Question about Home
Only hot water comes out of single handle shower faucet
    Problem Solver:
  • 13 Answers
It sounds like the cartridge needs to be switched around. And the temperature limit stop adjusted higher.
Posted on Apr 21, 2013
  • Bruce Chalmers Apr 21, 2013
    Shane,
    I had adjusted the hot limiter and it was not the issue. I took apart the cartridge and flipped the little valve at the back of and now only the cold water runs
  • shane Apr 21, 2013
    you could turn the water off,then take cartridge out,and the two spring and seats. then close shower curtain and turn water back on for 2 seconds then off. repeat this 3 times to make sure nothing is blocking inlet pipes. when you shake the cartridge in your hand you should hear a clicking sound. if you dont hear anything you need to change the cartridge. that means the pressure ballance is not working.
4 Suggested Answers
  • 297 Answers
SOURCE: No hot water flow from faucet/shower
change the cartridge it is bad or defective.
Posted on Jul 20, 2009
  • 349 Answers
SOURCE: Single-handle Glacier Bay shower faucet, hot/cold reversed
Behind the handle check to see if it has a dail to take out and replace at a different postion this will change the hot and cold. It a anti scald protection device. Don't remove cartridge just adjust dail.
Mark where you start and take out and move a 1/8-1/4 turn at a time and replace til temp desired. It has teeth like a gear you move to adjust temp.
Posted on May 16, 2010
  • 349 Answers
SOURCE: & Single Handle Shower Faucet : how to adjust to get hotter water...
First step remove handle and behind it there is a dial that looks like a gear. Mark where it is and remove it and put back in about a 1/4 to 1/8 turn counter clockwise to increase to hotter temp.
These faucets are equiped with anti scald setting's to protect the public and preset for this reason.
Posted on May 20, 2010
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
I have Danze, single handle shower faucets that were professionally installed in 2005. One shower faucet has not hot water, just cold and when the handle is turned on all the way to hot, there is an itty...
Replace valve canister- no construction- just remove after taking time to shut off water- a few screws and the job takes 15 minutes. I take for granted you have good water hot/cold to the fixture. This fix will cure most temperature balance problems.
The single lever system is a EZ care system. Note the canister can malfunction faster when exposed to untreated hard water.
Nov 17, 2010 | Danze & Single Handle Tub And Shower...
No hot water on Moen single handle shower faucet. cold ok and shut off is fine
do you have hot water elsewhere? if not, might be that your water heater is not heating.
if you do have hot water elsewhere, did you let the faucet run for a minute or 2.
did you have hot water before? is this a new house? new valve?
need a little more detail.
on posi temp valves, if there were no water coming out of the hot side of the valve, the valve will not operate.
Aug 12, 2010 | Moen 1 Handle Lever Shower Faucet With...
Water is not very hot.
First try adjusting the pressure balancing gear located right behind the handle. If you still do not have hot water I suggest to replace the cartridge.
Jan 13, 2010 | Delta & Single Handle Shower Faucet
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Oct 07, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Jul 20, 2009 | Delta & Single Handle Shower Faucet
Home Logo
65 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
