Question about Singer Confidence 7469 Mechanical Sewing Machine
How do I take the machine apart #7469? Where I plug in the foot the plug thing went into the machine
I don't want to have to bring it in for repair. But I don't want to damage it either. I took out all of the visible screws. But it isn't coming apart.
    Scholar:
  • 99 Answers
I'm not sure I understand the problem. Is it the foot pedal that you want to remove or is there a problem with it? Exactly what is the problem you're having?
Posted on Apr 19, 2013
  • Meg Moe
    Meg Moe Nov 29, 2013
    Sounds like the same problem I'm having. We are just trying to take apart the machine at home so that we don't have to take it in but I can't get it to come open.
I have a new singer 7469 confidense quilter - regardless of thread, needle, and material (all being appropriate for one another) the upper tension always pulls the bottom thread to the top. I have tried...
1. Adjust the bobbin tension tighter. The tension you are trying for is to be equal to the top tension.
2. The top tension should start at about four. When you are threading the top do it with the pressure foot up.
3. As you are threading the top give little tugs to check for snags.
4. When you thread the tension control make sure it goes through the tension disc.
5. After you have threaded (except needle) lower the pressure foot.
6. Give a tug to see if the thread will move without excessive resistance.
7. Thread the needle and try sewing.
Feb 28, 2015 | Singer Confidence 7463 Computerized Sewing...
My singer 7469 lights are all blinking she won't sew
flashing lights, beeping sound are error signs its posiibly the upper tension path is not threaded correctly. Check that the transparent thread path located at the top of the machine is threaded correctly.
Hold thread in both hands and slip under transparent thread guide. While holding the thread securely, pull the thread towards you and then slip it back and forth like you were flossing. You should hear or feel two clicks as the thread slips past the thread guides. 2ca6d1db-fd79-4114-9d73-88b025c69c68.jpg
Sep 23, 2014 | Singer Confidence 7469 Mechanical Sewing...
Lights all blinking my sewing machine won't do anything
If you still have the warranty card, bring it back to the dealer and ask for a check or better still replacement.
I have a singer confidence 7469 quilter, the upper thread keeps bunching up in the bobbin case. I've tried re threading numerous times with no luck.
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
Jan 29, 2013 | Singer Confidence 7469 Mechanical Sewing...
Cannot get the auto buttonhole to work..it beeps and I can't find the problem
there is a button hole lever to the left of the needle & you pull it
down gently against the button hole foot & the beeping should
go away
Aug 25, 2012 | Singer Confidence 7469 Mechanical Sewing...
What's your problem?Have a TOYOTA EZT9000 and it seems to have slowed quite a bit. Does it need oil? If so, where do I put it in?
there are other things that can cause the machine to slow down
like the motor, foot pedal, have you checked these things first
1. is the power cord plugged into the outlet securely
2. is the power cord plugged into the machine correctly
3. is the foot pedal plugged into the machine correctly
4. is the cord to the foot pedal caught in the foot pedal
if none of these are the problem, then the machine needs to be serviced
to see why it's running slow
May 01, 2012 | Toyota EZT9000
What's wrong with the machine when the thread is skipping on top and bottom.
hi, it could be several things
damaged needle---try new needle
needle is not correctly inserted into machine----flat side of the needle goes to the back of the machine
wrong size needle for the fabric--choose a needle to suit thread & fabric
the wrong foot is attached--select correct foot
if you check all these things & they don't help then it's possible the machine is out of time
Sep 08, 2011 | Simplicity Creative Spirti PLus SA2200...
When I plug my machine in, it starts sewing very rapidly. I inherited it and am unfamilar with it.
The capacitor in the foot control has blown, undo the foot control and take out the little silver square thing and throw it away, you don't need it
Aug 05, 2011 | Sewing Machines
Have a singer 7469. thread got jammed and bobbin was stuck. cut it apart but now the needle is hitting the bottom of the bobbin casing compartment. could it have shifted. looks like there is a channel for...
Did you change your needle to a new one? If it is bent or has dropped down, there will be a problem like you are describing. Or you may have bent the shaft for the needle, hopefully you will be able to fix it yourself.
Jul 26, 2010 | Singer Confidence 7469 Mechanical Sewing...
Singer Confidence 7469 Mechanical Sewing Machine Logo
149 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
