Question about Amana ABB1927DE Bottom Freezer Refrigerator
RESET SWITCH? WE WERE VACCUMING THE BOTTOM OF FREEZER AND MUST HAVE HIT A SWITCH BECAUSE IT QUIT RUNNING! DOES ANYBODY KNOW IF THERE IS A RESET SWITCH?
    New Friend:
  • 102 Answers
Maybe the breaker kicked off, might have hit a wire, or maybe it just shut off when the temp was right but you should never vaccuum under neath with power on for that reason could be dangerous.  Not to say some have fans. If the breaker has not been thrown Try raising the thermostat and see if it starts, hope this helped.
Posted on Mar 11, 2009
Maytag MFI2269VEM2 Freezer issue. In the past two weeks, twice ice has built up in the freezer so much it is causing the fan to stop working and has been running really loud. Twice now we have taken the...
it is not defrosting. timer ,element , limit switch maybe issue. find defrost timer advance it see if compressor and fan quit running. when you advance this it should start defrost mode, which turns on the heater, which stays on till limit switch opens or timer advances, most are on 12 hour cycles
Oct 02, 2013 | Freezers
Freezer fan quit working after ice took over (kids kept leaving freezer door open) we defrosted and the temp will not drop below 40 degrees is there a reset to restart the fan?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
No,
Probably wrecked the fan motor...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Samsung RB195ABBP (187 cu ft) Bottom...
Was vaccuming and vaccum quit. Tried unplugging and turning back on. Getting absolutely no power. unscrewed screw under handle and tried to make sure connection was being made. Don't really know what to...
ok..If you have a multimeter you can check plug fuse then switch and motor, if you put leads across the plug you will get some reading if its working.could be thermal cut out on the motor.
Apr 18, 2010 | Kenmore Magic Blue 24195 Bagged Canister...
I have an Amana bottom freezer, model BX20S5E that is not cooling properly in either compartment. I have replaced both the defrost thermostat and defrost timer (new). Still no change... what I do notice is...
check door gaskets and see if problem is moisture,or air gate to fridge compartment not working properly.I would recomend verifying defrost cycle is working by turing defrost timer to defrost cycle,it will click when engaged when unit is frozen and heater should come on if all is well,if not heater is probably culpret if the rest is new.
Apr 09, 2009 | Amana ARB8057CSL Bottom Freezer...
Ice Maker quit making ice cubes
Look on the bottom of the rectangular motor housing for the ice maker. This is the white box that holds the front end of the ice tray. In the past, this was normally a small patch of black 'runner' that covered the switch and helped kkep moisture out.
If you cannot locate it by feel, try using a small mirror and a flashlight to help you locate it.
Jan 02, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
NEW FAN WILL NOT QUIT RUNNING
Hello.
How long did you wait after installing the fan? It takes 24 hours for the unit to recuperate.
If the fan hasn't been working for a long time, you may have not noticed it was running a lot, but with the new fan you can hear it. Let me know if you don't think this is the case and I can guide you through some other options.
Dec 03, 2008 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Kenmore fridge
First we need to see if the compressor is running.  Pull the fridge out take off the lower panel on the back and see if you can hear it running.  Also, need to know if freezer fan and fan by compressor is running.  Check for thick frost build up on back panel in freezer.  Let me know what you find.
Oct 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator
The freezer not running for several hours should not allow food to thaw. One thought is that the heater on the evaporator coils is not working.
Oct 19, 2007 | Samsung RB2155 Bottom Freezer Refrigerator
Amana ABB1927DE Bottom Freezer Refrigerator Logo
221 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
