Question about Amana ABB1927DE Bottom Freezer Refrigerator
There are black specs in the ice on my amana french door bottom freezer model. I have chanbed the filter after three months and the problem is still there
  • Amana Master
  • 3,361 Answers
Probably paint flecking from the ice cuber mold.
Posted on Mar 11, 2009
Why does my freezer build up with ice in the bottom
is it a frost free model? if it is the defrost timer may be out or the defrost element may be bad. but if this is not a frost free model the door seals may be bad and need replaced
Aug 24, 2014 | Amana ABB1922FEB (185 cu ft) Bottom...
Amana fridge stopped working for 2 days
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 03, 2012 | Amana AFF2534FE Bottom Freezer French...
Amana fridge. french door ice maker now seems to freeze overflow of water so i'm using hair dryer frequently to remove the clog. why is this starting
Your defrost assembly has probably stopped working, which means that you are probably also building up ice in between the panels.
Jun 06, 2011 | Amana AFI2538A Bottom Freezer French Door...
Our Amana French door ice maker is clogged with ice chunk about 2-in x 6-in and we can't pull it out. The area is too small to pour hot water in onto the ice. Any suggestions?
Good day,
What you have described sounds like a defective water valve on the back bottom rear of the machine. It will need to be replaced.
Although awkward, the best way is to remove the ice maker completely and let it air dry, while the valve gets changed.
The above diagnosis is based on the fact the freezer is maintaining it's normal temperature. If for some reason the freezer thaws and then refreezes that problem would need to be addressed first.
May 26, 2010 | Amana AFD2535FES Stainless Steel Bottom...
Condensation on the strip between the 2 french doors
these fridge have a heater in that black flaper to prevent condensation. It is probably not working or not even plugged...do they removed the doors when they delivered your fridge??? remove the uper left cap of the hinge, the connection is there...... the tech must check that piece if it is well plugged..
Jul 03, 2009 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Ice tastes like plastic. New LG French Door.
Change the filter each week until problem is gone. LG is not usually hit with this problem. good luck.
Jun 09, 2009 | LG LFC25760 French Door Refrigerator
I sure hope you are using an in-line filter for starters, then if the ice still tastes bad, check the source line.
Jun 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Amana bottom freezer not working on model abb2524deq
I replaced the solenoid and my ice machine starting working again.
May 02, 2009 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Amana French Door Bottom Freezer
see if there is any ice caught within the ice maker itself preventing proper cycling of the ice maker. if not pop off the white cover to the ice maker(theres small **** in the cover on bottom right corner of white cover to insert a ***** driver and twist the cover will pop off. look into the center of the main plastic gear, there should be 2 "tabs" holding that gear in place . as if you were to push gear on and the tabs would keep it in place.( reason i mention that it is/was a problem with the ice makers hat the gear would break and it was very noticeable looking into the center gear).if not, theres a detailed trouble shooter for the ice maker behind the kickplate(maybe taped up under front corner under cabinet) it will tell you points to check for power and jump out if necessary
Mar 12, 2008 | Amana AFD2535DES French Door Refrigerator
Amana ABB1927DE Bottom Freezer Refrigerator Logo
106 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
