Question about Gateway GT5056 PC Desktop
Print to large on my monitor.
The printing on my gateway is so large I can not get to the 'approval' button to change it.
  • Harry333 Mar 11, 2009
    On the right track.....that solution did not work for the icons and tool bars....the resolution on those is huge...help please
    Problem Solver:
  • 14 Answers
If you are using internet explorer, you can hold down the Ctrl key and hit the - key to make the text smaller or the + key to enlarge the text. If you have a wheel mouse, hold down the Ctrl key and turn the wheel on your mouse, and that will make it larger or smaller. If you can get to the view tab click it then text size, I have mine set on medium. Good Luck.
Posted on Mar 11, 2009
Output is blurry on my new VN247H monitor
Try going into display settings and change resolution
Nov 19, 2013 | ASUS VN247H-P 23.6" Widescreen LED LCD...
Print Screen button will not print to printer
use programs like paint to capture print screen then print from there
Jul 20, 2013 | Computers & Internet
PRINT ON EMAIL TOO SMALL
In firefox, click on file->print preview..at the top of that page will be a box with scale to the left of it...click on the down arrow and change the percent to a higher one. Print just a few words and see if it is large enough for you...adjust the per cent as needed...
In internet explorer,click file->print preview....there will be a box with a percent in it...click on the down arrow to change it....
Aug 29, 2012 | Gateway GT5220 PC Desktop
Print Screen on Gateway 820gm
You need a printer attached to your computer.
Print Screen
Use this method to print screen.
Press and hold down the Alt key and the press the PrtSc key, this places thescreen image into the Clipboard. .
Open a blank Word document and then Click on Edit - Paste.
The image is then places onto this page, you can up the image by holdingdown the Shift key and then place the cursor on the bottom corner of the image,then press the left mouse button and drag it down to the right, release themouse button when you have d the image to your requirements.
NOTE - Holding down the Shift button will maintain the image in the correctproportion.
You can now print this image document and or add text before printing.
Apr 04, 2012 | Gateway 820GM (827103045345) PC Desktop
Is it at all possible to print on a Canon IP 4500 when the large black cartridge (for text) runs out? It ought to be possible, when all other cartridges are far from empty.
it is possible, when it shows catridge emtpy error press and hold the resume button for 5 seconds
also change the paper type from plain paper from photo paper so that the printer only uses the small black catridge for printing black docs
Apr 16, 2011 | Office Equipment & Supplies
The print on my screen is too large. I don't know what I did wrong - but I've hit a button (or something) and it's too wide. Can you help me 'shrink' it back down. Thanks.
If you are using windows xp go to control panel then apperance and themes then select screen resolution and change to suit.
Dec 01, 2010 | Computers & Internet
My icons and tool bars are so big nothing I bring up fits on the screen.....I can make the internet smaller with the mouse wheel, but it shows in a very small space because of the very large tool bars....
Here are some tips to help you move around when you can't see other parts of the screen
Alt + Tab (hold down Alt and press tab) will move you between open windows
Tab will move you from button to button and to the file menu at the top
Shift + tab will move you back, for example if you hit the tab key one too many times
Alt + F4 will close the open window, if no window is selected it will bring up the shutdown computer screen
F5 will refresh a page on the Internet
F11 will switch between Full Screen mode and not full screen mode
So try getting to the "approved" window and then using tab to select it.
Mar 11, 2009 | Gateway GT5056 PC Desktop
Status Monitor informs of Ink levels requiring me to press resume button during and after each print job.
What it means is the tank to collect waste ink (from cleaning etc) is full.
Canon suggest you return ther printer for replacement of the absorbant mat, suggest you scour the web for DIY cures.
Oct 19, 2007 | Canon i9100 InkJet Photo Printer
Monitor is blank, power is on
it was on after it went blank & again on means there was a loose connect as it came back on. but now that loose contact has got permanent due to print breack or track open. the problem is in 1 monitor to computer connector not properly connectec. 2 crt base loose 3 track open or print in power supply. 4 if it is ok check for horizontal section print or loose. hope this will help good luck. 1 power supply print b
Sep 28, 2007 | Gateway FPD2275W LCD Monitor
Japanese language-- i want english
Hi there ! Press 'Main Menu' (first button from the bottom), then go into 'Advanced', which is 2 tools forming a X. In that one, go into the Globe logo which is language. You'll be able to change languages in that one ! Here is a link for the user's manual of this model, which you can print or just browse online, it describes it well : http://support.gateway.com/s/Manuals/Monitors/8512088.pdf Hope that helps ! cheebster.
Jun 18, 2007 | Gateway FPD2275W LCD Monitor
Gateway GT5056 PC Desktop Logo
65 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
