My gaming screen.
My game screen is small and I cant figure out to make it full screen.
my loptop is 4730z.
In order to keep playing your game, how do you enlarge your screen for the slot games, its very small?
in game settings there should be a box that says full screen tick box or un X the box.
Mar 01, 2016 | Video Game Consoles & Games
When i play my game i cant see the whole screen how do i fix it?
If you are playing pogo games ?
Pogo.com is an online gaming website where you can play well-known games such as Monopoly, Battleship and Scrabble -- along with scores of other board, word, puzzle and arcade games -- in a Web browser window. The games on Pogo are programmed using Adobe Flash, and are viewed in a small box inside the browser. If your computer has a large display, you may find the games difficult to see because of the of the game box. Although you cannot independently adjust the of the Pogo game box, there are several tricks that you can use to make games appear larger on your screen. Magnify the browser window. In Internet Explorer 9, click the gear-shaped button in the upper-right corner of the screen, and click "Zoom" and "Zoom In." Browse in full screen mode. In Internet Explorer 9, press the "F11" key to enter this mode, and press "F11" again to leave it. Lower the screen resolution. In Windows 7, minimize the browser, right-click the desktop and select "Screen Resolution." Click the drop-down menu next to "Resolution," and select a lower resolution than the one currently displayed. Because a lower resolution uses less pixels to display the information on the screen, this has the effect of making the Pogo game box larger. Remember to change the resolution back when you are done playing. Disable the address and status bars in Internet Explorer 9 if a portion of the game window is cut off. Click the gear-shaped button, and then click "Internet Options." Click the "Security" tab, then click the "Custom Level" button. Click the "Enable" radio button next to "Allow websites to open windows without address or status bars," then click "OK" twice. Close and re-open your Pogo game window. Press the "F4" key. Some Pogo games enter full-screen mode when this key is pressed, but many do not. Hope this helps.
b>
Dec 29, 2012 | Dell Dimension 2400 PC Desktop
When i open Cue Club in win7 (laptop model-acer aspire 5738z), it opens in a small square screen rather than full square screen. my pc's resolution is set as maximum. can any one suggest how to play the...
Check the in game options of the game itself. Somewhere in there should be a check box option allowing you to choose between full screen and windowed mode.
If there is no option, then find the shortcut to the game, and right click on it. Then click on properties. On the command line (that leads to the actual game file) go to the end and see if it has -window at the end of it. (might look like c:\program files\egames\cue.exe - window) if you see that window part (or win in some cases) then delete that and see if that helps.
Don't forget to Rate :)
Aug 13, 2010 | eGames Cue Club for Windows
H233H cant go full screen
Resolution (gaming resolution is based on game and will change. your desktop is different
Oct 02, 2009 | Computers & Internet
Scrabble on laptop (vista) went from full screen to small screen
Hey,
Go to graphics options inside your scrabble menu and turn off windowed mode.
Hope this helps.
Thanks
Apr 10, 2009 | Video Game Consoles & Games
Compatible games for my loptop
hai
you can play any games which requiers 128mb of graphics card
not a games like advanced 3d graphics game
see the game requriement before installing
if you install more games the system might be slow
Mar 20, 2008 | Acer Aspire 5610 Notebook
When i install a game and when i start the game game run only on my 1/3 of the screen. means the game not run on the full screen so i can seen the small text and can't play some puzzle game due to...
it sounds like u r trying to run games which r ment for smaller screen ph and not for n80, which game(s) u installed? any game or som selected games?
hav fun!
shuweb
Mar 11, 2008 | Nokia N80 Cellular Phone
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
