Question about Goodman CKL36AR36 Air Conditioner
Goodman GPH1430H41AA package unit
Package unit tubes freezing up after metering device
check refrigerant charge. A low charge with cause what you are experiencing.
Jun 30, 2014 | Goodman Manufacturing Goodman GPH1342M41...
Goodman package unit heat strips will not turn on
Put meter probes at in put terminal of the element if you read 220volts that mean your relay is good. if you got it there use amp meter on one leg of that element. You should read some amp draw there but if there is no amp draw it mean the element broke.
Nov 29, 2013 | Goodman Manufacturing Goodman GPH1530M41...
Goodman package unit will not. Come on in heat
sounds like a defective thermostat. try a replacement.
Jan 23, 2013 | Goodman Manufacturing GPG1342090M41...
How to wire high voltage goodman straight a/c package gpc1324 unit with 8kw heat kit
do any one have a old package unit is a goodman i want to see were heater on that package uint or take picture of that unit so i can see where the wire go at the heat
Aug 17, 2012 | Goodman Heating & Cooling
I'm trying find out if my old goodman unit was a
Hello WESLEY The unit mod# is 3 ton.If the inside part has an 048 number means together it produces 3.5 ton.If inside is 036 it is 3 ton together.If it is a split.If it is a package it is 3 ton.
Aug 02, 2010 | Goodman Heating & Cooling
Need wiring schematic for a goodman 4ton unit model #mle48-1b
There should be one packaged with the unit. Shut off the power and open the metal enclosure around the control board.
--W/D--
Aug 18, 2009 | Goodman Heating & Cooling
Gas Package Unit Keeps Running with all T- stat wires unpluged at the unit?
does that unit run heating or just the fan run? if just the fan you may have a bad fan thermostat
Oct 21, 2008 | Goodman CLQ36AR49 Air Conditioner
My goodman seer 13 package heatpump stopped blowing cool air. Fan still works, there is power to the unit.
Is the outside unit starting and fan blade spinning? Have you inspected you air filter recently?
Sep 15, 2008 | Goodman Heating & Cooling
Goodman CKL36AR36 Air Conditioner Logo
81 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
