Question about Craftsman Pump Out Wet/Dry Vac Pump Accessory
Replacement impeller for Craftsman wet/dry vac pump
The pump impeller of the Craftsman "Pump OUt" wet/dry vac pump broke after one use. Does anyone know of where to find a replacement impeller?
reddevil6
  • 1673 Answers
SOURCE: need replacement manual
Go to Sears.com, click on the parts link, put in your model number, a parts list will come up, if you manual is available, you can click on it to buy it.
Posted on Jan 22, 2008
  • 1314 Answers
SOURCE: Craftsman 20 Gal Wet/Dry Vacuum model number 17762
you did take the filter off before useing it wet didnt you make sure the check ball in the filter housing is down in the cage and that the top is locked down properly
Posted on Feb 13, 2008
SOURCE: craftsman wet/dry vac
It is supposed to have a round plastic plate and a plastic handle with a nut made in it that tightens against the plate to hold the filter on
Posted on Feb 27, 2008
MrScary66613
  • 1990 Answers
SOURCE: Craftman Canister Wet/Dry vac- Motor just stopped working
It is Repairable But, The parts will cost almost as much as a New Vac. I would just get a New Vac and save the Hastle and the Cash. The choice is all yours Though. Please Rate My Response! Thanks!
Posted on Feb 07, 2009
bozcro
  • 867 Answers
SOURCE: Wet/Dry Vac Leaking
are you using a water , foam material filter?
Posted on Aug 01, 2009
Who made craftsman wet/dry shop vacs in the late 70's?
here is a link that may be helpful
http://vintagemachinery.org/craftsman/manufacturers.aspx
it details the manufactuars that craftsman used based on then model and OEM number
Feb 08, 2013 | Vacuums
Aquamate basin pump does not work. Used it 3 times, stored it for a year and pump does not work. Looks like a reliability issue. Is this product defective for everybody? I saw an ebay listing for the...
Hmmm............ looks like the impeller is already stuck from a year w/o using it!
I suggest if u could open it and spray some penetrating oil on the bushing of the pump motror and the impeller, force the motor to turn manually to set it's rotor FREE. or just POUR some penetrating( I usually use BRAKE FLUiD ) oil in the pump and let it seat for a couple of days.
If don't have a knowhow in opening and repairing such machine, u coud bring it to ur tecnician or service center to fix that up!
Hope that helps u out!
Dec 02, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Not working after vacuuming water.
Your wet/dry vac came with 2 filters.
Paper for dust and dirt and Foam for wet/dry use.
If you left the paper filter on and tried to vacuum a wet surface, you most likely shredded your paper filter and clogged the outlet vent above your water shut-off float.
You should always use a filter to prevent clogging of the cyclonic impeller blades next to the motor. When extracting water or moisture you will need to use the Foam filter to prevent water from collecting in your fan blade area which then creeps to the motor eventually causing it to seize up.
Mar 15, 2010 | Craftsman 17776 Canister Wet/Dry Vacuum
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
Wet/Dry Vac Leaking
Aug 01, 2009 | Craftsman 17762 Wet/Dry Vacuum
How do i turn the pump on to pump out the water this is a 16 gallon 5.75 peak horsepower wet dry vacuum.
If you want to get water that's in your vacuum, OUT of your vacuum, you simply need to remove the top and dump the water out. As far as I know, the Shop-Vac 962-16-00 won't "pump out" any water that's in it.
If you want to pump water from one place to another (for example, your basement to your backyard), this vacuum doesn't pump water "through" itself (like a sump pump) - it will, however, **** water up. You just need to dump it out once the vacuum is full.
Jul 08, 2009 | Shop Vac 962-16-00 Ultra Pro Canister...
Feb 07, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
Need replacement manual
Jan 01, 2008 | Craftsman 17740 Wet/Dry Vacuum
Sep 01, 2007 | Craftsman 17026 Wet/Dry Vacuum
Craftsman Pump Out Wet/Dry Vac Pump Accessory Logo
62 people viewed this question
Top Craftsman Vacuums Experts
Tim Doolittle
Tim Doolittle
 steve
steve
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
