Question about Danby DCD5505W Electric Dryer
Dryer runs but wont tumble - Danby DCD5505W Electric Dryer
  • karin froysa Apr 02, 2009
    dryer works but tumble drum will not move it has locked it self what can i do to solv the problem single mum
    bosch maxx tumble drum has stoped moveing is locked heat is ok makeing strange noises how can i fix it karin
  • 221 Answers
Try checking to see if the dryer belt is broken, the dryer belt wraps around the drum and goes to a motor at the bottom of the dryer that turns the drum, if so you can usually get a replacement belt from the maker of your dryer by visiting there website.
Posted on Mar 11, 2009
  • Danby Master
  • 3,361 Answers
Replace the belt.
  • sheenamaltby Nov 04, 2010
    were does thebelt go on the drum and how does it go in the motor?
2 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: dryer runs but inside canister wont turn
Not sure I fully understand your question but it sounds like the problem is that the drum isn't rotating when the dryer is started. Depending on the model, that is probably ( but not always) the drive belt. Please consider including the brand and model of your appliance so that answers can be tailored to that specific application.. Hope this generic answer helps you...
Posted on Oct 06, 2008
MED9700SQ dryer sensor light comes on but will not run
I have the same problem with the same model Maytag dryer. I called a repairman and paid a hefty service charge and the repairman found that the electronic control board needed to be replaced. This particular part (Part #8558455) costs between $250 and $350. Evidently there are many people with the same problem.
Feb 02, 2013 | Maytag MED9700S Electric Dryer
HI, MY ADMIRAL TUMBLE DRYER WILL NOT START. THERE
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 28, 2010 | Dryers
Dryer wont tumble
i think the belt is slipping bad on your dryer,,
what puzzels me is you say you can here the motor hum? is it a hum? or a buzz?? if its a buzz then its more likley to be the motor as its past its best and it needs if it needs a new motor as well, it would work out cheeper to buy a new tumble dryer
Nov 16, 2009 | Dryers
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
Hotpoint ctd40 t dryer. wont start just ticking.
do you hear anything running?,might have broken the belt or idler wheel,motor runs but no tumble,need to look inside,warning !! unplug ,high voltage.be carefull
Sep 22, 2009 | Dryers
My dryer wont tumble
Your belt is not installed correctly. The weight of the clothes is making it slip.
Jun 30, 2009 | Maytag SDE2606 Electric Dryer
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Tumble dryer
No. What brand is it? Is it running but not tumbling? Is it gas or electric? What model number. Let me know!
Nov 15, 2007 | Dryers
Drum wont turn on my creda t622cw tumble dryer
my tumble dryer drum wont go round
Danby DCD5505W Electric Dryer Logo
437 people viewed this question
Top Danby Dryers Experts
Tim Whalen
SHARCNET-USA
SHARCNET-USA
Are you a Danby Dryer Expert? Answer questions, earn points and help others
