If ink level are showing in printer & physically cartridges having ink, then problem with print head, try to clean the clogged nozzles.
Nov 16, 2014 | HP Officejet 4620 e-All-in-One Printer,...
Hp4620 wont copy pages
Hi try removing the print head, run it under the tap, dry, then replace the head and retry
Aug 12, 2014 | HP Officejet 4620 e-All-in-One Printer,...
How to clean print heads?
There is a tools sometimes on the printer it self under maintenance and you will see clean printheads, and in the HP software it is there also.
Jul 22, 2014 | HP Officejet 4620 e-All-in-One Printer,...
How do i remove the print head from hp office jet 4620
remove all the inks and look for a release lever might be grey in color or black lift the lever and remove/lift the print head assembly from printer... your inks sit directly on top of the print head assembly
May 03, 2014 | HP Officejet 4620 e-All-in-One Printer,...
The scan of color document gives a black and white product
there some reasons :
1- Are you sure to select the copying color not black and white ?
2- try to reset color ink cartridge ,
3- try to select clean print head
i hope that was help you
Mohamed Hejazi
Afaqnama -Libya
ipg@hplibya.com
Mar 21, 2013 | HP Officejet 4620 e-All-in-One Printer,...
Hp 4620 printer doesn't print black ink
i have same problem and have tried everything suggested on HP website. I can print in color but not black and white
Nov 08, 2012 | HP Officejet 4620 All in One
Blurred officejet 4620 photo
Have you checked to be sure that -
  • you've designated the paper type as one of the photo type papers?
  • you've designated the print quality as either Normal or Best (NOT Draft or Quick or similar low-quality print)?
  • you're using one of the photo-type papers?
  • none of the ink cartridges is low on ink?
Sep 17, 2012 | HP Officejet 4620 All in One - CZ152AB1H
HP OfficeJet 4620 All-in-One CZ152A Logo
811 people viewed this question
Seeker5211
Seeker5211
