Question about Haier Refrigerators
I have two Haier model DD400RS refrigerators, both units are not cooling.
Where the temp shows on the display it is flashing EE what is the problem with the units as they are not cooling?
  • fgwhite
    fgwhite Apr 19, 2013
    By turning the power off at the electrical panel and back on the problem has been solved thank you
fridgetech
  • 473 Answers
SOURCE: Items sometimes freeze on refrigerator side of unit - model GSS25LGMA
It is most likely a bad damper motor.  This is where the cool air comes out into the fridge section.  On this model it is a fairly common problem and comes a whole assembly.  The part # is WR49X10091 and will cost anywhere from $100 to $122.  Knowing this model I would bet this is your problem.  If the damper is bad and stuck open cold air will just keep blowing in.  It is suppose to open and close based on the temp setting.  Let me know if you have any other questions.
Posted on Oct 11, 2007
SOURCE: Samsung RS2533SW freezer not cooling problem
mine did the same thing. It was the mother board.
and guess what? they don't sell that motherboard anymore.
I will never buy Samsung again!
Posted on Dec 15, 2007
SOURCE: Samsung twin cooling fridge/freezer model
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Posted on Aug 01, 2008
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
Posted on Apr 20, 2009
SOURCE: Danby Kegerator is beeping and flashing EE and won't cool
I am having the same problem seeing if you found a fix??
Posted on Feb 15, 2010
Haier Wine Cellar, Dual model, displays EE error code and was heavily iced on the interior back.
If the refrigerator or freezer displays error code, request a technician to check, please call the service
Different series display different error codes.
The error codes for the refrigerator: F1, F2. F3, F4, F5, F6, F7, EO, E1, E2, E6, Er, Ed, an so on
The error codes for the wine cellar: F1, F2. F3, F4, F5, H1. H2, A1, A2, E1, E2, EE, HH, LL, and so on
Notice: If you power off then power on, maybe the error code disappear, but it will display again after a few hours.
Mar 27, 2018 | Haier Refrigerators
Haier model BC112G. When I plug it in, the temp light flashes. Why doesn't the compressor start and it will not cool?
Bought a couple of small refrigerators (Haier) and brand new they weren't very cold. There was a real small screw in behind the temp control. If I remember correctly you turn it clockwise for cooler and counter clockwise for warmer. Try checking that out.
Jul 04, 2015 | Furniture
Temp display is flashing "ee" but seems to be cold inside.
EE mean that the cable between the mainboard and the display have a problem. I think it doesn't affect the coldness of the unit.
There are an explanation manual behind the back bottom panel.
In my case soon after having reset this error, the cable melted and took in fire.
How to check:
There is a black panel under the two drawer with 2 screws (left/right). The board is behind, the cable which melted in my case was a grey one connected to a black one.
Aug 28, 2013 | Haier Dd400rs Refrigerator
On the temp display it is flashing EE. Any thoughts on what I should do?
unplug unit wait a few secounds then plug it back in and try it may reset.
Aug 06, 2013 | Haier Dd400rs Refrigerator
Haier Model HRT02WNC compact refrigerator not cooling what type of gas does it use?
this model is thermoelectric and has no gas in it.
It uses a peltier junction to provide a temp differential. the fan will run constantly, and it will cool the interior to about 35 degrees F below ambient. theoretically...
May 16, 2010 | Refrigerators
THE UNIT DOES NOT COOL ANDY COLDER THAN ROOM TEMPERATURE.
does the compressor run ? if so you could have a low refrigerant charge, a sealed unit resrtiction, leak or defective compressor.
Apr 30, 2010 | Haier HVUE08A Wine Cooler
Aug 26, 2009 | Danby DKC645BLS Compact Beverage Cooler
EE Flashing in the in the humidity LED indicator
Hello rich784,
Welcome,
You said, unit is working but I'm not getting a % read out in the LED indicator, so I can not tell what the humidity is in the unit.
I called Haier and I got nothing but a big run-around
Let me see if I can help!
1.Turn the unit off.
2. Pull the plug out.
3.wait 5 minutes with the plug out!
4.plug back in after at least 5 minutes.
This reboot should have cleared your EE code and reset you system !
Because the unit still runs and is cold, this told me you may have a glitch in the electronic system.
Let me know how it goes.
I'm hopeful this is solved!
Thank you for using us,Huuum
I am waiting for your response.
Please remember to leave a rating!
Oct 21, 2008 | Haier HVR042 Wine Cooler
Maytag error message EE
What is the name and model number of your unit?
Jun 10, 2008 | Maytag M6Q10F2A Air Conditioner
Refrigerators Logo
237 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
