Question about Whirlpool Ovens
Whirlpool RB5305PDB16 The stove beeps 3 times and when I check the door in locked. The code is F7
  • 4 Answers
SOURCE: GE Profile Stove
I used what Charlie recommended ...” post-it” as insulation
And works PERFECTLY….
I have a Kenmore oven Clock…( built in the wall)
Thanks Charlie…you are a Genius!!!!
Posted on Aug 02, 2008
SOURCE: F7 is beeping is also running
We had a similar issue. I assume you have the touch pad keyboard. If you clean this with a rug that produces static it will cause a problem with the touch pad. I replaced ours and it is now working again. You can get this part at Our p/n for this was
1008902 Touchpad & control panel assembly (Black) 1 $173.10 $173.10
but make sure you check for the correct part/number to fit your oven! Make sure you disconnect power from the oven before you disassemble anything!
I was very happy with the service from I can highly recommend using them!
Posted on Jan 03, 2009
  • 234 Answers
SOURCE: Double GE wall oven - F7 code
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Posted on Apr 27, 2009
  • 619 Answers
SOURCE: Trying to get gas self clean/oven to start. Getting error E1 F5.
E1 F5 is bad door lock assembly. Only way to repair is to replace the locking assembly completly. Sorry. Hope this helps.
Posted on Mar 07, 2010
  • 8619 Answers
SOURCE: code f9 on frigidaire self cleaning oven. what
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Posted on Sep 16, 2010
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
My stove is beeping and is flashing F7. What does this mean, it is a built in oven.
The F7 error code means that a function key on the touchpad is shorted or stuck, the F7 can be cleared by pushing the clear/off button,if the error code returns the touchpad would need to be replaced.
Sep 10, 2011 | GE Ovens
Kemore Mod# 911 4298814 Ser# 9762371 it is giving me a code F1 what is the proplem&
911= Roper stove made by whirlpool
F0 Defective ERC Replace ERC (ERC electronic range control; that expensive stove electronic control)
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Jan 24, 2011 | Kenmore Ovens
Mar 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
F90 code flashing and i cant reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Range led flash code F7
Here is the error information for Fault Code F7
F7 Lock motor relay watchdog circuit is active when it should be off Microprocessor checking the operation of the EDC lock, relay failed. Replace EDC.
Hope this is helpful, I will also provide you a link to to a helpful site.
Mar 14, 2009 | Frigidaire FEB27S5A Electric Single Oven
F2,F5,F7 message
Range/Stove/Oven Fault Codes Failure
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Feb 07, 2009 | Maytag MEW5527B Electric Single Oven
Kenmore Elect Built-IN Oven Model 790
You don't say what specific F code error. If it is an F7, go to the following link for my solution.
I have shared my fix with over 1570 folks and most report success. I hope that it works for you too. Please let me know at:
Feb 23, 2008 | Ovens
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
Ovens Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
