Question about John Deere Pto Clutch For Stx38 And Stx46 Lawn Mowers
Jd 46 will not start even with new battery it will start if i go strait to the starter
  • 27 Answers
Bad ignition switch
Posted on Mar 16, 2014
My 3020 JD tractor won't start. Lights on dash come on and dim when i turn the key to start. No noise nothing.
If it's not a bad battery connection somewhere in the cables, then you need to test the starter motor. Can you jumper a wire from the starter solenoid connection to the battery connection on the starter? If starter cranks the engine over, a problem is in the start circuit between the ignition switch and the starter solenoid. If starter doesn't crank, either the starter motor or the solenoid is at fault.
Apr 26, 2017 | Cars & Trucks
John deere srx 75 starting with key doesn't work why
if u wiggle the gear shift lever , holding key to start does it work ? if so then u need a new or adjustment neutral safety switch (also key does have running deere on it ?) as non factory keys don't work to well either
also this machine is listed on jd tech site as one that has been noted for an "starting improvement kit " part # - AM107421 jd has made it plain that they know it doenst start so well ,so they have released this kit to install that improves its starting
May 25, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Why ent there enough power going to my brand new starter motor seems to spin slow when i connect strait from battery
hook a volt meter up to your battery you should see around 12.5 volts. Then crank the engine and see what the voltage drops to. If it drops to less than 12 volts the battery is bad.
Sep 16, 2015 | Cars & Trucks
My starter does not turn.Relay checks good.How do I remove starte
Just do the bench test on the bike,(use jumper cables to bypass the relay and go strait to the starter with power from a good battery.) You could even do this with the key off.
May 05, 2010 | 2000 Harley Davidson FLSTC Heritage...
Subaru ea81 starter solenoid wiring diagram
Some starter solenoids are mounted on the fender near the battery and some are on the starter itself.
Typically the ones mounted on the fender have two larger posts and one smaller post. For the larger posts: One connects strait to the positive post on the battery. The other connects strait to the starter. The smaller post connects to the neutral safety switch which connects to the start position of the ignition switch. Here is a diagram. Make sure the solenoid is grounded good.
For the solenoid that is mounted on the starter: Connect the positive post of the battery to the large post on the starter. Connect smaller neutral safety switch/ignition switch wire to the smaller post.
Here is a diagram if you have both solenoids
Don't forget to hook backup any other wires that were hooked to the positive side of battery/solenoid like alternator wire etc.
Sep 11, 2009 | 1987 Subaru Brat
I have a jd 100(?) series riding mower that has
First, charge the battery.(Always do the easier things first). If that isnt the problem, take a DC volt meter and check the voltage where the battery connects to the solenoid. Then check the voltage on the starter side, while you turn the key,If there is a large voltage drop, or no voltage, replace the solenoid. If voltage okay, then check the starter. Good luck...Lee
Aug 22, 2009 | Garden
I have trouble starting my 316 JD tractor. When I
I do not have answer I will like to have an answer for my 316 JD no power no lights on dash battery new and was running shot off and wont stared again.Thank You
Aug 15, 2009 | John Deere New Tractor Starter w/ 317...
Mower will barely turn over. new starter and batt.
not 100% but i have a JD 345 that i just went through the same scenario with, turns out the pto cluch was froze up, take the clutch off (can be a pain, medium size gear puller a plus) and see if it turns over. new clutches are a lot less expensive than a new mower!
May 06, 2009 | Garden
John Deere Pto Clutch For Stx38 And Stx46 Lawn Mowers Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
